    [PLUGIN] Voronoi + Conic Curve
    140 Posts 55 Posters 257.9k Views 54 Watching
    • OxerO
      Oxer
      Interesting plugin but the icons don't show on Mac (see the image below), but they work fine.
      When I push Tab key on Mac the Options window doesn't apper.
      OSX 10.9.3 & SU2014
      • CTXC
        CTX
        any news on SU2014?
        thanks in advance!!
          It works in v2014 on PC for me. πŸ˜„
          You do need delauney3.rb loading to get the 'Voroni' part to load and work.
          The zip on this thread's second page includes that. http://sketchucation.com/forums/viewtopic.php?p=417942#p417942
          It also makes the toolbar.
          The issue with MAC and toolbar's missing icons is most usually to do with the PNG files' format.
          Some PC-made PNG images are not suitable for the MAC.
          Try editing the PNGs shipped within the ZIP's subfolder on the MAC and saving them, they might then become MAC-friendly.
          The dialog won't open on MAC because the ConicCurveInFace.rb code uses:
          def onKeyDown(...
          at line #10.
          For some unfathomable reason a TAB-key down on MAC is not 'seen', so while pressing the TAB-key on a PC works, it fails silently on a MAC.
          It's easily fixed by changing the code to read:
          def onKey**Up**(...
          So then when you release the TAB-key the dialog appears - works on MAC AND PC.
          Also change the next line from:
          if key==9 or key==15 or key==48...
          to read:
          if key==9 or key==15 ###or key==48...
          As key#48 is NOT a TAB newer MACs - it's #15, and #9 on PCs.
          You might find odd things happening otherwise.
          This old toolset is a bit creaky BUT it works, and can be fixed up easily too...
          • OxerO
            Oxer
            Thanks TIG for the info, the dialog appears now on MAC. The icons don't show, I changed them to png mac format and resize their resolution of 96 to 72 but without result. It's a mystery!! ❓
              If you make brand new PNG files does that help ?
              The attached ZIP contains just the PNG files at 72 dpi and with the Color Profile 'generalized' [i.e. NOT IExxx] - put them into the subfolder...
              Do they help on your MAC ?
              voronoi_conic.zip
              • OxerO
                Oxer
                Thanks TIG for the effort but your icons don't show on Mac. 😒 ❓
                I don't know if the problem is in the ConicCurveInFace.rb file, if there is a missing code to load the icons. The mouse icon shows correctly.
                  I don't expect this to fix it... but you never know 😲
                  Look in subfolder's .rb files for these lines...
                  cmd.small_icon = "voronoi_conic/icon0s.png" cmd.large_icon = "voronoi_conic/icon0.png"
                  Change it to read thus:
                  cmd.small_icon = File.join(File.dirname(__FILE__), "icon0s.png") cmd.large_icon = File.join(File.dirname(__FILE__), "icon0.png")
                  AND similarly make changes for the other 2 similar entries for cmd1 & cmd2...
                  Save & restart SketchUp........
                  • OxerO
                    Oxer
                    Thanks you very much TIG!! πŸ‘
                    Problem fixed, I changed the lines and the icons show now.
                    • CTXC
                      CTX
                      for TIG:
                      Thank you first of all for the suggestion ........ but I get this message .Where I do wrong? Thanks in advance! πŸŽ‰ πŸŽ‰
                      Error message
                      • O
                        Oxygen220
                        anyone know what to do when this happens?
                        Error Loading File VoronoiXY.rb
                        Error: #<LoadError: cannot load such file -- delauney3.rb>
                        C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                        C:/Users/MR-T-REX/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/VoronoiXY.rb:31:in `<top (required)>'
                          Yes.
                          It's an incompatibility with SketchUp v2014 Ruby2...
                          I'm working on a fix...
                          • O
                            Oxygen220
                            ok so i got the points and triangulation working, but when i select the point and click voronoi, nothing happens, what am i missing? 😧 no errors come up, just nothing happens.
                              Here is the updated RBZ in the PluginStore http://sketchucation.com/pluginstore?pln=VoronoiXY
                              It has the corrected icons / paths and is now compatibly encoded files for >= SketchUp v2014 [and earlier!]...
                              It also auto-removes any of its outdated and unwanted files from the base Plugins folder...
                              • OxerO
                                Oxer
                                Hi TIG, you forgot to fix the problem with the TAB key on Mac in the new version:
                                def onKeyDown(...
                                at line #10.
                                def onKeyUp(...
                                to read:
                                  Doh ! πŸ˜’
                                  So many bug-fixes... v2.3 in progress...
                                    Here's v2.3 which fixes the TAB bug on MACs...
                                    • O
                                      Oxygen220
                                      god damn, ok so i got the 2.3 version, and finally able to get the icons, but the problems still there, i can create points, i can triangulate but when i try the vonoroi tool, nothing happens D:, either its not working or im an idiot and forgot to do something, or both..
                                      • CTXC
                                        CTX
                                        For Tig:
                                        Thank you very much, with the two updates (TIG: Triangulate Points v1.1 and
                                        MattC: VoronoiXY v2.3) now everything works great.
                                        Thanks again for the speed of response. 😍 😍 πŸ‘ πŸ‘
                                        • CTXC
                                          CTX
                                          I would like to ask if anyone knows a plugin for SU able to draw points (maybe choosing how many and in what geometry) on a surface. ❓ ❓
                                          Many thanks
                                            This is the staple 'PointTool'...
                                            http://sketchucation.com/pluginstore?pln=PointTool
                                            Toolbar or menu item...
                                            It draws individual cpoints [guides] - but you can of course use Rotate OR Move +Ctrl to Copy and then type NNx +<enter> to array them by the number NN repeating the distance, or /NN to divide the original distance up with your copies...
                                            • 5 / 7
