    [Plugin] SketchUV - now free
    176 Posts 62 Posters 169.5k Views 62 Watching
    • H Offline
      hsrhdrehre5654654
      Great tool. Just one question.. im trying to export the uvs. Here is the problem, i set the extraction path in, for example d:/ , then i go to options - export uvs, and a msg appear saying that the uvs have been exported. Well, i cant find the obj file anywhere. And since in the msg box there is not info about the path itself, im totally lost. My guess is it is exporting the uvs to the default folder instead. So, what is the default folder where the uvs are exported?
      • H Offline
        hsrhdrehre5654654
        Oh well. NVM. It turns out i was "saving" the uvs, not exporting rofl!!! sorry my bad.
        • dereiD Offline
          derei
          Can't export UVs. The error is "Unable to export UVs" and after a quick inspection in the console, it seems the default export path doesn't exist anymore (indeed, the folder was renamed). The problem is that I have no idea how I can convince the plugin to export somewhere else...
          Please help!
          DESIGNER AND ARTIST DEREI.UK
          • dereiD Offline
            derei
            Please help!
            Solved - I deleted the REG entry. Nonetheless, should address the issue in a better manner (if path not found, to prompt for a new path).
            Cheers!
            • sicksickisckS Offline
              sicksickisck
              • W Offline
                Whaat
                @sicksickisck said:
                [attachment=1:2ohepcgx]<!-- ia1 -->EXPORT UV.JPG<!-- ia1 -->[/attachment:2ohepcgx]
                EXPORT UV, BUG SKP 2016[attachment=0:2ohepcgx]<!-- ia0 -->VER.JPG<!-- ia0 -->[/attachment:2ohepcgx]
                Do you have the entire ruby output available?
                I'm guessing you might have a conflicting plugin.
                • K Offline
                  kubap
                  Hi, sketchup says that this plugin is unidentified (doesn't have digital signature) and therefore may be risky to use. I don't have this issue with other plugins.
                  • W Offline
                    Whaat
                    Thanks for the note - the current version on the EW might not have a signature. I'll have to fix that.
                    • K Offline
                      kcezario_ep
                      I do not know why this happens to me always.
                      Some faces never get right
                      • W Offline
                        Whaat
                        Have you checked the Ruby Console for errors?
                          lBeral
                          @derei said:
                          Please help!
                          Cheers!
                          If someone have the same problem the registry's path is
                          "HKEY_CURRENT_USER\Software\SketchUp\SketchUp 2017\UVTools"
                            maurorog
                            How to apply the tool to an object that shows both front and back sides, such as a folded sheet
                            http://i68.tinypic.com/rtguja.jpg
                            • W Offline
                              Whaat
                              Hi maurorog,
                              I don't think it is possible to apply the UV mapping to the back side of the face in SketchUV, unless someone knows a clever trick.
                              • E Offline
                                Einstein
                                Hello!
                                Could someone please post the lost manual PDF file? I'd gladly see list of hotkeys instead if video tutorial.
                                Or just tell me how to move and rotate UV texture while mapping?
                                I know that scaling goes by typing *X or /X but can't find the rest of transformation hotkeys.
                                  safak
                                  I want to be able to have models with UV mapping but without textures applied to them. Is there any way to do it without seeing the multi-coloured default material of SketchUV?
                                  Thank you,
                                  • N Offline
                                    nlipovac
                                    Replace it with a white pic - 512x512 jpg, in the plugin folder.
                                    • 6
                                    • 7
                                    • 8
                                    • 9
                                    • 9 / 9
