    [Plugin] FredoTools:RemoveLonelyVertices 1.2a - 20 Jul 11
    18 Posts 16 Posters 44.2k Views 16 Watching
    • fredo6F Offline
      fredo6
      http://forums.sketchucation.com/download/file.php?id=49290
      RemoveLonelyVertices is a small standalone script which will remove (or mark with construction points) the vertices that joins consecutive and collinear edges.
      RemoveLonelyVertices works on a selection or on the whole model recursively.
      It normally preserves all faces and textures.
      http://forums.sketchucation.com/download/file.php?id=49285
      RemoveLonelyVertices is now installed as part of FredoTools.
      See the main post for this plugin for Installation
      http://forums.sketchucation.com/download/file.php?id=49286
      No user manual (see section Quick Startbelow)
      • Language: English and French
      • Menus: by default, it is installed in Tools > FredoTools > Remove Lonely Vertices and also appears in the Contextual menu when there is at least one edge or face in the current selection
      • Icon toolbar: Fredo6 Tool. Icon is not shown by default
      • The plugin is free, for private and commercial usage.
      http://forums.sketchucation.com/download/file.php?id=49284
      [flash=640,480:3bq24fj2]http://youtube.com/v/WbxKv4WJfbc&hl[/flash:3bq24fj2]
      http://forums.sketchucation.com/download/file.php?id=49288
      • Select edges that contain lonely vertices. You can also select faces, groups and components to act on them as a whole. If you select nothing, the plugin will apply the clean up of the lonely vertices to the whole model.
      • Call the Plugin on the selection (main menu or contextual menu “Remove Lonely Vertices”)
      • all lonely vertices are marked with a small green cube
      • a dialog box will appear, asking for action (remove or mark) and whether you wish to process recursively
      • Lonely vertices are removed
      http://forums.sketchucation.com/download/file.php?id=49289
      RemoveLonelyVertices 1.2a - 20 Jul 11: Part of FredoTools. No functional change
      RemoveLonelyVertices 1.1a - 29 May 11: Initial public release
        Thanks Fredo. Great Tool
        • JClementsJ Offline
          JClements
          +1. Thanks, Fredo.
          This should have been built into SU in the first place ... as either an element of the Edit Menu or an option of Model > Purge.
          • mitcorbM Offline
            mitcorb
            Thank you Fredo. This tool should come in handy as an analytical tool prior to using ArtisanSDS. Occasionally, Artisan will ding you about "lonely vertices" in the process of subdividing, although that's not what the error message says. And, point well made by JClements.
              rv1974
              thank you, it'll help in sanitary state preserving.
                Tricky 😉
                  JGA
                  Thanks very much, this will be a very handy tool.
                  Regards,
                  JGA
                  • P Offline
                    Panga
                    Thanks for this plugin Fredo, it'll complete the Thomthom's Cleanup plugin. 👍
                    • P Offline
                      putnik
                      I've been wanting a tool like this forever. Thanks very much Fredo6!
                      http://keshas.info
                      • P Offline
                        Pherim
                        Great plugin! Thanks!
                          abilio
                          Fredo u r hell awesome, thank u so much.
                            dylan
                            Thanks Fredo, impressive work again.
                            http://dmdarchitecture.co.uk/
                              CleanUp has the feature - it's the Repair Split Edges function.
                              • fredo6F Offline
                                fredo6
                                @panga: Thomthom is right, this is part of the great suit of Cleanup tools. The only small difference is that RemoveLonelyVertices allows to visualize the lonely vertices before proceeding, and also to repair a selection of colinear edges on a full sequence of colinear edges (instead of replacing the whole sequence by a single edge). This is just very subtle (and not sure this is required in the real life), but I needed this feature for another script.
                                Fredo
                                  Ben Ritter
                                  Thank you again, for your generosity and great work.
                                  • G Offline
                                    gokhan0322
                                    thn xxxxxxxxx
                                      seth65475 Newcomers
                                      Glad to be one of the visitors on this awe inspiring web site. Facboook
                                        seth65475 Newcomers
