    Revision control
    9 Posts 7 Posters 912 Views 7 Watching
    • AdamBA
      AdamB
      What package / workflow do Sketchup designers use for revision control? Sure, there are "big iron" solutions such as Alien Brain for backing up, versioning and generally looking after art assets. But I always found them pretty clunky - particularly compared the tools we use for software revision control (such as Subversion, Git, Perforce) which allows you to quickly move back and forth in time to narrow down to a particular revision (that you liked, had bugs, customer wants, whatever).
      I've been saved so many times by being able to roll back to a previous version.
      But with .skp files, I find myself doing scummy stuff like making Copy 1, Copy 2, Copy 3 etc.
      Any top tips / recommendations from the power users out there?
      Adam
      • K
        kaas
        I use the archiver plugin whenever I'm about to change something big. It makes a copy of the current file and puts it in a seperate directory with a timestamp in the filename. Great for rolling back to previous versions.
        • thomthomT
          I use Mercurial, via TortoiseHg with remote repositories on BitBucket.
          • thomthomT
            OOps..! Didn't finish reading the last important sentence... 😳
            For .skp files I usually have an Archive folder in the same folder as my model. Ideally there is only one .skp in the root of the project folder which is the current. I then save a copy in the Archive model when I start a new iteration or alternative. Prefix the original model name with the date and possibly prefix it with a couple of keywords describing it.
            • thomthomT
              (We also have a backup system that let us go back a couple of weeks, restoring a file as it where at the end of each workday.)
              • TIGT
                That's what my 'Archiver' tool does...
                • hellnbakH
                  hellnbak
                  Please allow me to demonstrate my ignorance --
                  I apparently don't understand the question. What's the difference between what you guys are saying and just saving copies of your model (with maybe a few words added to the title to help describe why you saved it) whenever you are going to make some changes to it (in addition to the 5 minute autosave feature)? Try as I might I can't figure out the difference.
                  Of course I'm not a "power user", but then again I might be because I also don't know what defines a "power user"
                  This is probably one of those questions that's going to embarass me 😳 , but you never know 'till you ask, right?
                    It's having the ability to roll back to an earlier version of your model.
                    So 'Roadster_1' is opened
                    Changes are made and it's saved as 'Roadster_1_1'
                    After multiple changes you may end up at 'Roadster_1_7'
                    But on review you need to see 'Roadster_1_3' and modify this version
                    This could be saved as 'Roadster_1_3_1' and so the family of models grows to reflect each modelling session/milestone
                    It needs a Zen like approach to begin. But imagine starting a project and saving after 5min as 'Hellnbak' then modelling and autosave is your only backup. It's not allowing to rollback to a certain stage in the process. It only allows a rollback to the latest autosave or manual save.
                    • J
                      Jim
                      Since SketchUp is not a parametric modeller, saving snapshots is the only way to get back to specific version of a model.
                      A simple approach using a plugin - such as prompting the user for a few notes and saving the file; combined with a history browser that displays the notes and thumbnail might be enough for most users.
                      Possibly introduce the idea of branching (the concept borrowed from software version control systems)
