    Save model in PNG without background . anyone?
    20 Posts 4 Posters 3.8k Views 4 Watching
      You have the same settings as when you export normally, Width, Height and Anti-aliasing - adjust to your requirement.
      I never use SketchUp's AA when exporting - instead I export the image out much larger and scale down in Photoshop which then produce nice smooth edges.
        Haven't used other applications. Either I do it by hand, or I use the panorama function in PhotoShop. http://tv.adobe.com/watch/learn-photoshop-cs5/creating-a-panorama/
        • tibetT
          tibet
          hi,
          you´re right. to export bigger model, then resize in PS, but when i need transparent backgroung?
          do you thing PS fix everything?
          thanks!
          note: just making a texture of bulding (another project) photos were made from many places around.
          when i need to make panorama pic to wrap the model, i´ve to fix/strech photos for nice result.
          do you think PS is the best, or is there any other tools/programs, which can fix distortions too.
          your valuable tips are very appreciated 👍
          http://i52.tinypic.com/zujcp1.jpg
          SU 2015 Pro on Win10 x64
            Aye - that is what I do. Some times I increase the size of Outlines in Edge Styles as the edge thickness doesn't scale up with the size of the export. An alternative is using Layout - let you export with nice AA, edge size scale, transparent background and you can even export as vector.
            • tibetT
              tibet
              hi,
              a prety fast help, thanks, the tut is great !
              i´m very thankful, i´ve spent many valuable moments here with you guys 😍
              so, when i return to previous topic, the best think is to change resolution of size of the model, then reduce it in PS.
              wonderful !
              http://i.imgur.com/u5RLds.jpg
              • tibetT
                tibet
                good job, well done !
                hope to be a good source of wisdom like you someday 😄
                interesting info about panorama makers:
                404 Not Found
                (www.stockholmviews.com)
                http://www.qcas.net.au/images/Graphics GIF/Blue Prize Ribbon.gif
                • pbacotP
                  Thothom, if you please, what is meaning of the acronym "AA"?
                  • GaieusG
                    Anti Aliasing. The rest you probably know but here it is for those new to SU.
                    Can be set at system preferences level - in this case it only affects what is rendered on the screen.
                    And can be set when exporting stills and animations - this time it is done by the software (SU) but that is not a nice job (here they could improve a lot)
                    • pbacotP
                      😳 of course!
                      • GaieusG
                        I told you knew! 😄
