    [Plugin] SketchUpBIM: Building Modeling made easy!
    128 Posts 37 Posters 105.9k Views 37 Watching
    • brookefoxB Offline
      brookefox
      You checked the install and can verify that the plug and the folder are in the plug directory?
      ~ Brooke
        Assuming you do have the files/subfolder+files properly in Plugins [and not some 'compatibility files' location because you don't have 'full' properties>security-permissions to the destination folder]...
        then have you checked to see if it's an Extension that needs a one time activation from Menu > Window > Preferences > Extensions, and if so perhaps a one time activation of its Toolbar from Menu > View > Toolbars ?
        If none of this works... have you tried using the tool's own web site? where they have a support page and tutorial pages, or even try a PM to the author here...
          d_e_x
          @eccowboy said:
          I tried downloading SUBim, but when I was done the plugin wasn't in my SU toolbar,
          I'm working in pro7, does this plugin only work with Pro8.
          Thanks....
          Eccowboy,
          SketchUpBIM works with SketchUp 7 and 8, both Free and Pro Versions.
          Please browse to "C:\Program Files (x86)\Google\Google SketchUp 7\Plugins"
          on your computer, and see if the following files exist inside this folder: (i) SketchUpBIM.rbs file (ii) SketchUpBIM sub-folder. If not, then please re-install the software using the installation file. If you still cannot see the SketchUpBIM files even after re-installation, then you might not have admin privileges to install softwares into your "Program Files" folder or you might have multiple versions of SketchUp installed on your computer. If this is the case, please send me an email at support@sketchupbim.com. I can send you a link to the zip package of the plug-in (otherwise discouraged to facilitate installation upgrades). The zip package can be easily un-zipped, and the files can be copied to the SketchUp plug-ins folder.
            d_e_x
            @brookefox said:
            Thank you, d_e_x, for sharing this set of integrated tools.
            Any plans for wall intersection corner clean-up?
            Hi Brookefox,
            clean-up of wall corners, and other intersections has been requested by a number of users. it's on our list of things-to-do. Hopefully, we'll do so in one our future releases. I will notify as and when it is added to SketchUpBIM.
            Dex
            • E Offline
              etong
              Tried to make this plug-in work but I really can't.
              I already reinstalled my SUPro 8.0.3117 to scratch, installed only SUBIM as plugin but still no luck.
              Running in Win7 64bit.
              I have SketchUpBIM.rbs and subfolder SketchUpBIM in my Plug-in Folder.
              Also did Preferences/Extensions but didn't find any SketchUpBIM there... I only have: Ruby Script Examples, Ocean Modeling, Utilities Tools, Dynamic Components, Sandbox Tools, Solar North Toolbar, Photo Textures as choices.
              I just dunno what else to do now.
                @etong said:
                SUPro 8.0.3117
                I recommend you update to the latest service release of SU8 - got lots of bug fixes.
                As for the plugin, can you post a screenshot of your plugin folder?
                • E Offline
                  etong
                  @thomthom said:
                  @etong said:
                  SUPro 8.0.3117
                  Ok, already downloaded the latest SU. Unfortunately still the same issue.
                  Here's my Screenshot of my SU8 Plugins Folder
                  Folders:
                  Examples
                  Ocean
                  SketchUpBIM
                  SU_Podium_V2
                  Utilities
                  Ruby Scripts:
                  examples.rb
                  ocean_extension.rb
                  SketchUpBIM.rbs
                  SU_Podium_Browser.rbs
                  SU_Podium_V2.rbs
                  SU_Podium_V2_Render_All.rbs
                  utilities.rb
                  Didn't made a screenshot as there's only a few of ruby plug-ins as I am trying to eliminate the probable rb in conflict with SUBIM.
                  • micioneM Offline
                    micione
                    SketchupBIM not allow "LightUp" to work well. It seems that the conflict concerns the layers. Has anyone noticed this problem?
                    • PixeroP Offline
                      Pixero
                      Yes, this was the reason I uninstalled SketchUpBIM.
                      • micioneM Offline
                        micione
                        Thank you. I uninstalled. pity ...
                          d_e_x
                          Hi Micione, Pixero,
                          LightUp / SketchUpBIM conflict has been reported by some other users as well. We will investigate this issue, and get in touch with the LightUp team to fix this issue. Apologies for the inconvenience. We'll have this fixed in the upcoming release.
                          Dex
                          • E Offline
                            etong
                            @etong said:
                            @thomthom said:
                            @etong said:
                            SUPro 8.0.3117
                            Folders:
                            Examples
                            Ocean
                            SketchUpBIM
                            SU_Podium_V2
                            Utilities
                            Ruby Scripts:
                            examples.rb
                            ocean_extension.rb
                            SketchUpBIM.rbs
                            SU_Podium_V2.rbs
                            utilities.rb
                            Still not working for me 😞.
                            • IneshtineI Offline
                              Ineshtine
                              Dex
                              The problem is usually with your global variables. If you use $pluginDir = "c:/BIM" and another plugin uses $pluginDir = "c:/Other" then the last one who load will change the variable $pluginDir in all loaded plugins. So make sure you name your global variables accordingly. For example, use $bim_pluginDir instead of $pluginDir
                              What? you haven't tried Raylectron yet?
                                No - the best thing is to not use global variables! Ever! Play nice with the environment your plugin live in and wrap everything in your own unique namespace module. No global variables and no global methods or constants that gets added to the Object class and inherited throughout every other class.
                                I wrote down some guidelines for avoiding clashes with other plugins etc: http://www.thomthom.net/thoughts/2012/01/golden-rules-of-sketchup-plugin-development/
                                  Ineshtine
                                  TT, I was pointing out the possible problem and a simple fix using search/replace rather then changing the whole code!
                                    It appear that this plugin doesn't work that well when installed to a location to anything other than the Plugins folder. Toolbar icons, webdialogs.
                                    Usually when I see this behaviour it's because the plugin uses Sketchup.find_support_file to build the paths to the resources. A better practice is to build the path relative to the file itself, using __FILE__. I see all the files are rbs files - where __FILE__ will not work. But You can instead create an unscrambled loader which stores the path it's installed to for later use by the scrambled files. That way users can install the plugin to any location.
                                    The reason people install to other locations is that they want to share plugins between SketchUp versions or computer. It's become popular to install plugins to a shared Dropbox folder. That's why it's a good thing to write plugins that work from any location.
                                      Phil Rader AIA
                                      I notice an odd behavior when I have SketchupBIM installed.
                                      IF I activate layer 0 in the layers dialog all layers are turned on, The camera view is changed to Isometric, and The camera is zoomed to extents:
                                      see this video:
                                      404 Not Found
                                      (www.nvizeon.com)
                                      This behavior only happens when SketchupBIM is installed.
                                      Is this a know bug or is this a "feature" built-into the plugin?
                                      http://www.philrader.com
                                        Phil Rader AIA
                                        I have disabled this plugin as it is too invasive of the user interface. It forced a zoom extents and isometric view and all layers on when a file is opened instead of opening the file to the last saved view.
                                        I'll try it out again though as it definitely has potential to be very useful.
                                          RICALBUR
                                          Thank you, I will try it
                                          • EdsonE Offline
                                            Edson
                                            I am not sure the points I am about to make have not been made before. in that case, I apologize for the repetition. here they go.
                                            1. one of the first lessons one learns about good modeling practices is: keep layer 0 the active layer ALWAYS. SketchupBIM puts not only all entities modeled on a given elevation on a specific named layer – which is good – but also puts all the geometry (edges and faces) in that layer.
                                            2. all the elements created are solid groups – again initially a good thing – but if one needs to create 20 columns SketchupBIM creates 20 groups whereas any good modeling practice would indicate those columns were components, for obvious reasons.
                                            3. the tool forces one to model everything from a center line alignment. I, for one, would welcome the possibility of choosing the alignment that suits me best.
                                            4. wall segments always overlap. an autoclean feature would be very nice.
                                            5. why can't a new segment wall start from a corner or from the surface of a wall? they tend to all grab the center line of the wall.
                                            6. pardon me, but the standard way to view the model is awful. one of the great things about designing in 3D is to be able to simulate what the object will be like when viewed in real life. what is the point in viewing the model in a distorted way in which what is far away looks bigger than what is close to you? I really do not care for the fact that it replicates some engineering apps. who is this tool meant for? the developers should be clear about that.
                                            all in all, a promising tool but still needs to have more built-in flexibility. as it is it tends to force one to work in a specific way and not a better one.
                                            http://www.mahfuz.arq.br
                                            • 6 / 7
