    FluidImporter free .obj importer Beta 1.0.5 Updated
    extensions
    168 Posts 46 Posters 77.2k Views 46 Watching
      Mikaelo
      @box said:
      I don't know about the rest of it but the .rbz file is an installation file used to install extension from within sketchup. If you go to Window/Preferences/Extensions tab and click install extension you can navigate to the file and install it that way.
      As said before, even if the plugin seems to be installed correct and then select an OBJ file to import, NOTHING happens, even for small files, even if I wait 5, 10, or more than 20 minutes for 500Kb sized OBJ files! Feel free to have a look on the following screenshots (for example by installing and using TIG's "obj_importer_v2.2.rbz" plugin).
      http://s27.postimg.org/t3i5lv0fn/001.jpg
      http://s27.postimg.org/mn4li12ib/002.jpg
      http://s27.postimg.org/jhjzrtjw3/003.jpg
      @box said:
      If you don't have a new enough version of SU the install extension button won't be there, either update SU or install the .rb manually.
      As already said, I have installed the v 8.0.15158, which I believe is the most recent "8" version before the "2013" version. The point is that the laptop, works with same SketchUp version, same Win XP version, can import OBJ files with any kind of method (plugin or FluidImporter) but is old & extremely slow to use for such purposes.
      @box said:
      To get the .rb from the .rbz rename it to .zip and you'll find the .rb inside and you can extract it to your plugins folder.
      Already tried that. No result!...
        OK...
        Back track.
        If it installed OK on another XP PC, then it should install on this similar one...
        Have you got the XP SP3 installed on both ?
        Also do you have the same Security permissions set for the subfolders within the SketchUp folder ?
        That is == ALL subfolders, like Plugins, AND Importers etc...
        Perhaps having limited permissions is affecting the importer's successful installation...
          Mikaelo
          @ TIG thanks for helping. You are an experienced user and I count on your oppinion.
          Yes, on the old & slow laptop is intsalled and works fine. Actually (and that the most weird thing that drives me crazy) it WAS installed and used to work OK on THIS PC, few days ago, before disc format and installing again Win XP. Same XP, same everything. I cannot understand, HOW it is possible for OJJ importer to work fine on PC and after format and re-install everything (by using the exact same exe files, my SketchUp denies to import OBJ files? How can be?
          Yes! From same CD. I "refresh" my PC / laptop once or twice a year, using always same Win XP features and always following same procedures. Never had problems before
          @tig said:
          Also do you have the same Security permissions set for the subfolders within the SketchUp folder ? That is == ALL subfolders, like Plugins, AND Importers etc...
          Everything is set on same options. I had the laptop side-byside with PC, and check every possible option within SketchUp. All same. Also, checked files & folders. All same too.
          Hmmm, what exactly you mean with "limited permissions"? How can be one working and other not, when both using the exact same software?
            Folders can have limited security permissions.
            These can affect the permissions of the enclosed files.
            Check the security permissions of the two folders and see if they differ ?
            This relates to Windows itself, not SketchUp or any application...
              Have you tried 'Repairing' SketchUp ?
                Mikaelo
                @tig said:
                Folders can have limited security permissions. These can affect the permissions of the enclosed files. Check the security permissions of the two folders and see if they differ ? This relates to Windows itself, not SketchUp or any application...
                After your advice, I checked. And then double checked. And then checked again. And found everything same in both machines. the only difference is that on PC, the SketchUp does not import OBJ files. Yes, I know, that it sounds very strange and you might think that I do something very stupid mistake here, but I am also confused and amazed of the problem. The Sketchup simply denies to accept any method of importing OBJ files. ANY method - not just FluidImporter!
                  Mikaelo
                  Please be more specific. How to "Repair" SketchUp? Keep in mind that at this point, after failing to fix the error myself, I need guidance like I am 5 years old boy. Its the first time after 15 years PC using that I feel completely unable to win the machine.
                    I'm not sure about XP, but on newer PCs the Programs 'Control Panel' has an Uninstall/Repair option.
                    By Repairing the installation it might fix some 'permissions' etc ?
                    Are you 100% sure that all 'permissions' etc under 'properties' are the same on both machines, for all folders that SketchUp uses ?
                    Logic suggests that one of them differs, and therefore limits your 'importer' πŸ˜•
                    If there are any XP users left out there, please chip in... πŸ˜„
                      Mikaelo
                      @tig said:
                      I'm not sure about XP, but on newer PCs the Programs 'Control Panel' has an Uninstall/Repair option. By Repairing the installation it might fix some 'permissions' etc ?
                      When I first notice the problem few days before, the first thing I tried was un-installing and then installing again the FluidImport. No result! Then, I tried un-installing and then installing again the SketchUp. No result again! I also tried to install older "8" or "7" versions (as already mentioned in my previous post HERE), but no result!. Then, I tried to format my hard disc and install everything back again - not one time, but 5! Five formats, 5 Win XP installing procedures one after the other, 5 "fresh" SketcUp installings. Unfortunately, every time, the SketchUp denioes to import OBJ files. Every time! No result at all!
                      200% sure. I placed the laptop side-by-side on PC screen to check one-by-one all 'permissions', 'properties', folders, subfolders, files etc in both machines. Everything is same, but no result! It simply denies to make me happy.
                        I am at a loss too πŸ˜•
                          Mikaelo
                          Since I see to result, I am about to quit SketchUp-ing.
                          Importing non-SKP files (STL, OBJ, SLDPRT etc) into SketchUp by converting them into OBJ first, was the best solution for me. On the other hand, the DAE files are not an option, because it takes too looooong (many hours or days for big files) to import into SketchUp and the 3DS files look like damaged when imported into SketchUp.
                          I ll keep waiting for any possible ideas for few days more, but I see no other available way to keep dealing with SketchUp for easy modeling. Thanks for your kind answers.
                          • P Offline
                            pibuz
                            Any chance that we get support for 2014 version guys?
                            Thanks in advance!
                            WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                            • F Offline
                              fluid
                              We just released a new version of FluidImporter 2 that solves a lot of compatibility issues with SketchUp 2013/2014. You can download it here:
                              301 Moved Permanently
                              (www.fluidray.com)
                                mac1
                                By default XP does not make the Admin log on at its welcome screen available. Try at the welcome screen pressing cntrl+alt+delete twice; logon user; administrator; pwd the one you orginally set.
                                When you fomatted your disk what did you use FAT32 or NTFS
                                  Mikaelo
                                  The HDs in both machines (PC and laptop) are formated in NTFS. In laptop it works, in PC it does not.
                                  I am the only user and I have not set pass while loging in. WinXP starts without selecting user or seting a pass to proceed.
                                    mac1
                                    Good NTFS is where the extensive permsiions are implemented;
                                    Try the log on I suggested above . I used XP for some time and was surprised. Do internet search on windows xp administrator log in there are a number of how too,s. Note the xp login is different depending on the xp sku version you have, stating just xp is not the full story.
                                    • jeff hammondJ Offline
                                      jeff hammond
                                      (www.fluidray.com)
                                      i take it a mac version is not in the works nor will it ever be?
                                      mac sketchup needs a fast OBJ importer and so far, you're the closest hope πŸ˜„
                                      dotdotdot
                                      • F Offline
                                        fluid
                                        Actually, we are working on the Mac version as well, it will be released soon.
                                          jeff hammond
                                          😲 πŸ‘
                                          sweet!
                                          dotdotdot
                                          • P Offline
                                            pibuz
                                            (www.fluidray.com)
                                            Thanks a lot fluid! Your plugin is wonderful!
                                            EDIT: I'm seriously intentioned to buy your plugin. What would be the price in euros (I'm italian)? Thank you
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 7 / 9
