    Add vertex on curve at length - or edge on surface at length
    25 Posts 7 Posters 5.6k Views 7 Watching
    • jeff hammondJ
      There is a plugin that places cpoints along a path. But i can't think of it.
      maybe you're thinking of 1001bit's divide along edges?
      that's what i use when i need to do what TT is asking for (not the surface thing.. rather inserting a vertex along an arc)
      you can set it up to where it starts from one end of the curve then places a cpoint at a given distance (though it will keep repeating that distance til it runs out of curve so you may end up with a few extra cpoints)..
      you then have to go in and manually modify the vertex.. a bit of a pain but it's the easiest way i've found how to do it so far..
      if it worked automagically then, well, that'd be sweet! πŸ˜„
      [edit] example of using said plugin.. i actually use it for something a little different than shown here but this version will keep it simple πŸ˜„
      divide_curve.skp
      • sdmitchS
        sdmitch
        ThomThom,
        The attached plugin will add a vertex at a given interval along a selected curve.
        Add vertices to curve at given interval
        AddPts2Curve demo
        http://sdmitch.blogspot.com/
          @Sam
          You should give this it's own thread. It's a great tool πŸ‘
          Thank You
          • JClementsJ
            JClements
            Very nice. Thank you.
            Could a similar script add points at Equal Intervals? Perhaps leave the points selected or grouped after being created?
              You can make a list of the new_vertices and then move the old_vertices to their locations [vector_from old_to_new?], using a transform_by_vectors on the new_vertices...
              PS: Glad someone can understand what I'm a saying... πŸ˜‰
              • sdmitchS
                sdmitch
                It could select and/or group the construction points but not the individual vertices added to the curve.
                thomthom, what kind of "extruded surface" are we talking about? Curved or straight?
                • JClementsJ
                  JClements
                  I had in mind the construction points; the user would input how many equal intervals, contruction points would be placed and then grouped.
                  • jeff hammondJ
                    @sdmitch said:
                    ThomThom,
                    hmm.. i don't think that's quite right. (or at least what i'm talking about.. maybe i'm mis-understanding TT's question ?)
                    it's just placing a point along the curve but it's not actual moving the vertex into it's proper place..
                    as an exaggeration, here's a picture showing an arc with 3 segments.. then it shows how it should look after running the script..
                    click pic for bigger
                    [EDiT].. well, i reread thomas' original post and i think i'm misunderstanding him 😳
                    it looks as if the script you (sam) wrote is what he's looking for
                    • sdmitchS
                      sdmitch
                      Jeff, You are right regarding the arc, the point added is on the existing segment.
                        You understood me correctly. πŸ˜„
                        An extruded surface from the 2D profile of a curve. It's the shape of a building constant of several curves.
                          But as I said in my diatribe... if it's a Arc you can do the Math to work out where the swept start-point will be to become the new point where the new vertex ought to be on the true circumference, so you add the new vertex on the segment as normal then apply an entities transformation on the new vertex to relocate it at that new point that lies on the circumference... The Arc will become a Curve...
                            Are we now talking about a new topic?
                            (Just trying to catch up to the post since last evening.)
                              No - same topic.
                              Adding a new vertex on a curve splits a segment.
                              If the curve is an Arc then we have been considering if the vertex should split a segment AND adjust the vertex so it is on the true circumference too...
                                I see. In terms of what I needed to, no adjustments can be done. But I can see the use of this option.
                                Just had to check if there was existing plugins I'd missed out of.
                                • sdmitchS
                                  sdmitch
                                  I have modified the plugin so that, if the the selected entity is an arc, the point is placed in its true position instead of on the segment as before.
                                  Should this be an option?
                                  Add points to curve
