    [Plugin] Projecting Floor Paintings
    16 Posts 10 Posters 20.3k Views 10 Watching
    • plot-parisP
      plot-paris
      wow, TIG! Did you just write that? thats almost perfect! wonderful! you just made my day!!!
        TIG, that's pretty slick.
        Eye2Ground.skp
        • E
          elthanos
          Very good TIG!!! Could it project on other objects too or only on ground floor?
            RPNZ
            Hey TIG, this is all great information,
            is there a way of projecting on the ground and onto a vertical surface ? ie onto a street and onto a building across the street? So the "object is projected on the flat and vertical surfaces in the same drawing?
            thanks..
              mikedd
              @plot-paris said:
              Do you know these painters, drawing a painting on the floor in a pedestrian area? Some of these paintings use a fantastic trick, so that if you stand at one specific point you will see a hole in the ground or similar. They do it via perspective distortion.
              Julian Beever is probably the most famous. http://www.julianbeever.net/index.php?option=com_content&view=article&id=1&Itemid=1
              Here is a basic tutorial http://www.instructables.com/id/3D-Anamorphic-Street-Art/
              With Photoshop http://www.instructables.com/id/Anamorphic-3-D-Images-with-Photoshop/
                mikedd
                Heres mine: Nancy with a basketball, in scene 1 the ball looks normal. In scene 2 you can clearly see how the ball is flat and distorted by using the scale tool and how long the anamorphic images have to be to get the desired effect.
                anamorphic.skp
                  http://artbite.fr/local/cache-vignettes/L400xH547/artbite-a323-anamorphose_femme_au_miroir-231db.jpg
                  • robertWanR
                    robertWan
                    How to place the camera in the designated place (x, y, z)?
                    Google Translator
                    Robert
                      eye = [1000,1000,1000]
                      target = [0,0,0]
                      up = [0,0,1]
                      my_camera = Sketchup;;Camera.new(eye, target, up)
                      Sketchup.active_model.active_view.camera = my_camera
                      Vary the eye and target as desired...
                      • Didier BurD
                        Didier Bur
                        @RPNZ:
                        Try my Projections extension, I think it can do it 😉
                        Here: https://extensions.sketchup.com/extension/8f66e284-c0e3-45a9-be6e-e86911a3cf5e/projections-tools
                        DB
                        • robertWanR
                          robertWan
                          @didier bur said:
                          @RPNZ:
                          I have SU8 and I see that I need 2016.
                          It works! Thank you.
                          The shadows can be easily redrawn by hand.
                          Robert
                          • Didier BurD
                            Didier Bur
                            DB
