    Save model in PNG without background . anyone?
    20 Posts 4 Posters 3.8k Views 4 Watching
      Yes I have - it's even in the screenshots of the post - using the default grey background of SU's architecture template.
      • GaieusG
        Okay, you may be right, I could only find the sky and background issue in the topic (I was the one with problems).
          For that model you could use QuadFace Tools to UV map the surface: http://forums.sketchucation.com/viewtopic.php?f=323&t=39442&hilit=+quadface#p348501
          • tibetT
            tibet
            hi,
            a pretty fast answer, thank you!
            The more i learn, the more i realize how little i know in difference from you guys πŸ˜„
            best of luck !
            http://i52.tinypic.com/zujcp1.jpg
            SU 2015 Pro on Win10 x64
            • tibetT
              tibet
              hi,
              thanks for your tips, so what are the final tricks?
              a smart plugin solves everything ?
              wow, thatΒ΄s pretty cool !
              additional question about adding texture to faces
              round one http://www.youtube.com/watch?v=AVYYdWYRqrg
              flat surface http://www.youtube.com/watch?v=KEg6tHWNXb4&feature=relmfu
              to move texture on flat surface is easy, but what about round one 😞
              i need to move a bit replace my texture at the entrance of the building / see picture
              thanks!
              http://i.imgur.com/9wFoN.jpg
              • tibetT
                tibet
                hi,
                the plugin works like a charm, but my model is a bit "hairy" πŸ˜„
                is there any setting how to convert model into higher resolution of PNG, to reduce raster to minimum please?
                thank you!
                http://i.imgur.com/mmM1Ol.jpg
                  You have the same settings as when you export normally, Width, Height and Anti-aliasing - adjust to your requirement.
                  I never use SketchUp's AA when exporting - instead I export the image out much larger and scale down in Photoshop which then produce nice smooth edges.
                    Haven't used other applications. Either I do it by hand, or I use the panorama function in PhotoShop. http://tv.adobe.com/watch/learn-photoshop-cs5/creating-a-panorama/
                    • tibetT
                      tibet
                      hi,
                      youΒ΄re right. to export bigger model, then resize in PS, but when i need transparent backgroung?
                      do you thing PS fix everything?
                      thanks!
                      note: just making a texture of bulding (another project) photos were made from many places around.
                      when i need to make panorama pic to wrap the model, iΒ΄ve to fix/strech photos for nice result.
                      do you think PS is the best, or is there any other tools/programs, which can fix distortions too.
                      your valuable tips are very appreciated πŸ‘
                        Aye - that is what I do. Some times I increase the size of Outlines in Edge Styles as the edge thickness doesn't scale up with the size of the export. An alternative is using Layout - let you export with nice AA, edge size scale, transparent background and you can even export as vector.
                        • tibetT
                          tibet
                          hi,
                          a prety fast help, thanks, the tut is great !
                          i´m very thankful, i´ve spent many valuable moments here with you guys 😍
                          so, when i return to previous topic, the best think is to change resolution of size of the model, then reduce it in PS.
                          wonderful !
                          http://i.imgur.com/u5RLds.jpg
                          • tibetT
                            tibet
                            good job, well done !
                            hope to be a good source of wisdom like you someday πŸ˜„
                            interesting info about panorama makers:
                            404 Not Found
                            (www.stockholmviews.com)
                            http://www.qcas.net.au/images/Graphics GIF/Blue Prize Ribbon.gif
                            • pbacotP
                              Thothom, if you please, what is meaning of the acronym "AA"?
                              • GaieusG
                                Anti Aliasing. The rest you probably know but here it is for those new to SU.
                                Can be set at system preferences level - in this case it only affects what is rendered on the screen.
                                And can be set when exporting stills and animations - this time it is done by the software (SU) but that is not a nice job (here they could improve a lot)
                                • pbacotP
                                  😳 of course!
                                  • GaieusG
                                    I told you knew! πŸ˜„
