    [Plugin] SketchUV - now free
    176 Posts 62 Posters 169.5k Views 62 Watching
    • ToboboT Offline
      Tobobo
      @frederik said:
      It even looks great when rendered... 😄
      That's great 😄
      Thanks mate!
      Toby
      Philippians 4:13
      • Z Offline
        Zacchia
        Many thanks for this nice plugin!!
        • romboutR Offline
          rombout
          I got a question. Ive read somewhere when import a obj mesh which gets triangulated at normal size (for me metric) better use a smaller import size. Im using meter in blender and than import it as inch into SU, cm still gives triangles and mm cuts holes.
          what scale do i need to use to set it back to meter. Im searching google but im not sure what keywords i need to use. Im non english person so bit harder for correct translation.
          Doing my own tests i came around 39.35% when i use the scale tool in SU, im still a bit off. Anyone here who knows the exact scale method
          • romboutR Offline
            rombout
            After checking again and using a simple cube i found that 39.37% scale is exact. I could also use the tape measure ofcourse, i totally forgot about that function. Measuring the down scaled part and than simply typing the exact number.
            Now i wonder why the scale is such awkward number, any know familiar with this 😄
            • Z Offline
              Zacchia
              This is because 1 m is about 39.37 inches I think...
                AcesHigh
                I suppose this is not the place... or maybe it is... but I followed the Roadkill SketchUV road mapping tutorial and it didn´t work at all.
                The problem was that my road had a more complex triangulation and when I started pulling the border vertexes arond at RoadKill, Roadkill did not know how to deal with the vertexes in the middle of the road... it resulted in a bad mess, specially when I would pull the right vertexes to the right side of the map... there were triangles jumping all over the place inside Roadkill 😕
                  dacastror
                  mistakes like this are appearing on the console
                  Error: #<NameError: uninitialized constant DM_SketchUV::DM_UVTool::Set>
                  I'm using Sketchup 2015. When you use version 1.0 works fine, but there are flaws in version 1.0.1
                  • W Offline
                    Whaat
                    Thanks for the report - I'll look into it. Are you sure you have the latest version installed?
                    • BSquared18B Offline
                      BSquared18
                      **Hello Dale,
                      I started a thread titled "Need Help Using SketchUV for UV mapping" at:
                      404 Not Found
                      (sketchucation.com)
                      In short, I am trying to UV-map the texture from a .png file to a SketchUp 3D model of an aircraft instrument panel. The details are in the above-mentioned thread.
                      I've gone through the steps listed in your tutorials, except that instead of applying a texture from SU's Paint Bucket palette, I have tried to import it using SU's Import Texture feature.
                      But after applying it and trying to export it using Marginal's SU2XP plugin, I do not get the desired effect.
                      Do you have any suggestions?
                      Thank you,
                      Bill**
                      • H Offline
                        hsrhdrehre5654654
                        Great tool. Just one question.. im trying to export the uvs. Here is the problem, i set the extraction path in, for example d:/ , then i go to options - export uvs, and a msg appear saying that the uvs have been exported. Well, i cant find the obj file anywhere. And since in the msg box there is not info about the path itself, im totally lost. My guess is it is exporting the uvs to the default folder instead. So, what is the default folder where the uvs are exported?
                        • H Offline
                          hsrhdrehre5654654
                          Oh well. NVM. It turns out i was "saving" the uvs, not exporting rofl!!! sorry my bad.
                          • dereiD Offline
                            derei
                            Can't export UVs. The error is "Unable to export UVs" and after a quick inspection in the console, it seems the default export path doesn't exist anymore (indeed, the folder was renamed). The problem is that I have no idea how I can convince the plugin to export somewhere else...
                            Please help!
                            DESIGNER AND ARTIST DEREI.UK
                            • dereiD Offline
                              derei
                              Please help!
                              Solved - I deleted the REG entry. Nonetheless, should address the issue in a better manner (if path not found, to prompt for a new path).
                              Cheers!
                              • sicksickisckS Offline
                                sicksickisck
                                • W Offline
                                  Whaat
                                  @sicksickisck said:
                                  [attachment=1:2ohepcgx]<!-- ia1 -->EXPORT UV.JPG<!-- ia1 -->[/attachment:2ohepcgx]
                                  EXPORT UV, BUG SKP 2016[attachment=0:2ohepcgx]<!-- ia0 -->VER.JPG<!-- ia0 -->[/attachment:2ohepcgx]
                                  Do you have the entire ruby output available?
                                  I'm guessing you might have a conflicting plugin.
                                    kubap
                                    Hi, sketchup says that this plugin is unidentified (doesn't have digital signature) and therefore may be risky to use. I don't have this issue with other plugins.
                                    • W Offline
                                      Whaat
                                      Thanks for the note - the current version on the EW might not have a signature. I'll have to fix that.
                                        kcezario_ep
                                        I do not know why this happens to me always.
                                        Some faces never get right
                                        • W Offline
                                          Whaat
                                          Have you checked the Ruby Console for errors?
                                            lBeral
                                            @derei said:
                                            Please help!
                                            Cheers!
                                            If someone have the same problem the registry's path is
                                            "HKEY_CURRENT_USER\Software\SketchUp\SketchUp 2017\UVTools"
                                            • 9 / 9
