    Drawing Conundrums
    26 Posts 8 Posters 1.1k Views 8 Watching
      TIG's is not possible if you want the fourth triangle, too. It is for the three of them.
      • gillesG Offline
        gilles
        I'm stuck with the extra lap.I'll give it a try later.
        • TIGT Online
          I know it's not possible with 4 flaps !
          You'll always have a line left over that requires a re-trace!
          πŸ˜’
          I was being cruel πŸ‘Ώ
          • TIGT Online
            Here's the "5 rooms puzzle"WallsLines.gif The object of the puzzle is to draw a continuous [flat 2d] line that intersects each "wall" of the diagram only once. WallsLines2.gif This example fails as the wall marked with the O is not intersected...
            Officially it's "unsolvable"... but there is a tricky solution [that doesn't involve 3d or wormholes!]
              Roger
              Spelling Conondrum. 😎
              http://www.azcreative.com
              • Mike LuceyM Offline
                Mike Lucey
                πŸ˜„ Cooldn't resist
                  Mike Lucey
                  Move just one matchstick to form a square!
                  Matches.skp
                      Make four, equilateral triangles of these matches.
                      4triangles.skp
                        Mike Lucey
                        I showed you that one when I was in Hungary πŸ˜’
                          Nope. And anyway, how could you remember? πŸ˜’
                          • boofredlayB Offline
                            boofredlay
                              πŸ‘
                              After all, this is a 3D application forum! β˜€
                              (The alignment could be nicer though... πŸ˜’ )
                                boofredlay
                                I should have just burned them.
                                • TIGT Online
                                  It relies on the interpretation that you can intersect a line [wall] at its very end point, thereby allowing you to intersect three at once...
                                    Mike Lucey
                                    Mmmmmm ...... 'end point' πŸ˜‰
                                    • gillesG Offline
                                      gilles
                                      Un peu tirΓ© par les cheveux... πŸ‘Š
                                        boofredlay
                                        Ah, so the single line is allowed a thickness, nice.
                                        • david_hD Offline
                                          david_h
                                          I think the bigger conundrum to those rooms is how does one get in? πŸ’š
