    [Plugin] FredoTools:RemoveLonelyVertices 1.2a - 20 Jul 11
    18 Posts 16 Posters 44.9k Views 16 Watching
      Thanks Fredo. Great Tool
      • JClementsJ
        JClements
        +1. Thanks, Fredo.
        This should have been built into SU in the first place ... as either an element of the Edit Menu or an option of Model > Purge.
        • mitcorbM
          mitcorb
          Thank you Fredo. This tool should come in handy as an analytical tool prior to using ArtisanSDS. Occasionally, Artisan will ding you about "lonely vertices" in the process of subdividing, although that's not what the error message says. And, point well made by JClements.
            rv1974
            thank you, it'll help in sanitary state preserving.
              Tricky 😉
                JGA
                Thanks very much, this will be a very handy tool.
                Regards,
                JGA
                • P
                  Panga
                  Thanks for this plugin Fredo, it'll complete the Thomthom's Cleanup plugin. 👍
                  • P
                    putnik
                    I've been wanting a tool like this forever. Thanks very much Fredo6!
                    http://keshas.info
                    • P
                      Pherim
                      Great plugin! Thanks!
                        abilio
                        Fredo u r hell awesome, thank u so much.
                          dylan
                          Thanks Fredo, impressive work again.
                          http://dmdarchitecture.co.uk/
                            CleanUp has the feature - it's the Repair Split Edges function.
                            • fredo6F
                              @panga: Thomthom is right, this is part of the great suit of Cleanup tools. The only small difference is that RemoveLonelyVertices allows to visualize the lonely vertices before proceeding, and also to repair a selection of colinear edges on a full sequence of colinear edges (instead of replacing the whole sequence by a single edge). This is just very subtle (and not sure this is required in the real life), but I needed this feature for another script.
                              • B
                                Ben Ritter
                                Thank you again, for your generosity and great work.
                                • G
                                  gokhan0322
                                  thn xxxxxxxxx
                                    seth65475 Newcomers
                                    Glad to be one of the visitors on this awe inspiring web site. Facboook
                                      seth65475 Newcomers
