    Drawing Conundrums
    26 Posts 8 Posters 799 Views 8 Watching
      Here's the "5 rooms puzzle"WallsLines.gif The object of the puzzle is to draw a continuous [flat 2d] line that intersects each "wall" of the diagram only once. WallsLines2.gif This example fails as the wall marked with the O is not intersected...
      Officially it's "unsolvable"... but there is a tricky solution [that doesn't involve 3d or wormholes!]
        Roger
        Spelling Conondrum. 😎
        http://www.azcreative.com
        • Mike LuceyM Offline
          Mike Lucey
          πŸ˜„ Cooldn't resist
            Mike Lucey
            Move just one matchstick to form a square!
            Matches.skp
                Make four, equilateral triangles of these matches.
                4triangles.skp
                  Mike Lucey
                  I showed you that one when I was in Hungary πŸ˜’
                    Nope. And anyway, how could you remember? πŸ˜’
                    • boofredlayB Offline
                      boofredlay
                        πŸ‘
                        After all, this is a 3D application forum! β˜€
                        (The alignment could be nicer though... πŸ˜’ )
                          boofredlay
                          I should have just burned them.
                            It relies on the interpretation that you can intersect a line [wall] at its very end point, thereby allowing you to intersect three at once...
                              Mike Lucey
                              Mmmmmm ...... 'end point' πŸ˜‰
                              • gillesG Offline
                                gilles
                                Un peu tirΓ© par les cheveux... πŸ‘Š
                                  boofredlay
                                  Ah, so the single line is allowed a thickness, nice.
                                  • david_hD Offline
                                    david_h
                                    I think the bigger conundrum to those rooms is how does one get in? πŸ’š
