    FluidImporter free .obj importer Beta 1.0.5 Updated
    extensions
    168 Posts 46 Posters 90.5k Views 46 Watching
      guaucorreo
      hi, there is a problem on the official page of http://www.fluidray.com/ (Internal Server Error)
      an its imposible to download the fluidimporter win 32
      please can someone share
      thanks in advance
        guaucorreo
        thanks, i have now the fluidimporter from direct download (11,7MB)
        I try how it works
        • F Offline
          fluid
          We just released FluidImporter 2.0 for SketchUp 2013. We decided to make it available for a small fee to help support the development. You can download the 30-Day trial (full-featured) in the download page: http://www.fluidray.com/downloads
            RTM
            This is what I was looking for !!! thanks TIG and fluid you are my hero ! 😄
              Mikaelo
              HELP WANTED - OBJ IMPORT OPTION DOES NOT APPEAR
              I am a happy SketchUp user (version 8.0.16846), mostly for hobby purposes. I used the FluidImporter (v 1.0.5 32 bit) to import OBJ files into SketchUp with no problems at all for more than one year. I am running Win XP pro SP3 32 bit.
              Last week I format my HD and start installing again all programs - no problem so far. After installing the SketchUp (version 8.0.16846) & FluidImporter (v 1.0.5 32 bit) which I used to work for long time without problems, I found that I cannot import OBJ files. Actually, under the "Import" table, the "OBJ files" options is now missing (screenshots follwoing). The FluidImporter seems to be installed normaly, the files "FluidImporter.dll" and "Uninstall.exe" seems to be OK under C:\Program Files\Google\Google SketchUp 8\Importers folder (exactly as before HD format and Win XP new instalation)... but the OBJ importing option is missing!
              As said before, I am running a SketchUp 8.0.16846 with FluidImporter 1.0.5 (Win XP 32 bit version downloaded from http://www.fluidray.com/downloads link) on a Win XP SP3. The most weird is that I installed the exact same setup files as before HD format and new Win XP, so it should work but unfortunatelly it does not!
              Any ideas or advices please?
              http://s28.postimg.org/psxdlvpvx/Screen_01.jpg
              http://s28.postimg.org/lu063218t/Screen_02.jpg
              http://s28.postimg.org/tb9di9qrx/Screen_03.jpg
              http://s28.postimg.org/cq1r2lznx/Screen_04.jpg
                Mikaelo
                Anybody? Come ooon people. Am I the only one person facing this problem? There MUST be a way! OBJ files importing option is still not available and I have no idea what should be done to make it work...
                ...ANY idea, ANY advice could be usefull
                • TIGT Online
                  Have you been in touch with the author ?
                  It might be an XP issue ??
                  If all else fails my slower Ruby based OBJimporter will work ?
                    Mikaelo
                    Already did that, few days ago. No answer yet.
                    Could be, could be not. I have an old laptop, operating with same XP pro SP3 version, same SketchUp version 8.0.15158 and same FluidImporter version 1.0.5 and the OBJ files can be imported. You might ask me why I do not use this old laptop, to do all the import hard work to translate OBJ into SKP files. Well, its an old laptop as said before, not capable for hard work and able to handle only small (not more than 1-2 Mb) OBJ files without crashing Sketchup.
                    I guess you mean THIS one. Right? Already download it and seems to be the "obj_importer_v2.2.rbz" file (5.2 kb). Placed it into "Plugins" folder, but nothing happened. Should I place it into another folder? On the other hand, I ve alrady tried Jim Foltz's "obj_import.rb" file, which seems to give me an option to inport an OBJ file but it does not work (Sketchup does not respond (even if I tried small files 0.5-1 Mb)...
                    The last few days I have this problem, I formated the hd 5 times, install everything again another 5 times, do everything by the book as I did dozens of times all these years before when need to re-fresh my Windows, tried different versions of Sketchup (v 7.0.08657 / 7.0.10247 / 7.1.04871 / 7.1.06087 / 7.1.06860 / 8.0.03117 / 8.0.04811 / 8.0.11752 / 8.0.14346 / 8.0.15158) tried to install again and again the FluidImporter 1.0.5, but nothing happens...!!! No OBJ file import option appeared into menu.
                    • BoxB Offline
                      I don't know about the rest of it but the .rbz file is an installation file used to install extension from within sketchup. If you go to Window/Preferences/Extensions tab and click install extension you can navigate to the file and install it that way.
                      If you don't have a new enough version of SU the install extension button won't be there, either update SU or install the .rb manually. To get the .rb from the .rbz rename it to .zip and you'll find the .rb inside and you can extract it to your plugins folder.
                        Mikaelo
                        As said before, even if the plugin seems to be installed correct and then select an OBJ file to import, NOTHING happens, even for small files, even if I wait 5, 10, or more than 20 minutes for 500Kb sized OBJ files! Feel free to have a look on the following screenshots (for example by installing and using TIG's "obj_importer_v2.2.rbz" plugin).
                        http://s27.postimg.org/t3i5lv0fn/001.jpg
                        http://s27.postimg.org/mn4li12ib/002.jpg
                        http://s27.postimg.org/jhjzrtjw3/003.jpg
                        As already said, I have installed the v 8.0.15158, which I believe is the most recent "8" version before the "2013" version. The point is that the laptop, works with same SketchUp version, same Win XP version, can import OBJ files with any kind of method (plugin or FluidImporter) but is old & extremely slow to use for such purposes.
                        Already tried that. No result!...
                        • TIGT Online
                          OK...
                          Back track.
                          If it installed OK on another XP PC, then it should install on this similar one...
                          Have you got the XP SP3 installed on both ?
                          Also do you have the same Security permissions set for the subfolders within the SketchUp folder ?
                          That is == ALL subfolders, like Plugins, AND Importers etc...
                          Perhaps having limited permissions is affecting the importer's successful installation...
                            Mikaelo
                            @ TIG thanks for helping. You are an experienced user and I count on your oppinion.
                            Yes, on the old & slow laptop is intsalled and works fine. Actually (and that the most weird thing that drives me crazy) it WAS installed and used to work OK on THIS PC, few days ago, before disc format and installing again Win XP. Same XP, same everything. I cannot understand, HOW it is possible for OJJ importer to work fine on PC and after format and re-install everything (by using the exact same exe files, my SketchUp denies to import OBJ files? How can be?
                            Yes! From same CD. I "refresh" my PC / laptop once or twice a year, using always same Win XP features and always following same procedures. Never had problems before
                            @tig said:
                            Also do you have the same Security permissions set for the subfolders within the SketchUp folder ? That is == ALL subfolders, like Plugins, AND Importers etc...
                            Everything is set on same options. I had the laptop side-byside with PC, and check every possible option within SketchUp. All same. Also, checked files & folders. All same too.
                            Hmmm, what exactly you mean with "limited permissions"? How can be one working and other not, when both using the exact same software?
                            • TIGT Online
                              Folders can have limited security permissions.
                              These can affect the permissions of the enclosed files.
                              Check the security permissions of the two folders and see if they differ ?
                              This relates to Windows itself, not SketchUp or any application...
                              • TIGT Online
                                Have you tried 'Repairing' SketchUp ?
                                  Mikaelo
                                  @tig said:
                                  Folders can have limited security permissions. These can affect the permissions of the enclosed files. Check the security permissions of the two folders and see if they differ ? This relates to Windows itself, not SketchUp or any application...
                                  After your advice, I checked. And then double checked. And then checked again. And found everything same in both machines. the only difference is that on PC, the SketchUp does not import OBJ files. Yes, I know, that it sounds very strange and you might think that I do something very stupid mistake here, but I am also confused and amazed of the problem. The Sketchup simply denies to accept any method of importing OBJ files. ANY method - not just FluidImporter!
                                    Mikaelo
                                    Please be more specific. How to "Repair" SketchUp? Keep in mind that at this point, after failing to fix the error myself, I need guidance like I am 5 years old boy. Its the first time after 15 years PC using that I feel completely unable to win the machine.
                                    • TIGT Online
                                      I'm not sure about XP, but on newer PCs the Programs 'Control Panel' has an Uninstall/Repair option.
                                      By Repairing the installation it might fix some 'permissions' etc ?
                                      Are you 100% sure that all 'permissions' etc under 'properties' are the same on both machines, for all folders that SketchUp uses ?
                                      Logic suggests that one of them differs, and therefore limits your 'importer' 😕
                                      If there are any XP users left out there, please chip in... 😄
                                        Mikaelo
                                        @tig said:
                                        I'm not sure about XP, but on newer PCs the Programs 'Control Panel' has an Uninstall/Repair option. By Repairing the installation it might fix some 'permissions' etc ?
                                        When I first notice the problem few days before, the first thing I tried was un-installing and then installing again the FluidImport. No result! Then, I tried un-installing and then installing again the SketchUp. No result again! I also tried to install older "8" or "7" versions (as already mentioned in my previous post HERE), but no result!. Then, I tried to format my hard disc and install everything back again - not one time, but 5! Five formats, 5 Win XP installing procedures one after the other, 5 "fresh" SketcUp installings. Unfortunately, every time, the SketchUp denioes to import OBJ files. Every time! No result at all!
                                        200% sure. I placed the laptop side-by-side on PC screen to check one-by-one all 'permissions', 'properties', folders, subfolders, files etc in both machines. Everything is same, but no result! It simply denies to make me happy.
                                        • TIGT Online
                                          I am at a loss too 😕
                                            Mikaelo
                                            Since I see to result, I am about to quit SketchUp-ing.
                                            Importing non-SKP files (STL, OBJ, SLDPRT etc) into SketchUp by converting them into OBJ first, was the best solution for me. On the other hand, the DAE files are not an option, because it takes too looooong (many hours or days for big files) to import into SketchUp and the 3DS files look like damaged when imported into SketchUp.
                                            I ll keep waiting for any possible ideas for few days more, but I see no other available way to keep dealing with SketchUp for easy modeling. Thanks for your kind answers.
                                            • 7 / 9
