    (solved) cpu slows down with high res
    renderpluginsextensions
    7 Posts 4 Posters 2.4k Views 4 Watching
    • K Offline
      kudel47
      Hi.
      Maybe you know why my cpu slows down to 20% while rendering 3500x2500 image. It goes 100% at smaller res. like 1600x1200 and it takes about 2hr. my laptop cpu i7 2630 jumps to 2,7 ghz and memmory work 50% of 8gb while rendering and its normal. Render time big image is so long and i got work for yesterday 😞 I use latest version of skp and vray.
      Help!
      i set only IM with DMC and the scene has 12mb
      • andybotA Offline
        andybot
        have you tried rendering to raw format (save as .exr)?
        • K Offline
          kudel47
          Whith rendering exr file its still about 30-35% of cpu. small diffrence but not help to much:p
          I set priority for sketchup process in windows and unchceck the low priority render option in vray.
          • eidam655E Offline
            eidam655
            do i understand it correctly if it's a laptop?
            because then it seems like some anti-throttling policy of the power management, and not an issue related to SU/VRay.
            I'm using SketchUp 2017, V-Ray 3.4
            • K Offline
              kudel47
              Solve. if i turn off displacement (which was only with one towel) everything goes fast!
              • V Offline
                valerostudio
                Displacement kills CPU, use it sparingly. Also, try to get away with using lower subdivs and and a higher edge length. On high res renders you can sometimes get away with an edge of 20+ pixels. Try it out.
                • K Offline
                  kudel47
                  Thanks for good advice but in this situation i used edge length 1,0 without 'use global' option to make it real, full of details. Finally for the high resolution render i made it with fur plugin. it looks better i think:)
