    Drawing Conundrums
    26 Posts 8 Posters 2.0k Views 8 Watching
    • Mike LuceyM
      Mike Lucey
      Csaba, you are still a child ... so continue playing πŸ˜„
        Flame war
        • gillesG
          gilles
          πŸ˜‰
            This one is slightly mored difficult.
            • Mike LuceyM
              Mike Lucey
              That was fast Gilles πŸ‘
              I can imagine some hair pulling going on in the background with TIG's envelopes πŸ˜„
              • GaieusG
                TIG's is not possible if you want the fourth triangle, too. It is for the three of them.
                • gillesG
                  gilles
                  I'm stuck with the extra lap.I'll give it a try later.
                    I know it's not possible with 4 flaps !
                    You'll always have a line left over that requires a re-trace!
                    πŸ˜’
                    I was being cruel πŸ‘Ώ
                      Here's the "5 rooms puzzle"WallsLines.gif The object of the puzzle is to draw a continuous [flat 2d] line that intersects each "wall" of the diagram only once. WallsLines2.gif This example fails as the wall marked with the O is not intersected...
                      Officially it's "unsolvable"... but there is a tricky solution [that doesn't involve 3d or wormholes!]
                        Roger
                        Spelling Conondrum. 😎
                        http://www.azcreative.com
                        • Mike LuceyM
                          Mike Lucey
                          πŸ˜„ Cooldn't resist
                          • Mike LuceyM
                            Mike Lucey
                            Move just one matchstick to form a square!
                            Matches.skp
                            • GaieusG
                              • GaieusG
                                Make four, equilateral triangles of these matches.
                                4triangles.skp
                                • Mike LuceyM
                                  Mike Lucey
                                  I showed you that one when I was in Hungary πŸ˜’
                                  • GaieusG
                                    Nope. And anyway, how could you remember? πŸ˜’
                                    • boofredlayB
                                      boofredlay
                                      • GaieusG
                                        πŸ‘
                                        After all, this is a 3D application forum! β˜€
                                        (The alignment could be nicer though... πŸ˜’ )
                                        • boofredlayB
                                          boofredlay
                                          I should have just burned them.
                                            It relies on the interpretation that you can intersect a line [wall] at its very end point, thereby allowing you to intersect three at once...
