    [Plugin] SketchUpBIM: Building Modeling made easy!
    128 Posts 37 Posters 105.9k Views 37 Watching
      SUFractal
      @d_e_x said:
      SketchUpBIM, Instant Roof, and SectionCutFace put together - are working fine. I did not notice any crashes or any other issues. I have tested this on Windows 7, 64 Bits. Next, I am going to try this on the Mac. At this point, NO ISSUES HAVE BEEN FOUND.
      In the attached screen-shot, SketchUpBIM elements (columns, walls etc.) are working fine with a "Barn Gambrel" roof from Chuck Vali's Instant Roof and a cyan colored section cut from TIG's 'SectionCutFace'.
      [attachment=0:r3r61rfx]<!-- ia0 -->SBIM_SectionCut_InstantRoof.png<!-- ia0 -->[/attachment:r3r61rfx]
      TIG, Thomthom, could you confirm if there are any problems?
      Also, the SketchUpBIM plugin has been tested with SuPodium, and Ledas Driving Dimensions, and no issues have been found. If there is anything, then it might be platform specific; or is related to other softwares and/or privileges on some specific computers. (random hunch!)
      d_e_x:
      TIG and TT suggested that I try upgrading to a newer version of SU (Version 8.0.11751) ... which I have done. That seems to solve the problem with the other plugins. πŸ˜„
      I'm embarrassed that I didn't think to check that first.
      Keep up the good work ... looking forward to using your great tool again.
        pjdorger
        wow looks awesome
          d_e_x
          Hi All,
          The appended blog talks about the common support issues related to the installation and first-use of SketchUpBIM.
          http://sketchupbim.blogspot.in/
          Hope it helps the community πŸ˜„
          Dex
          • brookefoxB Offline
            brookefox
            Thank you, d_e_x, for sharing this set of integrated tools.
            Any plans for wall intersection corner clean-up?
            ~ Brooke
            • E Offline
              eccowboy
              I tried downloading SUBim, but when I was done the plugin wasn't in my SU toolbar,
              I'm working in pro7, does this plugin only work with Pro8.
              Thanks....
                brookefox
                You checked the install and can verify that the plug and the folder are in the plug directory?
                ~ Brooke
                  Assuming you do have the files/subfolder+files properly in Plugins [and not some 'compatibility files' location because you don't have 'full' properties>security-permissions to the destination folder]...
                  then have you checked to see if it's an Extension that needs a one time activation from Menu > Window > Preferences > Extensions, and if so perhaps a one time activation of its Toolbar from Menu > View > Toolbars ?
                  If none of this works... have you tried using the tool's own web site? where they have a support page and tutorial pages, or even try a PM to the author here...
                    d_e_x
                    Thanks....
                    Eccowboy,
                    SketchUpBIM works with SketchUp 7 and 8, both Free and Pro Versions.
                    Please browse to "C:\Program Files (x86)\Google\Google SketchUp 7\Plugins"
                    on your computer, and see if the following files exist inside this folder: (i) SketchUpBIM.rbs file (ii) SketchUpBIM sub-folder. If not, then please re-install the software using the installation file. If you still cannot see the SketchUpBIM files even after re-installation, then you might not have admin privileges to install softwares into your "Program Files" folder or you might have multiple versions of SketchUp installed on your computer. If this is the case, please send me an email at support@sketchupbim.com. I can send you a link to the zip package of the plug-in (otherwise discouraged to facilitate installation upgrades). The zip package can be easily un-zipped, and the files can be copied to the SketchUp plug-ins folder.
                      d_e_x
                      Hi Brookefox,
                      clean-up of wall corners, and other intersections has been requested by a number of users. it's on our list of things-to-do. Hopefully, we'll do so in one our future releases. I will notify as and when it is added to SketchUpBIM.
                      Dex
                      • E Offline
                        etong
                        Tried to make this plug-in work but I really can't.
                        I already reinstalled my SUPro 8.0.3117 to scratch, installed only SUBIM as plugin but still no luck.
                        Running in Win7 64bit.
                        I have SketchUpBIM.rbs and subfolder SketchUpBIM in my Plug-in Folder.
                        Also did Preferences/Extensions but didn't find any SketchUpBIM there... I only have: Ruby Script Examples, Ocean Modeling, Utilities Tools, Dynamic Components, Sandbox Tools, Solar North Toolbar, Photo Textures as choices.
                        I just dunno what else to do now.
                          @etong said:
                          SUPro 8.0.3117
                          I recommend you update to the latest service release of SU8 - got lots of bug fixes.
                          As for the plugin, can you post a screenshot of your plugin folder?
                          • E Offline
                            etong
                            @thomthom said:
                            @etong said:
                            SUPro 8.0.3117
                            Ok, already downloaded the latest SU. Unfortunately still the same issue.
                            Here's my Screenshot of my SU8 Plugins Folder
                            Folders:
                            Examples
                            Ocean
                            SketchUpBIM
                            SU_Podium_V2
                            Utilities
                            Ruby Scripts:
                            examples.rb
                            ocean_extension.rb
                            SketchUpBIM.rbs
                            SU_Podium_Browser.rbs
                            SU_Podium_V2.rbs
                            SU_Podium_V2_Render_All.rbs
                            utilities.rb
                            Didn't made a screenshot as there's only a few of ruby plug-ins as I am trying to eliminate the probable rb in conflict with SUBIM.
                            • micioneM Offline
                              micione
                              SketchupBIM not allow "LightUp" to work well. It seems that the conflict concerns the layers. Has anyone noticed this problem?
                              • PixeroP Offline
                                Pixero
                                Yes, this was the reason I uninstalled SketchUpBIM.
                                • micioneM Offline
                                  micione
                                  Thank you. I uninstalled. pity ...
                                    d_e_x
                                    Hi Micione, Pixero,
                                    LightUp / SketchUpBIM conflict has been reported by some other users as well. We will investigate this issue, and get in touch with the LightUp team to fix this issue. Apologies for the inconvenience. We'll have this fixed in the upcoming release.
                                    Dex
                                    • E Offline
                                      etong
                                      @etong said:
                                      @thomthom said:
                                      @etong said:
                                      SUPro 8.0.3117
                                      Folders:
                                      Examples
                                      Ocean
                                      SketchUpBIM
                                      SU_Podium_V2
                                      Utilities
                                      Ruby Scripts:
                                      examples.rb
                                      ocean_extension.rb
                                      SketchUpBIM.rbs
                                      SU_Podium_V2.rbs
                                      utilities.rb
                                      Still not working for me 😞.
                                      • IneshtineI Offline
                                        Ineshtine
                                        Dex
                                        The problem is usually with your global variables. If you use $pluginDir = "c:/BIM" and another plugin uses $pluginDir = "c:/Other" then the last one who load will change the variable $pluginDir in all loaded plugins. So make sure you name your global variables accordingly. For example, use $bim_pluginDir instead of $pluginDir
                                        What? you haven't tried Raylectron yet?
                                          No - the best thing is to not use global variables! Ever! Play nice with the environment your plugin live in and wrap everything in your own unique namespace module. No global variables and no global methods or constants that gets added to the Object class and inherited throughout every other class.
                                          I wrote down some guidelines for avoiding clashes with other plugins etc: http://www.thomthom.net/thoughts/2012/01/golden-rules-of-sketchup-plugin-development/
                                            Ineshtine
                                            TT, I was pointing out the possible problem and a simple fix using search/replace rather then changing the whole code!
                                            • 6 / 7
