    Exporting SU Shadow / Sun Settings into thea
    extensions
    19 Posts 8 Posters 1.6k Views 8 Watching
    • david_hD Offline
      david_h
      I am doing a shadow study that I want to animate in Thea. I have exported the scenes but I am not sure how to get thea to recognize SU's sun settings to get the appropriate time of day and such. Doesn't the SU pluging do this for us?
      I am such a Thea Newbie so this is pretty basic to you guys I am sure. I tried looking on the Thea Forum, but I have a hard time there. .. I can't even see how to post a new question.
      thx,
      David
      • soloS Offline
        What version of SU2Thea are you using?
        • david_hD Offline
          david_h
          Thea 1.1.
          And when I say "using it". . .let's say I have it. I dont know how to use it yet πŸ’š
            That's the renderer version, Pete asked about the exporter version.
            I see however that Tomasz already answered (and disappointed) you in the Thea forums.
            • david_hD Offline
              david_h
              See! that's how much I DON't Know about this stuff. Where would I look to see the "render version"?
              Yeah. . .tomasz was great. He didn't disappoint. At least it's a solution. I was just wondering if maybe Pete had some additional ideas or tricks.
              Thx,
              D
                Well, you must have downloaded the exporter. The exe file says what the version number is (currently the latest is 0.89 I think).
                And of course, I meant the "disappointment" in a way that what you hoped to do is not currently possible.
                • david_hD Offline
                  david_h
                  Oh I know. All you guys are great, and I really appreciate the help.
                  Anyway, Does SU and or Google provide the solar angle and Azimuth stuff that THEA uses? can i get that from the Google Locations that I put in the Model?
                  • N Offline
                    notareal
                    If you know the location (latitude & longitude from GE/maps), date and time - that should be enough for Thea for correct Sun & Sky. The solar angle and Azimuth are just alternative way.
                    Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                    • david_hD Offline
                      david_h
                      ****oh duh!****Yeah .. right under the Solar Azimuth tab crap . . .there's the location Tab Menu. okay. . . I'm slapping my head here!
                      Ouch. . .
                        • soloS Offline
                          Glad I could help... πŸ˜„
                          • david_hD Offline
                            david_h
                            Hey. . .I can do this! 😍
                            Still a lot to learn tho'.
                            Thx to all.
                            David. . .
                            p.s. Should I surrender my green sketchucator badge?
                            he's tearing off the sketchucator epaulets
                              No, it goes with the brown shoes and tuxedo. Anyway, there's no such thing as a stupid question.
                              What I want to know is how do I reset the location in Thea. I installed mine in Boulder last year while giddy with excitement. It's now permanently set to Boulder. Not a big deal but I've failed to reset since. I know I'm missing something obvious.
                              • david_hD Offline
                                david_h
                                interesting. . .
                                and here's another one. . .Pete? Tomasz?
                                if I set my location in the Location/time tab. ..can I attach THAT or lock that setting to a particular imported scene?
                                Thx,
                                D
                                EDIT: So I am playing with the location/time tabs --adjusting date and time and such, but no change in sun position. . . what am I missing here?
                                • Chris FullmerC Offline
                                  Have the sun selected when you make the changes maybe? Then also hit enter after you change the property? Mine seems to be working.
                                  • FrederikF Offline
                                    Frederik
                                    Seem to... πŸ˜•
                                    Sure it works... πŸ˜„
                                    And just like you said, you need to hit enter once you've changed the setting...
                                    Cheers
                                    Kim Frederik
                                      tomasz
                                      I have posted a 'tutorial' with a sample on Thea forum.
                                      Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                                      • N Offline
                                        notareal
                                        Don't forget scripting. Pretty much everything in Thea can be modified by it. Some merge related example http://www.thearender.com/forum/viewtopic.php?f=111&t=6446&start=0
                                        • david_hD Offline
                                          david_h
                                          thanks you guys. I will try all of these methods. I am sure most of this is just my lack of experience with the program. I think scripting might be a little out of my airspace right now, but I will go thru the tut. You guys are great.
                                          Thx,
                                          D
