    [Plugin] Projecting Floor Paintings
    16 Posts 10 Posters 20.2k Views 10 Watching
    • plot-parisP Offline
      plot-paris
      Hello everyone,
      have been absent for quite some time now. just too much to do. but now I've got a problem, that might be solved by a nice little ruby script:
      Do you know these painters, drawing a painting on the floor in a pedestrian area? Some of these paintings use a fantastic trick, so that if you stand at one specific point you will see a hole in the ground or similar. They do it via perspective distortion.
      To create such a painting in SketchUp all I have to do is create the scene, then define one camera point in space. Then I have to draw lines from this camera point to all the visible vertexes and continue these line until they hit the ground floor. And finally all I have to do is connect these new intersection points on the ground.
      If I look thorugh the camera now, I will see a 3D object, that is actually painted on a flat floor.
      (by the way: there is a new "Film and Stage" plugin for SketchUp 8 )
      Unfortunately I need to do that for quite a few scenes. And I figured this might be something that can be done via Ruby (I know there is the Projection ruby. But it doesn't do projections from one single point, only parallel...)
      I need to do the project over the weekend. So time is short 😕
      Any help would be highly appreciated!
      • mitcorbM Offline
        mitcorb
        Hi, plot-paris:
        Nice to see you back.
        I thought perhaps you could do a Forum wide search on "camera", but then I saw that there were only 307 pages on this search topic. However, what you describe does bring up thoughts of discussions within the last 6 months, it seems, on related topics.
          Try this Put into Plugins folder and restart Sketchup...
          projecteye2ground.rb
          Select raw geometry [i.e. including the edges to project] and type projecteye2ground into the Ruby Console, and the vertices are projected onto the ground plane from the eye, with cpoints and clines reproducing the distorted form...
          • mitcorbM Offline
            mitcorb
            In lieu of all that exhaustive searching, we have the resident problem solver to present the solution. Well done, TIG. 👍 👍
              plot-paris
              wow, TIG! Did you just write that? thats almost perfect! wonderful! you just made my day!!!
                TIG, that's pretty slick.
                Eye2Ground.skp
                • E Offline
                  elthanos
                  Very good TIG!!! Could it project on other objects too or only on ground floor?
                    RPNZ
                    Hey TIG, this is all great information,
                    is there a way of projecting on the ground and onto a vertical surface ? ie onto a street and onto a building across the street? So the "object is projected on the flat and vertical surfaces in the same drawing?
                    thanks..
                      mikedd
                      Julian Beever is probably the most famous. http://www.julianbeever.net/index.php?option=com_content&view=article&id=1&Itemid=1
                      Here is a basic tutorial http://www.instructables.com/id/3D-Anamorphic-Street-Art/
                      With Photoshop http://www.instructables.com/id/Anamorphic-3-D-Images-with-Photoshop/
                        mikedd
                        Heres mine: Nancy with a basketball, in scene 1 the ball looks normal. In scene 2 you can clearly see how the ball is flat and distorted by using the scale tool and how long the anamorphic images have to be to get the desired effect.
                        anamorphic.skp
                          http://artbite.fr/local/cache-vignettes/L400xH547/artbite-a323-anamorphose_femme_au_miroir-231db.jpg
                          • robertWanR Offline
                            robertWan
                            How to place the camera in the designated place (x, y, z)?
                            Google Translator
                            Robert
                              eye = [1000,1000,1000]
                              target = [0,0,0]
                              up = [0,0,1]
                              my_camera = Sketchup;;Camera.new(eye, target, up)
                              Sketchup.active_model.active_view.camera = my_camera
                              Vary the eye and target as desired...
                              • Didier BurD Offline
                                Didier Bur
                                @RPNZ:
                                Try my Projections extension, I think it can do it 😉
                                Here: https://extensions.sketchup.com/extension/8f66e284-c0e3-45a9-be6e-e86911a3cf5e/projections-tools
                                DB
                                  robertWan
                                  @didier bur said:
                                  @RPNZ:
                                  I have SU8 and I see that I need 2016.
                                  It works! Thank you.
                                  The shadows can be easily redrawn by hand.
                                  Robert
                                    Didier Bur
                                    DB
