    [Plugin] SketchUpBIM: Building Modeling made easy!
    128 Posts 37 Posters 94.9k Views 37 Watching
      d_e_x
      Hi All,
      The appended blog talks about the common support issues related to the installation and first-use of SketchUpBIM.
      http://sketchupbim.blogspot.in/
      Hope it helps the community πŸ˜„
      Dex
      • brookefoxB Offline
        brookefox
        Thank you, d_e_x, for sharing this set of integrated tools.
        Any plans for wall intersection corner clean-up?
        ~ Brooke
        • E Offline
          eccowboy
          I tried downloading SUBim, but when I was done the plugin wasn't in my SU toolbar,
          I'm working in pro7, does this plugin only work with Pro8.
          Thanks....
            brookefox
            You checked the install and can verify that the plug and the folder are in the plug directory?
            ~ Brooke
              Assuming you do have the files/subfolder+files properly in Plugins [and not some 'compatibility files' location because you don't have 'full' properties>security-permissions to the destination folder]...
              then have you checked to see if it's an Extension that needs a one time activation from Menu > Window > Preferences > Extensions, and if so perhaps a one time activation of its Toolbar from Menu > View > Toolbars ?
              If none of this works... have you tried using the tool's own web site? where they have a support page and tutorial pages, or even try a PM to the author here...
                d_e_x
                Thanks....
                Eccowboy,
                SketchUpBIM works with SketchUp 7 and 8, both Free and Pro Versions.
                Please browse to "C:\Program Files (x86)\Google\Google SketchUp 7\Plugins"
                on your computer, and see if the following files exist inside this folder: (i) SketchUpBIM.rbs file (ii) SketchUpBIM sub-folder. If not, then please re-install the software using the installation file. If you still cannot see the SketchUpBIM files even after re-installation, then you might not have admin privileges to install softwares into your "Program Files" folder or you might have multiple versions of SketchUp installed on your computer. If this is the case, please send me an email at support@sketchupbim.com. I can send you a link to the zip package of the plug-in (otherwise discouraged to facilitate installation upgrades). The zip package can be easily un-zipped, and the files can be copied to the SketchUp plug-ins folder.
                  d_e_x
                  Hi Brookefox,
                  clean-up of wall corners, and other intersections has been requested by a number of users. it's on our list of things-to-do. Hopefully, we'll do so in one our future releases. I will notify as and when it is added to SketchUpBIM.
                  Dex
                  • E Offline
                    etong
                    Tried to make this plug-in work but I really can't.
                    I already reinstalled my SUPro 8.0.3117 to scratch, installed only SUBIM as plugin but still no luck.
                    Running in Win7 64bit.
                    I have SketchUpBIM.rbs and subfolder SketchUpBIM in my Plug-in Folder.
                    Also did Preferences/Extensions but didn't find any SketchUpBIM there... I only have: Ruby Script Examples, Ocean Modeling, Utilities Tools, Dynamic Components, Sandbox Tools, Solar North Toolbar, Photo Textures as choices.
                    I just dunno what else to do now.
                      @etong said:
                      SUPro 8.0.3117
                      I recommend you update to the latest service release of SU8 - got lots of bug fixes.
                      As for the plugin, can you post a screenshot of your plugin folder?
                      • E Offline
                        etong
                        @thomthom said:
                        @etong said:
                        SUPro 8.0.3117
                        Ok, already downloaded the latest SU. Unfortunately still the same issue.
                        Here's my Screenshot of my SU8 Plugins Folder
                        Folders:
                        Examples
                        Ocean
                        SketchUpBIM
                        SU_Podium_V2
                        Utilities
                        Ruby Scripts:
                        examples.rb
                        ocean_extension.rb
                        SketchUpBIM.rbs
                        SU_Podium_Browser.rbs
                        SU_Podium_V2.rbs
                        SU_Podium_V2_Render_All.rbs
                        utilities.rb
                        Didn't made a screenshot as there's only a few of ruby plug-ins as I am trying to eliminate the probable rb in conflict with SUBIM.
                        Thanks!
                        • micioneM Offline
                          micione
                          SketchupBIM not allow "LightUp" to work well. It seems that the conflict concerns the layers. Has anyone noticed this problem?
                          • PixeroP Offline
                            Pixero
                            Yes, this was the reason I uninstalled SketchUpBIM.
                            • micioneM Offline
                              micione
                              Thank you. I uninstalled. pity ...
                                d_e_x
                                Hi Micione, Pixero,
                                LightUp / SketchUpBIM conflict has been reported by some other users as well. We will investigate this issue, and get in touch with the LightUp team to fix this issue. Apologies for the inconvenience. We'll have this fixed in the upcoming release.
                                Dex
                                • E Offline
                                  etong
                                  @etong said:
                                  @thomthom said:
                                  @etong said:
                                  SUPro 8.0.3117
                                  Folders:
                                  Examples
                                  Ocean
                                  SketchUpBIM
                                  SU_Podium_V2
                                  Utilities
                                  Ruby Scripts:
                                  examples.rb
                                  ocean_extension.rb
                                  SketchUpBIM.rbs
                                  SU_Podium_V2.rbs
                                  utilities.rb
                                  Thanks!
                                  Still not working for me 😞.
                                  • IneshtineI Offline
                                    Ineshtine
                                    Dex
                                    The problem is usually with your global variables. If you use $pluginDir = "c:/BIM" and another plugin uses $pluginDir = "c:/Other" then the last one who load will change the variable $pluginDir in all loaded plugins. So make sure you name your global variables accordingly. For example, use $bim_pluginDir instead of $pluginDir
                                    What? you haven't tried Raylectron yet?
                                      No - the best thing is to not use global variables! Ever! Play nice with the environment your plugin live in and wrap everything in your own unique namespace module. No global variables and no global methods or constants that gets added to the Object class and inherited throughout every other class.
                                      I wrote down some guidelines for avoiding clashes with other plugins etc: http://www.thomthom.net/thoughts/2012/01/golden-rules-of-sketchup-plugin-development/
                                        Ineshtine
                                        TT, I was pointing out the possible problem and a simple fix using search/replace rather then changing the whole code!
                                          It appear that this plugin doesn't work that well when installed to a location to anything other than the Plugins folder. Toolbar icons, webdialogs.
                                          Usually when I see this behaviour it's because the plugin uses Sketchup.find_support_file to build the paths to the resources. A better practice is to build the path relative to the file itself, using __FILE__. I see all the files are rbs files - where __FILE__ will not work. But You can instead create an unscrambled loader which stores the path it's installed to for later use by the scrambled files. That way users can install the plugin to any location.
                                          The reason people install to other locations is that they want to share plugins between SketchUp versions or computer. It's become popular to install plugins to a shared Dropbox folder. That's why it's a good thing to write plugins that work from any location.
                                          • P Offline
                                            Phil Rader AIA
                                            I notice an odd behavior when I have SketchupBIM installed.
                                            IF I activate layer 0 in the layers dialog all layers are turned on, The camera view is changed to Isometric, and The camera is zoomed to extents:
                                            see this video:
                                            404 Not Found
                                            (www.nvizeon.com)
                                            This behavior only happens when SketchupBIM is installed.
                                            Is this a know bug or is this a "feature" built-into the plugin?
                                            http://www.philrader.com
                                            • 6
                                            • 7
                                            • 6 / 7
