    Exporting SU Shadow / Sun Settings into thea
    extensions
    19 Posts 8 Posters 1.9k Views 8 Watching
      Well, you must have downloaded the exporter. The exe file says what the version number is (currently the latest is 0.89 I think).
      And of course, I meant the "disappointment" in a way that what you hoped to do is not currently possible.
      • david_hD Offline
        david_h
        Oh I know. All you guys are great, and I really appreciate the help.
        Anyway, Does SU and or Google provide the solar angle and Azimuth stuff that THEA uses? can i get that from the Google Locations that I put in the Model?
        • N Offline
          notareal
          If you know the location (latitude & longitude from GE/maps), date and time - that should be enough for Thea for correct Sun & Sky. The solar angle and Azimuth are just alternative way.
          • david_hD Offline
            david_h
            ****oh duh!****Yeah .. right under the Solar Azimuth tab crap . . .there's the location Tab Menu. okay. . . I'm slapping my head here!
            Ouch. . .
              • soloS Offline
                Glad I could help... πŸ˜„
                • david_hD Offline
                  david_h
                  Hey. . .I can do this! 😍
                  Still a lot to learn tho'.
                  Thx to all.
                  David. . .
                  p.s. Should I surrender my green sketchucator badge?
                  he's tearing off the sketchucator epaulets
                    No, it goes with the brown shoes and tuxedo. Anyway, there's no such thing as a stupid question.
                    What I want to know is how do I reset the location in Thea. I installed mine in Boulder last year while giddy with excitement. It's now permanently set to Boulder. Not a big deal but I've failed to reset since. I know I'm missing something obvious.
                    • david_hD Offline
                      david_h
                      interesting. . .
                      and here's another one. . .Pete? Tomasz?
                      if I set my location in the Location/time tab. ..can I attach THAT or lock that setting to a particular imported scene?
                      Thx,
                      D
                      EDIT: So I am playing with the location/time tabs --adjusting date and time and such, but no change in sun position. . . what am I missing here?
                      • Chris FullmerC Offline
                        Have the sun selected when you make the changes maybe? Then also hit enter after you change the property? Mine seems to be working.
                        • FrederikF Offline
                          Frederik
                          Seem to... πŸ˜•
                          Sure it works... πŸ˜„
                          And just like you said, you need to hit enter once you've changed the setting...
                          Cheers
                          Kim Frederik
                            tomasz
                            I have posted a 'tutorial' with a sample on Thea forum.
                            • N Offline
                              notareal
                              Don't forget scripting. Pretty much everything in Thea can be modified by it. Some merge related example http://www.thearender.com/forum/viewtopic.php?f=111&t=6446&start=0
                              • david_hD Offline
                                david_h
                                thanks you guys. I will try all of these methods. I am sure most of this is just my lack of experience with the program. I think scripting might be a little out of my airspace right now, but I will go thru the tut. You guys are great.
                                Thx,
                                D
