    Add vertex on curve at length - or edge on surface at length
    25 Posts 7 Posters 5.6k Views 7 Watching
    • thomthomT
      Is there any plugins out there that will:
      Insert a vertex at a given length on a curve? ( Not like Fredo's Polyline divider, because it changed the curve segments - but just so it inserts a vertex.)
      Or even better, given an extruded surface, a vertical line is inserted at a given interval along the surface?
      I've lost track of what all the plugins do... 😒
      • mitcorbM
        mitcorb
        Evidently, Divide is not what you are looking for? And Polyline Segmentor?
        • thomthomT
          No, divide only divides a single element into a given set of segments - so does Segmentor. Segmentor also reshapes the curve, like Polyline Divider does. I just want to insert vertices on the existing curve.
          • mitcorbM
            mitcorb
            For Divide on an arc or edge, select, right click Entity Info. You want one more vertex than the display, for instance. Divide by desired number.
            EDIT: Well, if the arc is an edge of a model (closed volume), I see that Divide is not available. But a straight edge is eligible to be divided on the same volume.
            EDIT EDIT: Maybe I should read your post more carefully 😳
            • mitcorbM
              mitcorb
              Ok, See my EDIT, EDIT, EDIT (is there an echo in here?)
              • mitcorbM
                mitcorb
                Ok so when can we expect this wonderful plugin from you? 💚
                • TIGT
                  Not that I know of...
                  However, it's not so difficult.
                  You know the start and end edges of the curve - we remember these.
                  Iterate along the curve's edges from the start one until the accumulated_length of them is beyond the distance you want, then use the last considered segment_edge and 'split' it at the required offset d = distance-accumulated_length-edge.length
                  [You need to trap for a distance that exceeds the curve's length etc,
                  Also if you want to split an Arc at a known distance around the circumference (rather than along the segmented 'polygonal' representation of the Arc) you need to do some Math to sweep the start.position.clone new_point through that distance around the true circumference, and then project the center point along the vector to that new_point offset by the radius, you get the intersection of the two 'lines' and then split the affected Arc-segment there, then you move this newly added vertex to its correct location on the true circumference at new_point; reforming the Curve if desired - but then it's no longer an Arc.
                  You could also toggle the curve's start/end as desired]
                  You know the new_segment returned from the 'split'.
                  Your original curve is now split into two with the new_segment added between them.
                  Get the original curve belonging to the original curve's start_edge, and get its vertices, 'vss'.
                  Get the vertices of the new_segment, 'vsn'.
                  Get the new curve belonging to the original curve's end_edge, and get its vertices, 'vse'.
                  Then verts=(vss+vsn+vse).flatten.uniq
                  The add group=new_segment.parent.entities.add_group() group.entities.add_curve(verts) group.explode
                  which should now reform the curve back as one piece with the extra segment/vertex added in ?
                  • thomthomT
                    I was hoping I wouldn't need to...
                    • JClementsJ
                      JClements
                      Thom,
                      For what it is worth, I have had situations where I had needed such a script (or one that places construction points along a curve at equal intervals).
                        There is a plugin that places cpoints along a path. But i can't think of it.
                        • jeff hammondJ
                          jeff hammond
                          maybe you're thinking of 1001bit's divide along edges?
                          that's what i use when i need to do what TT is asking for (not the surface thing.. rather inserting a vertex along an arc)
                          you can set it up to where it starts from one end of the curve then places a cpoint at a given distance (though it will keep repeating that distance til it runs out of curve so you may end up with a few extra cpoints)..
                          you then have to go in and manually modify the vertex.. a bit of a pain but it's the easiest way i've found how to do it so far..
                          if it worked automagically then, well, that'd be sweet! 😄
                          [edit] example of using said plugin.. i actually use it for something a little different than shown here but this version will keep it simple 😄
                          divide_curve.skp
                          dotdotdot
                          • sdmitchS
                            sdmitch
                            ThomThom,
                            The attached plugin will add a vertex at a given interval along a selected curve.
                            Add vertices to curve at given interval
                            AddPts2Curve demo
                            http://sdmitch.blogspot.com/
                              @Sam
                              You should give this it's own thread. It's a great tool 👍
                              Thank You
                              • JClementsJ
                                JClements
                                Very nice. Thank you.
                                Could a similar script add points at Equal Intervals? Perhaps leave the points selected or grouped after being created?
                                • TIGT
                                  You can make a list of the new_vertices and then move the old_vertices to their locations [vector_from old_to_new?], using a transform_by_vectors on the new_vertices...
                                  PS: Glad someone can understand what I'm a saying... 😉
                                  • sdmitchS
                                    sdmitch
                                    It could select and/or group the construction points but not the individual vertices added to the curve.
                                    thomthom, what kind of "extruded surface" are we talking about? Curved or straight?
                                    • JClementsJ
                                      JClements
                                      I had in mind the construction points; the user would input how many equal intervals, contruction points would be placed and then grouped.
                                      • jeff hammondJ
                                        jeff hammond
                                        @sdmitch said:
                                        ThomThom,
                                        hmm.. i don't think that's quite right. (or at least what i'm talking about.. maybe i'm mis-understanding TT's question ?)
                                        it's just placing a point along the curve but it's not actual moving the vertex into it's proper place..
                                        as an exaggeration, here's a picture showing an arc with 3 segments.. then it shows how it should look after running the script..
                                        click pic for bigger
                                        [EDiT].. well, i reread thomas' original post and i think i'm misunderstanding him 😳
                                        it looks as if the script you (sam) wrote is what he's looking for
                                        dotdotdot
                                        • sdmitchS
                                          sdmitch
                                          Jeff, You are right regarding the arc, the point added is on the existing segment.
                                          • thomthomT
                                            You understood me correctly. 😄
                                            An extruded surface from the 2D profile of a curve. It's the shape of a building constant of several curves.
                                            • 1 / 2
