    [Plugin] SketchUV - now free
    176 Posts 62 Posters 169.5k Views 62 Watching
      kubap
      Hi, sketchup says that this plugin is unidentified (doesn't have digital signature) and therefore may be risky to use. I don't have this issue with other plugins.
      • W Offline
        Whaat
        Thanks for the note - the current version on the EW might not have a signature. I'll have to fix that.
          kcezario_ep
          I do not know why this happens to me always.
          Some faces never get right
          • W Offline
            Whaat
            Have you checked the Ruby Console for errors?
              lBeral
              @derei said:
              @derei said:
              Can't export UVs. The error is "Unable to export UVs" and after a quick inspection in the console, it seems the default export path doesn't exist anymore (indeed, the folder was renamed). The problem is that I have no idea how I can convince the plugin to export somewhere else...
              Please help!
              Solved - I deleted the REG entry. Nonetheless, should address the issue in a better manner (if path not found, to prompt for a new path).
              Cheers!
              If someone have the same problem the registry's path is
              "HKEY_CURRENT_USER\Software\SketchUp\SketchUp 2017\UVTools"
                maurorog
                How to apply the tool to an object that shows both front and back sides, such as a folded sheet
                http://i68.tinypic.com/rtguja.jpg
                • W Offline
                  Whaat
                  Hi maurorog,
                  I don't think it is possible to apply the UV mapping to the back side of the face in SketchUV, unless someone knows a clever trick.
                  • E Offline
                    Einstein
                    Hello!
                    Could someone please post the lost manual PDF file? I'd gladly see list of hotkeys instead if video tutorial.
                    Or just tell me how to move and rotate UV texture while mapping?
                    I know that scaling goes by typing *X or /X but can't find the rest of transformation hotkeys.
                      safak
                      I want to be able to have models with UV mapping but without textures applied to them. Is there any way to do it without seeing the multi-coloured default material of SketchUV?
                      Thank you,
                      • N Offline
                        nlipovac
                        Replace it with a white pic - 512x512 jpg, in the plugin folder.
                        • 9 / 9
