    Save model in PNG without background . anyone?
    20 Posts 4 Posters 3.9k Views 4 Watching
      For that model you could use QuadFace Tools to UV map the surface: http://forums.sketchucation.com/viewtopic.php?f=323&t=39442&hilit=+quadface#p348501
      • tibetT
        tibet
        hi,
        a pretty fast answer, thank you!
        The more i learn, the more i realize how little i know in difference from you guys 😄
        best of luck !
        http://i52.tinypic.com/zujcp1.jpg
        SU 2015 Pro on Win10 x64
        • tibetT
          tibet
          hi,
          thanks for your tips, so what are the final tricks?
          a smart plugin solves everything ?
          wow, that´s pretty cool !
          additional question about adding texture to faces
          round one http://www.youtube.com/watch?v=AVYYdWYRqrg
          flat surface http://www.youtube.com/watch?v=KEg6tHWNXb4&feature=relmfu
          to move texture on flat surface is easy, but what about round one 😞
          i need to move a bit replace my texture at the entrance of the building / see picture
          thanks!
          http://i.imgur.com/9wFoN.jpg
          • tibetT
            tibet
            hi,
            the plugin works like a charm, but my model is a bit "hairy" 😄
            is there any setting how to convert model into higher resolution of PNG, to reduce raster to minimum please?
            thank you!
            http://i.imgur.com/mmM1Ol.jpg
              You have the same settings as when you export normally, Width, Height and Anti-aliasing - adjust to your requirement.
              I never use SketchUp's AA when exporting - instead I export the image out much larger and scale down in Photoshop which then produce nice smooth edges.
                Haven't used other applications. Either I do it by hand, or I use the panorama function in PhotoShop. http://tv.adobe.com/watch/learn-photoshop-cs5/creating-a-panorama/
                • tibetT
                  tibet
                  hi,
                  you´re right. to export bigger model, then resize in PS, but when i need transparent backgroung?
                  do you thing PS fix everything?
                  thanks!
                  note: just making a texture of bulding (another project) photos were made from many places around.
                  when i need to make panorama pic to wrap the model, i´ve to fix/strech photos for nice result.
                  do you think PS is the best, or is there any other tools/programs, which can fix distortions too.
                  your valuable tips are very appreciated 👍
                    Aye - that is what I do. Some times I increase the size of Outlines in Edge Styles as the edge thickness doesn't scale up with the size of the export. An alternative is using Layout - let you export with nice AA, edge size scale, transparent background and you can even export as vector.
                    • tibetT
                      tibet
                      hi,
                      a prety fast help, thanks, the tut is great !
                      i´m very thankful, i´ve spent many valuable moments here with you guys 😍
                      so, when i return to previous topic, the best think is to change resolution of size of the model, then reduce it in PS.
                      wonderful !
                      http://i.imgur.com/u5RLds.jpg
                      • tibetT
                        tibet
                        good job, well done !
                        hope to be a good source of wisdom like you someday 😄
                        interesting info about panorama makers:
                        404 Not Found
                        (www.stockholmviews.com)
                        http://www.qcas.net.au/images/Graphics GIF/Blue Prize Ribbon.gif
                        • pbacotP
                          Thothom, if you please, what is meaning of the acronym "AA"?
                          • GaieusG
                            Anti Aliasing. The rest you probably know but here it is for those new to SU.
                            Can be set at system preferences level - in this case it only affects what is rendered on the screen.
                            And can be set when exporting stills and animations - this time it is done by the software (SU) but that is not a nice job (here they could improve a lot)
                            • pbacotP
                              😳 of course!
                              • GaieusG
                                I told you knew! 😄
