    Drawing Conundrums
    26 Posts 8 Posters 1.3k Views 8 Watching
    • gillesG Offline
      gilles
      πŸ˜‰
        This one is slightly mored difficult.
        • Mike LuceyM Offline
          Mike Lucey
          That was fast Gilles πŸ‘
          I can imagine some hair pulling going on in the background with TIG's envelopes πŸ˜„
            TIG's is not possible if you want the fourth triangle, too. It is for the three of them.
            • gillesG Offline
              gilles
              I'm stuck with the extra lap.I'll give it a try later.
                I know it's not possible with 4 flaps !
                You'll always have a line left over that requires a re-trace!
                πŸ˜’
                I was being cruel πŸ‘Ώ
                  Here's the "5 rooms puzzle"WallsLines.gif The object of the puzzle is to draw a continuous [flat 2d] line that intersects each "wall" of the diagram only once. WallsLines2.gif This example fails as the wall marked with the O is not intersected...
                  Officially it's "unsolvable"... but there is a tricky solution [that doesn't involve 3d or wormholes!]
                    Roger
                    Spelling Conondrum. 😎
                    http://www.azcreative.com
                      Mike Lucey
                      πŸ˜„ Cooldn't resist
                        Mike Lucey
                        Move just one matchstick to form a square!
                        Matches.skp
                            Make four, equilateral triangles of these matches.
                            4triangles.skp
                              Mike Lucey
                              I showed you that one when I was in Hungary πŸ˜’
                                Nope. And anyway, how could you remember? πŸ˜’
                                • boofredlayB Offline
                                  boofredlay
                                    πŸ‘
                                    After all, this is a 3D application forum! β˜€
                                    (The alignment could be nicer though... πŸ˜’ )
                                      boofredlay
                                      I should have just burned them.
                                        It relies on the interpretation that you can intersect a line [wall] at its very end point, thereby allowing you to intersect three at once...
                                          Mike Lucey
                                          Mmmmmm ...... 'end point' πŸ˜‰
                                          • gillesG Offline
                                            gilles
                                            Un peu tirΓ© par les cheveux... πŸ‘Š
