    [Plugin] SketchUpBIM: Building Modeling made easy!
    128 Posts 37 Posters 109.9k Views 37 Watching
      @d_e_x said:
      TIG, Thomthom, could you confirm if there are any problems?
      I haven't used SketchUpBIM myself yet. Just noticed the query from the user when I moderated the post.
      Does it extend of modify the core classes that comes with SketchUp? (I've written some notes on why this is unsafe: http://www.thomthom.net/thoughts/2012/01/golden-rules-of-sketchup-plugin-development/ )
      Does it make use of Observers? (I've tried to map out bugs and quirks with observers here: http://www.thomthom.net/software/sketchup/observers/)
      If it does make use of observers, what does it do? Does it just monitor, or does it attempt to make changes to the model? The Google developers has mentioned that modifying the model on observer events can very likely cause unforeseen issues.
        SUFractal
        @d_e_x said:
        SketchUpBIM, Instant Roof, and SectionCutFace put together - are working fine. I did not notice any crashes or any other issues. I have tested this on Windows 7, 64 Bits. Next, I am going to try this on the Mac. At this point, NO ISSUES HAVE BEEN FOUND.
        In the attached screen-shot, SketchUpBIM elements (columns, walls etc.) are working fine with a "Barn Gambrel" roof from Chuck Vali's Instant Roof and a cyan colored section cut from TIG's 'SectionCutFace'.
        [attachment=0:r3r61rfx]<!-- ia0 -->SBIM_SectionCut_InstantRoof.png<!-- ia0 -->[/attachment:r3r61rfx]
        Also, the SketchUpBIM plugin has been tested with SuPodium, and Ledas Driving Dimensions, and no issues have been found. If there is anything, then it might be platform specific; or is related to other softwares and/or privileges on some specific computers. (random hunch!)
        d_e_x:
        TIG and TT suggested that I try upgrading to a newer version of SU (Version 8.0.11751) ... which I have done. That seems to solve the problem with the other plugins. πŸ˜„
        I'm embarrassed that I didn't think to check that first.
        Keep up the good work ... looking forward to using your great tool again.
        • P
          pjdorger
          wow looks awesome
            d_e_x
            Hi All,
            The appended blog talks about the common support issues related to the installation and first-use of SketchUpBIM.
            http://sketchupbim.blogspot.in/
            Hope it helps the community πŸ˜„
            Dex
            • brookefoxB
              brookefox
              Thank you, d_e_x, for sharing this set of integrated tools.
              Any plans for wall intersection corner clean-up?
              ~ Brooke
              • E
                eccowboy
                I tried downloading SUBim, but when I was done the plugin wasn't in my SU toolbar,
                I'm working in pro7, does this plugin only work with Pro8.
                Thanks....
                • brookefoxB
                  brookefox
                  You checked the install and can verify that the plug and the folder are in the plug directory?
                  ~ Brooke
                    Assuming you do have the files/subfolder+files properly in Plugins [and not some 'compatibility files' location because you don't have 'full' properties>security-permissions to the destination folder]...
                    then have you checked to see if it's an Extension that needs a one time activation from Menu > Window > Preferences > Extensions, and if so perhaps a one time activation of its Toolbar from Menu > View > Toolbars ?
                    If none of this works... have you tried using the tool's own web site? where they have a support page and tutorial pages, or even try a PM to the author here...
                      d_e_x
                      Thanks....
                      Eccowboy,
                      SketchUpBIM works with SketchUp 7 and 8, both Free and Pro Versions.
                      Please browse to "C:\Program Files (x86)\Google\Google SketchUp 7\Plugins"
                      on your computer, and see if the following files exist inside this folder: (i) SketchUpBIM.rbs file (ii) SketchUpBIM sub-folder. If not, then please re-install the software using the installation file. If you still cannot see the SketchUpBIM files even after re-installation, then you might not have admin privileges to install softwares into your "Program Files" folder or you might have multiple versions of SketchUp installed on your computer. If this is the case, please send me an email at support@sketchupbim.com. I can send you a link to the zip package of the plug-in (otherwise discouraged to facilitate installation upgrades). The zip package can be easily un-zipped, and the files can be copied to the SketchUp plug-ins folder.
                        d_e_x
                        Hi Brookefox,
                        clean-up of wall corners, and other intersections has been requested by a number of users. it's on our list of things-to-do. Hopefully, we'll do so in one our future releases. I will notify as and when it is added to SketchUpBIM.
                        Dex
                        • E
                          etong
                          Tried to make this plug-in work but I really can't.
                          I already reinstalled my SUPro 8.0.3117 to scratch, installed only SUBIM as plugin but still no luck.
                          Running in Win7 64bit.
                          I have SketchUpBIM.rbs and subfolder SketchUpBIM in my Plug-in Folder.
                          Also did Preferences/Extensions but didn't find any SketchUpBIM there... I only have: Ruby Script Examples, Ocean Modeling, Utilities Tools, Dynamic Components, Sandbox Tools, Solar North Toolbar, Photo Textures as choices.
                          I just dunno what else to do now.
                            @etong said:
                            SUPro 8.0.3117
                            I recommend you update to the latest service release of SU8 - got lots of bug fixes.
                            As for the plugin, can you post a screenshot of your plugin folder?
                            • E
                              etong
                              @thomthom said:
                              @etong said:
                              SUPro 8.0.3117
                              Ok, already downloaded the latest SU. Unfortunately still the same issue.
                              Here's my Screenshot of my SU8 Plugins Folder
                              Folders:
                              Examples
                              Ocean
                              SketchUpBIM
                              SU_Podium_V2
                              Utilities
                              Ruby Scripts:
                              examples.rb
                              ocean_extension.rb
                              SketchUpBIM.rbs
                              SU_Podium_Browser.rbs
                              SU_Podium_V2.rbs
                              SU_Podium_V2_Render_All.rbs
                              utilities.rb
                              Didn't made a screenshot as there's only a few of ruby plug-ins as I am trying to eliminate the probable rb in conflict with SUBIM.
                              • micioneM
                                micione
                                SketchupBIM not allow "LightUp" to work well. It seems that the conflict concerns the layers. Has anyone noticed this problem?
                                • PixeroP
                                  Pixero
                                  Yes, this was the reason I uninstalled SketchUpBIM.
                                  • micioneM
                                    micione
                                    Thank you. I uninstalled. pity ...
                                      d_e_x
                                      Hi Micione, Pixero,
                                      LightUp / SketchUpBIM conflict has been reported by some other users as well. We will investigate this issue, and get in touch with the LightUp team to fix this issue. Apologies for the inconvenience. We'll have this fixed in the upcoming release.
                                      Dex
                                      • E
                                        etong
                                        @etong said:
                                        @thomthom said:
                                        @etong said:
                                        SUPro 8.0.3117
                                        Folders:
                                        Examples
                                        Ocean
                                        SketchUpBIM
                                        SU_Podium_V2
                                        Utilities
                                        Ruby Scripts:
                                        examples.rb
                                        ocean_extension.rb
                                        SketchUpBIM.rbs
                                        SU_Podium_V2.rbs
                                        utilities.rb
                                        Still not working for me 😞.
                                        • IneshtineI
                                          Ineshtine
                                          Dex
                                          The problem is usually with your global variables. If you use $pluginDir = "c:/BIM" and another plugin uses $pluginDir = "c:/Other" then the last one who load will change the variable $pluginDir in all loaded plugins. So make sure you name your global variables accordingly. For example, use $bim_pluginDir instead of $pluginDir
                                          What? you haven't tried Raylectron yet?
                                            No - the best thing is to not use global variables! Ever! Play nice with the environment your plugin live in and wrap everything in your own unique namespace module. No global variables and no global methods or constants that gets added to the Object class and inherited throughout every other class.
                                            I wrote down some guidelines for avoiding clashes with other plugins etc: http://www.thomthom.net/thoughts/2012/01/golden-rules-of-sketchup-plugin-development/
                                            • 6 / 7
