    [Plugin] SketchUV - now free
    176 Posts 62 Posters 175.8k Views 62 Watching
    • BSquared18B
      BSquared18
      **Hello Dale,
      I started a thread titled "Need Help Using SketchUV for UV mapping" at:
      404 Not Found
      (sketchucation.com)
      In short, I am trying to UV-map the texture from a .png file to a SketchUp 3D model of an aircraft instrument panel. The details are in the above-mentioned thread.
      I've gone through the steps listed in your tutorials, except that instead of applying a texture from SU's Paint Bucket palette, I have tried to import it using SU's Import Texture feature.
      But after applying it and trying to export it using Marginal's SU2XP plugin, I do not get the desired effect.
      Do you have any suggestions?
      Thank you,
      Bill**
      • H
        hsrhdrehre5654654
        Great tool. Just one question.. im trying to export the uvs. Here is the problem, i set the extraction path in, for example d:/ , then i go to options - export uvs, and a msg appear saying that the uvs have been exported. Well, i cant find the obj file anywhere. And since in the msg box there is not info about the path itself, im totally lost. My guess is it is exporting the uvs to the default folder instead. So, what is the default folder where the uvs are exported?
        • H
          hsrhdrehre5654654
          Oh well. NVM. It turns out i was "saving" the uvs, not exporting rofl!!! sorry my bad.
          • dereiD
            derei
            Can't export UVs. The error is "Unable to export UVs" and after a quick inspection in the console, it seems the default export path doesn't exist anymore (indeed, the folder was renamed). The problem is that I have no idea how I can convince the plugin to export somewhere else...
            Please help!
            DESIGNER AND ARTIST DEREI.UK
            • dereiD
              derei
              Please help!
              Solved - I deleted the REG entry. Nonetheless, should address the issue in a better manner (if path not found, to prompt for a new path).
              Cheers!
              • sicksickisckS
                sicksickisck
                • W
                  Whaat
                  @sicksickisck said:
                  [attachment=1:2ohepcgx]<!-- ia1 -->EXPORT UV.JPG<!-- ia1 -->[/attachment:2ohepcgx]
                  EXPORT UV, BUG SKP 2016[attachment=0:2ohepcgx]<!-- ia0 -->VER.JPG<!-- ia0 -->[/attachment:2ohepcgx]
                  Do you have the entire ruby output available?
                  I'm guessing you might have a conflicting plugin.
                  • K
                    kubap
                    Hi, sketchup says that this plugin is unidentified (doesn't have digital signature) and therefore may be risky to use. I don't have this issue with other plugins.
                    • W
                      Whaat
                      Thanks for the note - the current version on the EW might not have a signature. I'll have to fix that.
                      • K
                        kcezario_ep
                        I do not know why this happens to me always.
                        Some faces never get right
                        • W
                          Whaat
                          Have you checked the Ruby Console for errors?
                          • L
                            lBeral
                            @derei said:
                            Please help!
                            Cheers!
                            If someone have the same problem the registry's path is
                            "HKEY_CURRENT_USER\Software\SketchUp\SketchUp 2017\UVTools"
                              maurorog
                              How to apply the tool to an object that shows both front and back sides, such as a folded sheet
                              http://i68.tinypic.com/rtguja.jpg
                              • W
                                Whaat
                                Hi maurorog,
                                I don't think it is possible to apply the UV mapping to the back side of the face in SketchUV, unless someone knows a clever trick.
                                • E
                                  Einstein
                                  Hello!
                                  Could someone please post the lost manual PDF file? I'd gladly see list of hotkeys instead if video tutorial.
                                  Or just tell me how to move and rotate UV texture while mapping?
                                  I know that scaling goes by typing *X or /X but can't find the rest of transformation hotkeys.
                                    safak
                                    I want to be able to have models with UV mapping but without textures applied to them. Is there any way to do it without seeing the multi-coloured default material of SketchUV?
                                    Thank you,
                                    • N
                                      nlipovac
                                      Replace it with a white pic - 512x512 jpg, in the plugin folder.
                                      • 9 / 9
