    Drawing Conundrums
    26 Posts 8 Posters 1.1k Views 8 Watching
    • Mike LuceyM Offline
      Mike Lucey
      Thought this may be some fun for anytime you may feel a little bored!
      Envelope Conondrum.skp
        Ah, we used to play that when I was a child. πŸ˜„
          Mike Lucey
          Csaba, you are still a child ... so continue playing πŸ˜„
          • Rich O BrienR Online
            Flame war
            • gillesG Offline
              gilles
              πŸ˜‰
                This one is slightly mored difficult.
                  Mike Lucey
                  That was fast Gilles πŸ‘
                  I can imagine some hair pulling going on in the background with TIG's envelopes πŸ˜„
                    TIG's is not possible if you want the fourth triangle, too. It is for the three of them.
                    • gillesG Offline
                      gilles
                      I'm stuck with the extra lap.I'll give it a try later.
                        I know it's not possible with 4 flaps !
                        You'll always have a line left over that requires a re-trace!
                        πŸ˜’
                        I was being cruel πŸ‘Ώ
                          Here's the "5 rooms puzzle"WallsLines.gif The object of the puzzle is to draw a continuous [flat 2d] line that intersects each "wall" of the diagram only once. WallsLines2.gif This example fails as the wall marked with the O is not intersected...
                          Officially it's "unsolvable"... but there is a tricky solution [that doesn't involve 3d or wormholes!]
                            Roger
                            Spelling Conondrum. 😎
                            http://www.azcreative.com
                              Mike Lucey
                              πŸ˜„ Cooldn't resist
                                Mike Lucey
                                Move just one matchstick to form a square!
                                Matches.skp
                                    Make four, equilateral triangles of these matches.
                                    4triangles.skp
                                      Mike Lucey
                                      I showed you that one when I was in Hungary πŸ˜’
                                        Nope. And anyway, how could you remember? πŸ˜’
                                        • boofredlayB Offline
                                          boofredlay
                                            πŸ‘
                                            After all, this is a 3D application forum! β˜€
                                            (The alignment could be nicer though... πŸ˜’ )
                                            • 1 / 2
