    Save model in PNG without background . anyone?
    20 Posts 4 Posters 3.9k Views 4 Watching
    • tibetT
      tibet
      hi,
      i wonder if there is an option how to save model in PNG without background or have to edit in other corelraw/photohop program
      thanks!
      http://i52.tinypic.com/zujcp1.jpg
      SU 2015 Pro on Win10 x64
      • GaieusG
        The Mac version can do it natively and for us, puny Windows users, there is this plugin:
        http://forums.sketchucation.com/viewtopic.php?t=30819
        Note that you need to turn off sky and ground and turn your background completely white (RGB 255 all) in order that this plugin work.
        • thomthomT
          eh? really? thought I've used it with any colour background - as long as sky and ground is off...
          • GaieusG
            That's what I remember. Hold on...
            • thomthomT
              Yes I have - it's even in the screenshots of the post - using the default grey background of SU's architecture template.
              • GaieusG
                Okay, you may be right, I could only find the sky and background issue in the topic (I was the one with problems).
                • thomthomT
                  For that model you could use QuadFace Tools to UV map the surface: http://forums.sketchucation.com/viewtopic.php?f=323&t=39442&hilit=+quadface#p348501
                  • tibetT
                    tibet
                    hi,
                    a pretty fast answer, thank you!
                    The more i learn, the more i realize how little i know in difference from you guys πŸ˜„
                    best of luck !
                    • tibetT
                      tibet
                      hi,
                      thanks for your tips, so what are the final tricks?
                      a smart plugin solves everything ?
                      wow, thatΒ΄s pretty cool !
                      additional question about adding texture to faces
                      round one http://www.youtube.com/watch?v=AVYYdWYRqrg
                      flat surface http://www.youtube.com/watch?v=KEg6tHWNXb4&feature=relmfu
                      to move texture on flat surface is easy, but what about round one 😞
                      i need to move a bit replace my texture at the entrance of the building / see picture
                      thanks!
                      http://i.imgur.com/9wFoN.jpg
                      • tibetT
                        tibet
                        hi,
                        the plugin works like a charm, but my model is a bit "hairy" πŸ˜„
                        is there any setting how to convert model into higher resolution of PNG, to reduce raster to minimum please?
                        thank you!
                        http://i.imgur.com/mmM1Ol.jpg
                        • thomthomT
                          You have the same settings as when you export normally, Width, Height and Anti-aliasing - adjust to your requirement.
                          I never use SketchUp's AA when exporting - instead I export the image out much larger and scale down in Photoshop which then produce nice smooth edges.
                          • thomthomT
                            Haven't used other applications. Either I do it by hand, or I use the panorama function in PhotoShop. http://tv.adobe.com/watch/learn-photoshop-cs5/creating-a-panorama/
                            • tibetT
                              tibet
                              hi,
                              youΒ΄re right. to export bigger model, then resize in PS, but when i need transparent backgroung?
                              do you thing PS fix everything?
                              thanks!
                              note: just making a texture of bulding (another project) photos were made from many places around.
                              when i need to make panorama pic to wrap the model, iΒ΄ve to fix/strech photos for nice result.
                              do you think PS is the best, or is there any other tools/programs, which can fix distortions too.
                              your valuable tips are very appreciated πŸ‘
                              • thomthomT
                                Aye - that is what I do. Some times I increase the size of Outlines in Edge Styles as the edge thickness doesn't scale up with the size of the export. An alternative is using Layout - let you export with nice AA, edge size scale, transparent background and you can even export as vector.
                                • tibetT
                                  tibet
                                  hi,
                                  a prety fast help, thanks, the tut is great !
                                  i´m very thankful, i´ve spent many valuable moments here with you guys 😍
                                  so, when i return to previous topic, the best think is to change resolution of size of the model, then reduce it in PS.
                                  wonderful !
                                  http://i.imgur.com/u5RLds.jpg
                                  • tibetT
                                    tibet
                                    good job, well done !
                                    hope to be a good source of wisdom like you someday πŸ˜„
                                    interesting info about panorama makers:
                                    http://www.stockholmviews.com/gigapan-review/gigapan7.html
                                    http://www.qcas.net.au/images/Graphics GIF/Blue Prize Ribbon.gif
                                    • pbacotP
                                      Thothom, if you please, what is meaning of the acronym "AA"?
                                      • GaieusG
                                        Anti Aliasing. The rest you probably know but here it is for those new to SU.
                                        Can be set at system preferences level - in this case it only affects what is rendered on the screen.
                                        And can be set when exporting stills and animations - this time it is done by the software (SU) but that is not a nice job (here they could improve a lot)
                                        • pbacotP
                                          😳 of course!
                                          • GaieusG
                                            I told you knew! πŸ˜„
