    Save model in PNG without background . anyone?
    20 Posts 4 Posters 3.8k Views 4 Watching
    • GaieusG
      That's what I remember. Hold on...
        Yes I have - it's even in the screenshots of the post - using the default grey background of SU's architecture template.
        • GaieusG
          Okay, you may be right, I could only find the sky and background issue in the topic (I was the one with problems).
            For that model you could use QuadFace Tools to UV map the surface: http://forums.sketchucation.com/viewtopic.php?f=323&t=39442&hilit=+quadface#p348501
            • tibetT
              tibet
              hi,
              a pretty fast answer, thank you!
              The more i learn, the more i realize how little i know in difference from you guys 😄
              best of luck !
              http://i52.tinypic.com/zujcp1.jpg
              SU 2015 Pro on Win10 x64
              • tibetT
                tibet
                hi,
                thanks for your tips, so what are the final tricks?
                a smart plugin solves everything ?
                wow, that´s pretty cool !
                additional question about adding texture to faces
                round one http://www.youtube.com/watch?v=AVYYdWYRqrg
                flat surface http://www.youtube.com/watch?v=KEg6tHWNXb4&feature=relmfu
                to move texture on flat surface is easy, but what about round one 😞
                i need to move a bit replace my texture at the entrance of the building / see picture
                thanks!
                http://i.imgur.com/9wFoN.jpg
                • tibetT
                  tibet
                  hi,
                  the plugin works like a charm, but my model is a bit "hairy" 😄
                  is there any setting how to convert model into higher resolution of PNG, to reduce raster to minimum please?
                  thank you!
                  http://i.imgur.com/mmM1Ol.jpg
                    You have the same settings as when you export normally, Width, Height and Anti-aliasing - adjust to your requirement.
                    I never use SketchUp's AA when exporting - instead I export the image out much larger and scale down in Photoshop which then produce nice smooth edges.
                      Haven't used other applications. Either I do it by hand, or I use the panorama function in PhotoShop. http://tv.adobe.com/watch/learn-photoshop-cs5/creating-a-panorama/
                      • tibetT
                        tibet
                        hi,
                        you´re right. to export bigger model, then resize in PS, but when i need transparent backgroung?
                        do you thing PS fix everything?
                        thanks!
                        note: just making a texture of bulding (another project) photos were made from many places around.
                        when i need to make panorama pic to wrap the model, i´ve to fix/strech photos for nice result.
                        do you think PS is the best, or is there any other tools/programs, which can fix distortions too.
                        your valuable tips are very appreciated 👍
                          Aye - that is what I do. Some times I increase the size of Outlines in Edge Styles as the edge thickness doesn't scale up with the size of the export. An alternative is using Layout - let you export with nice AA, edge size scale, transparent background and you can even export as vector.
                          • tibetT
                            tibet
                            hi,
                            a prety fast help, thanks, the tut is great !
                            i´m very thankful, i´ve spent many valuable moments here with you guys 😍
                            so, when i return to previous topic, the best think is to change resolution of size of the model, then reduce it in PS.
                            wonderful !
                            http://i.imgur.com/u5RLds.jpg
                            • tibetT
                              tibet
                              good job, well done !
                              hope to be a good source of wisdom like you someday 😄
                              interesting info about panorama makers:
                              404 Not Found
                              (www.stockholmviews.com)
                              http://www.qcas.net.au/images/Graphics GIF/Blue Prize Ribbon.gif
                              • pbacotP
                                Thothom, if you please, what is meaning of the acronym "AA"?
                                • GaieusG
                                  Anti Aliasing. The rest you probably know but here it is for those new to SU.
                                  Can be set at system preferences level - in this case it only affects what is rendered on the screen.
                                  And can be set when exporting stills and animations - this time it is done by the software (SU) but that is not a nice job (here they could improve a lot)
                                  • pbacotP
                                    😳 of course!
                                    • GaieusG
                                      I told you knew! 😄
