(solved) cpu slows down with high res
Hi.
Maybe you know why my cpu slows down to 20% while rendering 3500x2500 image. It goes 100% at smaller res. like 1600x1200 and it takes about 2hr. my laptop cpu i7 2630 jumps to 2,7 ghz and memmory work 50% of 8gb while rendering and its normal. Render time big image is so long and i got work for yesterday
I use latest version of skp and vray.
Help!i set only IM with DMC and the scene has 12mb
have you tried rendering to raw format (save as .exr)?
Whith rendering exr file its still about 30-35% of cpu. small diffrence but not help to much:p
I set priority for sketchup process in windows and unchceck the low priority render option in vray. -
do i understand it correctly if it's a laptop?
because then it seems like some anti-throttling policy of the power management, and not an issue related to SU/VRay.
Solve. if i turn off displacement (which was only with one towel) everything goes fast!
Displacement kills CPU, use it sparingly. Also, try to get away with using lower subdivs and and a higher edge length. On high res renders you can sometimes get away with an edge of 20+ pixels. Try it out.
Thanks for good advice but in this situation i used edge length 1,0 without 'use global' option to make it real, full of details. Finally for the high resolution render i made it with fur plugin. it looks better i think:)
