    Drawing Conundrums
    26 Posts 8 Posters 1.1k Views 8 Watching
      Ah, we used to play that when I was a child. πŸ˜„
      • Mike LuceyM Offline
        Mike Lucey
        Csaba, you are still a child ... so continue playing πŸ˜„
        • Rich O BrienR Online
          Flame war
          • gillesG Offline
            gilles
            πŸ˜‰
              This one is slightly mored difficult.
                Mike Lucey
                That was fast Gilles πŸ‘
                I can imagine some hair pulling going on in the background with TIG's envelopes πŸ˜„
                  TIG's is not possible if you want the fourth triangle, too. It is for the three of them.
                  • gillesG Offline
                    gilles
                    I'm stuck with the extra lap.I'll give it a try later.
                      I know it's not possible with 4 flaps !
                      You'll always have a line left over that requires a re-trace!
                      πŸ˜’
                      I was being cruel πŸ‘Ώ
                        Here's the "5 rooms puzzle"WallsLines.gif The object of the puzzle is to draw a continuous [flat 2d] line that intersects each "wall" of the diagram only once. WallsLines2.gif This example fails as the wall marked with the O is not intersected...
                        Officially it's "unsolvable"... but there is a tricky solution [that doesn't involve 3d or wormholes!]
                          Roger
                          Spelling Conondrum. 😎
                          http://www.azcreative.com
                            Mike Lucey
                            πŸ˜„ Cooldn't resist
                              Mike Lucey
                              Move just one matchstick to form a square!
                              Matches.skp
                                  Make four, equilateral triangles of these matches.
                                  4triangles.skp
                                    Mike Lucey
                                    I showed you that one when I was in Hungary πŸ˜’
                                      Nope. And anyway, how could you remember? πŸ˜’
                                      • boofredlayB Offline
                                        boofredlay
                                          πŸ‘
                                          After all, this is a 3D application forum! β˜€
                                          (The alignment could be nicer though... πŸ˜’ )
                                            boofredlay
                                            I should have just burned them.
