    Exporting SU Shadow / Sun Settings into thea
    extensions
    19 Posts 8 Posters 2.1k Views 8 Watching
    • david_hD
      david_h
      I am doing a shadow study that I want to animate in Thea. I have exported the scenes but I am not sure how to get thea to recognize SU's sun settings to get the appropriate time of day and such. Doesn't the SU pluging do this for us?
      I am such a Thea Newbie so this is pretty basic to you guys I am sure. I tried looking on the Thea Forum, but I have a hard time there. .. I can't even see how to post a new question.
      thx,
      David
      • soloS
        solo
        What version of SU2Thea are you using?
        http://www.solos-art.com
        • david_hD
          david_h
          Thea 1.1.
          And when I say "using it". . .let's say I have it. I dont know how to use it yet πŸ’š
          • GaieusG
            That's the renderer version, Pete asked about the exporter version.
            I see however that Tomasz already answered (and disappointed) you in the Thea forums.
            • david_hD
              david_h
              See! that's how much I DON't Know about this stuff. Where would I look to see the "render version"?
              Yeah. . .tomasz was great. He didn't disappoint. At least it's a solution. I was just wondering if maybe Pete had some additional ideas or tricks.
              Thx,
              D
              • GaieusG
                Well, you must have downloaded the exporter. The exe file says what the version number is (currently the latest is 0.89 I think).
                And of course, I meant the "disappointment" in a way that what you hoped to do is not currently possible.
                • david_hD
                  david_h
                  Oh I know. All you guys are great, and I really appreciate the help.
                  Anyway, Does SU and or Google provide the solar angle and Azimuth stuff that THEA uses? can i get that from the Google Locations that I put in the Model?
                  • N
                    notareal
                    If you know the location (latitude & longitude from GE/maps), date and time - that should be enough for Thea for correct Sun & Sky. The solar angle and Azimuth are just alternative way.
                    • david_hD
                      david_h
                      ****oh duh!****Yeah .. right under the Solar Azimuth tab crap . . .there's the location Tab Menu. okay. . . I'm slapping my head here!
                      Ouch. . .
                        • soloS
                          solo
                          Glad I could help... πŸ˜„
                          • david_hD
                            david_h
                            Hey. . .I can do this! 😍
                            Still a lot to learn tho'.
                            Thx to all.
                            David. . .
                            p.s. Should I surrender my green sketchucator badge?
                            he's tearing off the sketchucator epaulets
                              No, it goes with the brown shoes and tuxedo. Anyway, there's no such thing as a stupid question.
                              What I want to know is how do I reset the location in Thea. I installed mine in Boulder last year while giddy with excitement. It's now permanently set to Boulder. Not a big deal but I've failed to reset since. I know I'm missing something obvious.
                              • david_hD
                                david_h
                                interesting. . .
                                and here's another one. . .Pete? Tomasz?
                                if I set my location in the Location/time tab. ..can I attach THAT or lock that setting to a particular imported scene?
                                Thx,
                                D
                                EDIT: So I am playing with the location/time tabs --adjusting date and time and such, but no change in sun position. . . what am I missing here?
                                • Chris FullmerC
                                  Have the sun selected when you make the changes maybe? Then also hit enter after you change the property? Mine seems to be working.
                                  All my Plugins I've written
                                  • FrederikF
                                    Frederik
                                    Seem to... πŸ˜•
                                    Sure it works... πŸ˜„
                                    And just like you said, you need to hit enter once you've changed the setting...
                                    Cheers
                                    Kim Frederik
                                    • T
                                      tomasz
                                      I have posted a 'tutorial' with a sample on Thea forum.
                                      • N
                                        notareal
                                        Don't forget scripting. Pretty much everything in Thea can be modified by it. Some merge related example http://www.thearender.com/forum/viewtopic.php?f=111&t=6446&start=0
                                        • david_hD
                                          david_h
                                          thanks you guys. I will try all of these methods. I am sure most of this is just my lack of experience with the program. I think scripting might be a little out of my airspace right now, but I will go thru the tut. You guys are great.
                                          Thx,
                                          D
