    Exporting SU Shadow / Sun Settings into thea
    extensions
    19 Posts 8 Posters 2.1k Views 8 Watching
    • N
      notareal
      Oh I know. All you guys are great, and I really appreciate the help.
      Anyway, Does SU and or Google provide the solar angle and Azimuth stuff that THEA uses? can i get that from the Google Locations that I put in the Model?
      If you know the location (latitude & longitude from GE/maps), date and time - that should be enough for Thea for correct Sun & Sky. The solar angle and Azimuth are just alternative way.
      • david_hD
        david_h
        ****oh duh!****Yeah .. right under the Solar Azimuth tab crap . . .there's the location Tab Menu. okay. . . I'm slapping my head here!
        Ouch. . .
          • soloS
            Glad I could help... πŸ˜„
            • david_hD
              david_h
              Hey. . .I can do this! 😍
              Still a lot to learn tho'.
              Thx to all.
              David. . .
              p.s. Should I surrender my green sketchucator badge?
              he's tearing off the sketchucator epaulets
                No, it goes with the brown shoes and tuxedo. Anyway, there's no such thing as a stupid question.
                What I want to know is how do I reset the location in Thea. I installed mine in Boulder last year while giddy with excitement. It's now permanently set to Boulder. Not a big deal but I've failed to reset since. I know I'm missing something obvious.
                • david_hD
                  david_h
                  interesting. . .
                  and here's another one. . .Pete? Tomasz?
                  if I set my location in the Location/time tab. ..can I attach THAT or lock that setting to a particular imported scene?
                  Thx,
                  D
                  EDIT: So I am playing with the location/time tabs --adjusting date and time and such, but no change in sun position. . . what am I missing here?
                  • Chris FullmerC
                    Have the sun selected when you make the changes maybe? Then also hit enter after you change the property? Mine seems to be working.
                    • FrederikF
                      Frederik
                      Seem to... πŸ˜•
                      Sure it works... πŸ˜„
                      And just like you said, you need to hit enter once you've changed the setting...
                      Cheers
                      Kim Frederik
                      • T
                        tomasz
                        I have posted a 'tutorial' with a sample on Thea forum.
                        • N
                          notareal
                          Don't forget scripting. Pretty much everything in Thea can be modified by it. Some merge related example http://www.thearender.com/forum/viewtopic.php?f=111&t=6446&start=0
                          • david_hD
                            david_h
                            thanks you guys. I will try all of these methods. I am sure most of this is just my lack of experience with the program. I think scripting might be a little out of my airspace right now, but I will go thru the tut. You guys are great.
                            Thx,
                            D
