    [WIP] Skateboard
    11 Posts 8 Posters 1.8k Views 8 Watching
    • HieruH Offline
      Hieru
      Here's a work in progress that's been on the back burner for a while. Hopefully I will find some time to finish it this weekend.
      Most of the modelling is done, although I need to dirty up the scene with some gravel and trash to add to the realism. Other than that I need to work on the lighting and textures.
      Stage 1: Skateboard modelling - proxies.
      Stage 2: Skateboard modelling - finished geometry.
      Stage 3: First renders - using a basic studio setup.
      At this point I wasn't happy with the scene - mostly because of the obvious repeating texture - so I decided to place the skateboard in a real-world environment. The obvious thing to do was create a skate park backdrop. HDRIs didn't work very well so I modelled the environment with SU.
      The scene was still missing something, so I decided to model some more props. The first thing I wanted to add was a helmet.
      Stage 4: Helmet modelling.
      Stage 5: Rendering the scene with the added helmet.
      www.davidhier.co.uk
      • jeff hammondJ Offline
        jeff hammond
        wow.. nice!
        definitely the best looking sketchup skateboard model i've ever seen..
        not to mention the protec which is looking sweet too.
        πŸ‘ πŸ‘
        dotdotdot
          jeff hammond
          the trucks though.. those are looking very good.. and they're probably the hardest things to get right..
          dotdotdot
            That's pretty incredible David πŸ‘
              dsarchs
              Modelling looks great -- but scratches and wear on the trucks and deck wouldn't hurt.
              Great job!
              Knowledge is a polite word for dead but not buried imagination.
              -e.e.cummings
                liam887
                In love with the polystyrene texture on the inside of the helmet, good work - is that custom or stock?
                Cheers
                Liam
                VISIT MY ONLINE GALLERY
                • massimoM Offline
                  massimo Moderator
                  Well done David. πŸ‘
                  • HieruH Offline
                    Hieru
                    Thanks guys πŸ‘
                    @Jeff Hammond - Nice to see you pick up on the detailing of the trucks: most people simply wouldn't notice. The trucks weren't that hard really, but it helps when you've got something in front of you to model from. The only issue I had was figuring out how to use Artisan to create simple beveled edges on the base plate. Also they started out as Venture trucks but somehow turned into Thunder's πŸ˜• .
                    @dsarchs - You're right. There are already scratches on the trucks, but the texture I've used needs changing. I was going to leave the deck in factory condition, but a few scrapes will help. I'll probably swap the graphics out for a real-world design as well.
                    @liam887 - The polystyrene is a custom texture/material based on a stock image. I could really do with a better base image, but I don't have any of the right material to hand.
                    www.davidhier.co.uk
                    • MarianM Offline
                      Marian
                      Very very nice. πŸ˜„
                      • Bryan KB Offline
                        For simple bevels, I use BZ Roundedge.
                        Great model!
                        • HieruH Offline
                          Hieru
                          Thanks Marian and Bryan.
                          The first thing I tried with the truck base was RoundCorner, but it didn't work very well with that shape.
                          www.davidhier.co.uk
