    [PLUGIN] Voronoi + Conic Curve
    140 Posts 55 Posters 239.9k Views 54 Watching
      It works in v2014 on PC for me. πŸ˜„
      You do need delauney3.rb loading to get the 'Voroni' part to load and work.
      The zip on this thread's second page includes that. http://sketchucation.com/forums/viewtopic.php?p=417942#p417942
      It also makes the toolbar.
      The issue with MAC and toolbar's missing icons is most usually to do with the PNG files' format.
      Some PC-made PNG images are not suitable for the MAC.
      Try editing the PNGs shipped within the ZIP's subfolder on the MAC and saving them, they might then become MAC-friendly.
      The dialog won't open on MAC because the ConicCurveInFace.rb code uses:
      def onKeyDown(...
      at line #10.
      For some unfathomable reason a TAB-key down on MAC is not 'seen', so while pressing the TAB-key on a PC works, it fails silently on a MAC.
      It's easily fixed by changing the code to read:
      def onKey**Up**(...
      So then when you release the TAB-key the dialog appears - works on MAC AND PC.
      Also change the next line from:
      if key==9 or key==15 or key==48...
      to read:
      if key==9 or key==15 ###or key==48...
      As key#48 is NOT a TAB newer MACs - it's #15, and #9 on PCs.
      You might find odd things happening otherwise.
      This old toolset is a bit creaky BUT it works, and can be fixed up easily too...
      • OxerO Offline
        Oxer
        Thanks TIG for the info, the dialog appears now on MAC. The icons don't show, I changed them to png mac format and resize their resolution of 96 to 72 but without result. It's a mystery!! ❓
          If you make brand new PNG files does that help ?
          The attached ZIP contains just the PNG files at 72 dpi and with the Color Profile 'generalized' [i.e. NOT IExxx] - put them into the subfolder...
          Do they help on your MAC ?
          voronoi_conic.zip
          • OxerO Offline
            Oxer
            Thanks TIG for the effort but your icons don't show on Mac. 😒 ❓
            I don't know if the problem is in the ConicCurveInFace.rb file, if there is a missing code to load the icons. The mouse icon shows correctly.
              I don't expect this to fix it... but you never know 😲
              Look in subfolder's .rb files for these lines...
              cmd.small_icon = "voronoi_conic/icon0s.png" cmd.large_icon = "voronoi_conic/icon0.png"
              Change it to read thus:
              cmd.small_icon = File.join(File.dirname(__FILE__), "icon0s.png") cmd.large_icon = File.join(File.dirname(__FILE__), "icon0.png")
              AND similarly make changes for the other 2 similar entries for cmd1 & cmd2...
              Save & restart SketchUp........
              • OxerO Offline
                Oxer
                Thanks you very much TIG!! πŸ‘
                Problem fixed, I changed the lines and the icons show now.
                • CTXC Offline
                  CTX
                  for TIG:
                  Thank you first of all for the suggestion ........ but I get this message .Where I do wrong? Thanks in advance! πŸŽ‰ πŸŽ‰
                  Error message
                  • O Offline
                    Oxygen220
                    anyone know what to do when this happens?
                    Error Loading File VoronoiXY.rb
                    Error: #<LoadError: cannot load such file -- delauney3.rb>
                    C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                    C:/Users/MR-T-REX/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/VoronoiXY.rb:31:in `<top (required)>'
                      Yes.
                      It's an incompatibility with SketchUp v2014 Ruby2...
                      I'm working on a fix...
                      • O Offline
                        Oxygen220
                        ok so i got the points and triangulation working, but when i select the point and click voronoi, nothing happens, what am i missing? 😧 no errors come up, just nothing happens.
                          Here is the updated RBZ in the PluginStore http://sketchucation.com/pluginstore?pln=VoronoiXY
                          It has the corrected icons / paths and is now compatibly encoded files for >= SketchUp v2014 [and earlier!]...
                          It also auto-removes any of its outdated and unwanted files from the base Plugins folder...
                          • OxerO Offline
                            Oxer
                            Hi TIG, you forgot to fix the problem with the TAB key on Mac in the new version:
                            def onKeyDown(...
                            at line #10.
                            def onKeyUp(...
                            to read:
                              Doh ! πŸ˜’
                              So many bug-fixes... v2.3 in progress...
                                Here's v2.3 which fixes the TAB bug on MACs...
                                • O Offline
                                  Oxygen220
                                  god damn, ok so i got the 2.3 version, and finally able to get the icons, but the problems still there, i can create points, i can triangulate but when i try the vonoroi tool, nothing happens D:, either its not working or im an idiot and forgot to do something, or both..
                                  • CTXC Offline
                                    CTX
                                    For Tig:
                                    Thank you very much, with the two updates (TIG: Triangulate Points v1.1 and
                                    MattC: VoronoiXY v2.3) now everything works great.
                                    Thanks again for the speed of response. 😍 😍 πŸ‘ πŸ‘
                                    • CTXC Offline
                                      CTX
                                      I would like to ask if anyone knows a plugin for SU able to draw points (maybe choosing how many and in what geometry) on a surface. ❓ ❓
                                      Many thanks
                                        This is the staple 'PointTool'...
                                        http://sketchucation.com/pluginstore?pln=PointTool
                                        Toolbar or menu item...
                                        It draws individual cpoints [guides] - but you can of course use Rotate OR Move +Ctrl to Copy and then type NNx +<enter> to array them by the number NN repeating the distance, or /NN to divide the original distance up with your copies...
                                          You have Raytracer by Thomthom who dropts Cpoints on Surfaces! πŸ˜‰
                                          http://sketchucation.com/forums/download/file.php?id=53901&t=1
                                            darkshadow47
                                            OK, I feel like a complete idiot for not being able to make this work. I have the current plugin from MattC and TIGs separate triangulation plugin. After creating a polygon and selecting it, if I select Triangulate Points it will ask for a layer name, and then fail with the "No Guide Points in selection". How do I generate guide points?
                                            The Conic curve in a face works fine...
                                            • 5 / 7
