    [Plugin] SketchUV - now free
    176 Posts 62 Posters 162.6k Views 62 Watching
    • romboutR Offline
      rombout
      After checking again and using a simple cube i found that 39.37% scale is exact. I could also use the tape measure ofcourse, i totally forgot about that function. Measuring the down scaled part and than simply typing the exact number.
      Now i wonder why the scale is such awkward number, any know familiar with this 😄
      • Z Offline
        Zacchia
        This is because 1 m is about 39.37 inches I think...
          AcesHigh
          I suppose this is not the place... or maybe it is... but I followed the Roadkill SketchUV road mapping tutorial and it didn´t work at all.
          The problem was that my road had a more complex triangulation and when I started pulling the border vertexes arond at RoadKill, Roadkill did not know how to deal with the vertexes in the middle of the road... it resulted in a bad mess, specially when I would pull the right vertexes to the right side of the map... there were triangles jumping all over the place inside Roadkill 😕
            dacastror
            mistakes like this are appearing on the console
            Error: #<NameError: uninitialized constant DM_SketchUV::DM_UVTool::Set>
            I'm using Sketchup 2015. When you use version 1.0 works fine, but there are flaws in version 1.0.1
            • W Offline
              Whaat
              Thanks for the report - I'll look into it. Are you sure you have the latest version installed?
              • BSquared18B Offline
                BSquared18
                **Hello Dale,
                I started a thread titled "Need Help Using SketchUV for UV mapping" at:
                http://sketchucation.com/forums/viewtopic.php?f=80%26amp;t=63227%26amp;p=578909#p578909
                In short, I am trying to UV-map the texture from a .png file to a SketchUp 3D model of an aircraft instrument panel. The details are in the above-mentioned thread.
                I've gone through the steps listed in your tutorials, except that instead of applying a texture from SU's Paint Bucket palette, I have tried to import it using SU's Import Texture feature.
                But after applying it and trying to export it using Marginal's SU2XP plugin, I do not get the desired effect.
                Do you have any suggestions?
                Thank you,
                Bill**
                • H Offline
                  hsrhdrehre5654654
                  Great tool. Just one question.. im trying to export the uvs. Here is the problem, i set the extraction path in, for example d:/ , then i go to options - export uvs, and a msg appear saying that the uvs have been exported. Well, i cant find the obj file anywhere. And since in the msg box there is not info about the path itself, im totally lost. My guess is it is exporting the uvs to the default folder instead. So, what is the default folder where the uvs are exported?
                  • H Offline
                    hsrhdrehre5654654
                    Oh well. NVM. It turns out i was "saving" the uvs, not exporting rofl!!! sorry my bad.
                    • dereiD Offline
                      derei
                      Can't export UVs. The error is "Unable to export UVs" and after a quick inspection in the console, it seems the default export path doesn't exist anymore (indeed, the folder was renamed). The problem is that I have no idea how I can convince the plugin to export somewhere else...
                      Please help!
                      • dereiD Offline
                        derei
                        Please help!
                        Solved - I deleted the REG entry. Nonetheless, should address the issue in a better manner (if path not found, to prompt for a new path).
                        Cheers!
                        • sicksickisckS Offline
                          sicksickisck
                          • W Offline
                            Whaat
                            @sicksickisck said:
                            [attachment=1:2ohepcgx]<!-- ia1 -->EXPORT UV.JPG<!-- ia1 -->[/attachment:2ohepcgx]
                            EXPORT UV, BUG SKP 2016[attachment=0:2ohepcgx]<!-- ia0 -->VER.JPG<!-- ia0 -->[/attachment:2ohepcgx]
                            Do you have the entire ruby output available?
                            I'm guessing you might have a conflicting plugin.
                              kubap
                              Hi, sketchup says that this plugin is unidentified (doesn't have digital signature) and therefore may be risky to use. I don't have this issue with other plugins.
                              • W Offline
                                Whaat
                                Thanks for the note - the current version on the EW might not have a signature. I'll have to fix that.
                                  kcezario_ep
                                  I do not know why this happens to me always.
                                  Some faces never get right
                                  • W Offline
                                    Whaat
                                    Have you checked the Ruby Console for errors?
                                      lBeral
                                      @derei said:
                                      Please help!
                                      Cheers!
                                      If someone have the same problem the registry's path is
                                      "HKEY_CURRENT_USER\Software\SketchUp\SketchUp 2017\UVTools"
                                        maurorog
                                        How to apply the tool to an object that shows both front and back sides, such as a folded sheet
                                        http://i68.tinypic.com/rtguja.jpg
                                        • W Offline
                                          Whaat
                                          Hi maurorog,
                                          I don't think it is possible to apply the UV mapping to the back side of the face in SketchUV, unless someone knows a clever trick.
                                          • E Offline
                                            Einstein
                                            Hello!
                                            Could someone please post the lost manual PDF file? I'd gladly see list of hotkeys instead if video tutorial.
                                            Or just tell me how to move and rotate UV texture while mapping?
                                            I know that scaling goes by typing *X or /X but can't find the rest of transformation hotkeys.
                                            • 9 / 9
