    Multiple faces driving me crazy!
    37 Posts 11 Posters 20.0k Views 11 Watching
    • hellnbakH Offline
      hellnbak
      Is there some sort of trick to avoiding multiple faces being created when adding a face or subdividing a face? By multiple faces I mean faces on top of faces. Seems to be random as far as the the number of faces created, I think my record is seven. It's just a real pain when you go to paint the object, the multiple faces won't paint or smooth and you have to keep deleting the extra faces until you finally reach the "real" face. What the heck causes them? Is it my bad attitude?
      • Wo3DanW Offline
        Wo3Dan
        What plugin(s) is causing the issue, or none at all?
        What is your workflow step by step when (just before) encountering the issue?
        Right now it's hard to tell.
        Are these faces separated by being in different groups or by (some minor)endpoint differences?
          I get this from time to time as well. I suspect it's when I base geometry on imported CAD data which some times have some tiny inaccuracy that triggers some precision bug in SketchUp. PITA! X_x
            So 'flatten' the CAD drawing beforehand ?
            There are several tools or just drape it onto a large rectangle drawn below it - that way you get all the faces and no duplicates ??
              That doesn't seem to work either.
              • H Offline
                HFM
                I thought I was alone in this 😄 Very frustrating when you've created a face and you still have to triangulate it yourself so SketchUp recognizes it.
                Next time it happens I'm going to try the 'From Contours' option to see if that will just fill the shape...
                  That doesn't sound like the same case as mentioned before. What we're talking about is SketchUp creating extra faces ontop of existing faces. For instance, I have a planar polygon and I draw an edge across it to split it. In addition to splitting the face into two faces SketchUp creates extra duplicate faces overlapping the existing ones.
                  • H Offline
                    HFM
                    That is somewhat different from how I interpreted it. 😄 Still it's in the same ballpark though, SketchUp not recognizing faces and thus leaving holes [my problem] or duplicating faces...
                    • hellnbakH Offline
                      hellnbak
                      Well, I know this is not the problem, at least in my case, because I don't use imported CAD data. I can't even spell CAD 😆
                      It might not be so frustrating if it only added one extra face, at least then I would know that I could just delete the extra face and move on. But up to seven faces? What on earth could cause that? All I'm doing is either adding a face or subdividing an existing face, nothing complicated or mysterious about that. And I'm not talking about one particular model that's causing the problem, it happens, randomly, with no particular rhyme or reason, on whatever model I happen to be working on. And I know it's not a problem with a particular installation of SU, I have SU on several computers and it happens with each of them. Right now, because I never know how many extra faces there are, I just keep deleting them until there is no face, then undo the last deletion. Not the ideal solution.
                      It's not an earth-shattering problem, I know that I can fix it when it happens, it's just so dang annoying, it's a pothole in the road when I'm otherwise just cruising along creating another masterpiece (in my dreams). What I was really hoping was that it was a problem that other SU users had solved long ago and in my noobie ignorance had just not puzzled out the solution for myself.
                      Maybe somebody could write a plugin that makes extra faces a different color, at least that way I could just keep deleting them until the color was right 😉 .
                      Anyhow, thanks for all your input. I guess I'll just add it to my ever-growing list of SU peculiarities, and live with it. It's getting to the point that sometimes I wish I had never stumbled across SU. I certainly would have more free time to grow old.
                        "Remove Duplicate Faces" in CleanUp tries to remove such faces. But beware it's very slow.
                        • Wo3DanW Offline
                          Wo3Dan
                          @hellnbak said:
                          .... And I'm not talking about one particular model that's causing the problem, it happens, randomly, with no particular rhyme or reason, on whatever model I happen to be working on........
                          I don't have a clue whatsoever. It doesn't ever happen to my models.
                          So share one of yours, if possible.
                          • hellnbakH Offline
                            hellnbak
                            So you're saying that you have never had a multiple face on any of your models? 😲
                            You really need to buy a lottery ticket 😆
                            • Wo3DanW Offline
                              Wo3Dan
                              Yes, that's what I said.
                              @hellnbak said:
                              ...You really need to buy a lottery ticket 😆
                              I'd rather have that model of yours instead of the ticket.
                              For I also never win with lotteries. 💚
                              • jgbJ Offline
                                jgb
                                I get the double face on occasion as well. Don't have a clue why, as they seem to form randomly in areas where I have never edited, but seem to occur after I do an intersection to that surface.
                                BUT, I have discovered 2 ways to find them.
                                The first applies to surfaces that have some curve in them. It does not work with flat surfaces.
                                With all lines on the surface both soft and smooth, and hidden lines off, roll and rotate the surface and examine it carefully. You will see some individual faces seem to have a decidedly harder outline and seem somewhat flat. They are double faced. Just delete the "flat" face after you turn on hidden lines.
                                In the 2nd method, I found that when I made some surfaces (flat or curved) in a semi-transparent material (both front and back faces, not just 1 face) I saw some individual faces had a slightly darker appearance. Those were the double faces.
                                So, if you suspect double faces, select the whole surface, paint both sides with some throw-away color. Edit that color to be semi-transparent (around 20-50%) and view the surface with with hidden lines off. Delete the darker faces after you turn on hidden lines. Then repaint with desired color.
                                jgb
                                • mitcorbM Offline
                                  mitcorb
                                  I would add to this, that another way to inspect for duplicate faces is to turn on xray mode and orbit to inspect faces. At least on my machine the doubled faces are a little less transparent than others.
                                  You can also see internal unwanted closed faces when you visually compare the sharpness of edges seen through multiple layers of faces. Internal closed faces readily form when loops of edges are coplanar and aligned with global axis.
                                  • mitcorbM Offline
                                    mitcorb
                                    @hellnbak: Do you by chance, have quick hands? That is, do you model quickly? This may be nothing, but maybe some double clicking or something?
                                    My machine is borderline acceptable, and I am a slow modeler, but of course I do get these duplicate faces occasionally.
                                    • EarthMoverE Offline
                                      EarthMover
                                      I'll get it running the Make faces plugin from time to time. I've had instances where I'll get 15 or more faces on top of each other. You can tell when you go to texture it and nothing shows up. Usually running and intersect followed by Thom's cleanup will sort most of it out. It is very frustrating sometimes. Sketchup and profanity seem to go hand in hand in my house.
                                      Content Creator at Skapeup
                                      • hellnbakH Offline
                                        hellnbak
                                        Thanks for the suggestions, but finding the multiple faces is not a problem, I was just hoping that someone had a good tip on how to avoid creating the faces in the first place. Actually I wasn't very hopeful, but figured it was worth a shot. Like I said, I'll just have to live with it (just like all the other SU strange and annoying quirks 😒 )
                                          Quirks or charm? 😉
                                          • hellnbakH Offline
                                            hellnbak
                                            Hmmmm.....I'll have to go with quirks, and I'm being kind. Maybe SNAFU would be closer. I know now why they made SU free - you can't demand a refund for something you didn't pay for ❗
                                            • 1 / 2
