    [PLUGIN] Voronoi + Conic Curve
    140 Posts 55 Posters 262.8k Views 54 Watching
      I don't expect this to fix it... but you never know 😲
      Look in subfolder's .rb files for these lines...
      cmd.small_icon = "voronoi_conic/icon0s.png" cmd.large_icon = "voronoi_conic/icon0.png"
      Change it to read thus:
      cmd.small_icon = File.join(File.dirname(__FILE__), "icon0s.png") cmd.large_icon = File.join(File.dirname(__FILE__), "icon0.png")
      AND similarly make changes for the other 2 similar entries for cmd1 & cmd2...
      Save & restart SketchUp........
      • OxerO
        Oxer
        Thanks you very much TIG!! πŸ‘
        Problem fixed, I changed the lines and the icons show now.
        • CTXC
          CTX
          for TIG:
          Thank you first of all for the suggestion ........ but I get this message .Where I do wrong? Thanks in advance! πŸŽ‰ πŸŽ‰
          Error message
          • O
            Oxygen220
            anyone know what to do when this happens?
            Error Loading File VoronoiXY.rb
            Error: #<LoadError: cannot load such file -- delauney3.rb>
            C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
            C:/Users/MR-T-REX/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/VoronoiXY.rb:31:in `<top (required)>'
              Yes.
              It's an incompatibility with SketchUp v2014 Ruby2...
              I'm working on a fix...
              • O
                Oxygen220
                ok so i got the points and triangulation working, but when i select the point and click voronoi, nothing happens, what am i missing? 😧 no errors come up, just nothing happens.
                  Here is the updated RBZ in the PluginStore http://sketchucation.com/pluginstore?pln=VoronoiXY
                  It has the corrected icons / paths and is now compatibly encoded files for >= SketchUp v2014 [and earlier!]...
                  It also auto-removes any of its outdated and unwanted files from the base Plugins folder...
                  • OxerO
                    Oxer
                    Hi TIG, you forgot to fix the problem with the TAB key on Mac in the new version:
                    @tig said:
                    The dialog won't open on MAC because the ConicCurveInFace.rb code uses:
                    def onKeyDown(...
                    at line #10.
                    For some unfathomable reason a TAB-key down on MAC is not 'seen', so while pressing the TAB-key on a PC works, it fails silently on a MAC.
                    It's easily fixed by changing the code to read:
                    def onKeyUp(...
                    So then when you release the TAB-key the dialog appears - works on MAC AND PC.
                    Also change the next line from:
                    if key==9 or key==15 or key==48...
                    to read:
                    if key==9 or key==15 ###or key==48...
                      Doh ! πŸ˜’
                      So many bug-fixes... v2.3 in progress...
                        Here's v2.3 which fixes the TAB bug on MACs...
                        • O
                          Oxygen220
                          god damn, ok so i got the 2.3 version, and finally able to get the icons, but the problems still there, i can create points, i can triangulate but when i try the vonoroi tool, nothing happens D:, either its not working or im an idiot and forgot to do something, or both..
                          • CTXC
                            CTX
                            For Tig:
                            Thank you very much, with the two updates (TIG: Triangulate Points v1.1 and
                            MattC: VoronoiXY v2.3) now everything works great.
                            Thanks again for the speed of response. 😍 😍 πŸ‘ πŸ‘
                            • CTXC
                              CTX
                              I would like to ask if anyone knows a plugin for SU able to draw points (maybe choosing how many and in what geometry) on a surface. ❓ ❓
                              Many thanks
                                This is the staple 'PointTool'...
                                http://sketchucation.com/pluginstore?pln=PointTool
                                Toolbar or menu item...
                                It draws individual cpoints [guides] - but you can of course use Rotate OR Move +Ctrl to Copy and then type NNx +<enter> to array them by the number NN repeating the distance, or /NN to divide the original distance up with your copies...
                                  You have Raytracer by Thomthom who dropts Cpoints on Surfaces! πŸ˜‰
                                  http://sketchucation.com/forums/download/file.php?id=53901&t=1
                                    darkshadow47
                                    OK, I feel like a complete idiot for not being able to make this work. I have the current plugin from MattC and TIGs separate triangulation plugin. After creating a polygon and selecting it, if I select Triangulate Points it will ask for a layer name, and then fail with the "No Guide Points in selection". How do I generate guide points?
                                    The Conic curve in a face works fine...
                                      ronel_12
                                      No Existe para Pc ? saludos y bendiciones
                                        No entiendo lo que quieres decir.
                                        Esto funciona en la PC.
                                        ΒΏPor quΓ© crees que no lo hace?
                                        I don't understand what you mean.
                                        This works on PC.
                                        Why do you think it does not?
                                          AUTER
                                          i tried to install in my SketchUp but didnt work... anyone could help me with this?
                                          • sdmitchS
                                            sdmitch
                                            What didn't work? Did not install? Installed but will not run? Runs but no results?
                                            Post the model or a screenshot. Open the Ruby Console and execute the plugin. Post any errors that are shown.
                                            http://sdmitch.blogspot.com/
                                            • 5 / 7
