    FluidImporter free .obj importer Beta 1.0.5 Updated
    extensions
    168 Posts 46 Posters 90.5k Views 46 Watching
    • TIGT Online
      Have you tried 'Repairing' SketchUp ?
        Mikaelo
        @tig said:
        Folders can have limited security permissions. These can affect the permissions of the enclosed files. Check the security permissions of the two folders and see if they differ ? This relates to Windows itself, not SketchUp or any application...
        After your advice, I checked. And then double checked. And then checked again. And found everything same in both machines. the only difference is that on PC, the SketchUp does not import OBJ files. Yes, I know, that it sounds very strange and you might think that I do something very stupid mistake here, but I am also confused and amazed of the problem. The Sketchup simply denies to accept any method of importing OBJ files. ANY method - not just FluidImporter!
          Mikaelo
          Please be more specific. How to "Repair" SketchUp? Keep in mind that at this point, after failing to fix the error myself, I need guidance like I am 5 years old boy. Its the first time after 15 years PC using that I feel completely unable to win the machine.
          • TIGT Online
            I'm not sure about XP, but on newer PCs the Programs 'Control Panel' has an Uninstall/Repair option.
            By Repairing the installation it might fix some 'permissions' etc ?
            Are you 100% sure that all 'permissions' etc under 'properties' are the same on both machines, for all folders that SketchUp uses ?
            Logic suggests that one of them differs, and therefore limits your 'importer' πŸ˜•
            If there are any XP users left out there, please chip in... πŸ˜„
              Mikaelo
              @tig said:
              I'm not sure about XP, but on newer PCs the Programs 'Control Panel' has an Uninstall/Repair option. By Repairing the installation it might fix some 'permissions' etc ?
              When I first notice the problem few days before, the first thing I tried was un-installing and then installing again the FluidImport. No result! Then, I tried un-installing and then installing again the SketchUp. No result again! I also tried to install older "8" or "7" versions (as already mentioned in my previous post HERE), but no result!. Then, I tried to format my hard disc and install everything back again - not one time, but 5! Five formats, 5 Win XP installing procedures one after the other, 5 "fresh" SketcUp installings. Unfortunately, every time, the SketchUp denioes to import OBJ files. Every time! No result at all!
              200% sure. I placed the laptop side-by-side on PC screen to check one-by-one all 'permissions', 'properties', folders, subfolders, files etc in both machines. Everything is same, but no result! It simply denies to make me happy.
              • TIGT Online
                I am at a loss too πŸ˜•
                  Mikaelo
                  Since I see to result, I am about to quit SketchUp-ing.
                  Importing non-SKP files (STL, OBJ, SLDPRT etc) into SketchUp by converting them into OBJ first, was the best solution for me. On the other hand, the DAE files are not an option, because it takes too looooong (many hours or days for big files) to import into SketchUp and the 3DS files look like damaged when imported into SketchUp.
                  I ll keep waiting for any possible ideas for few days more, but I see no other available way to keep dealing with SketchUp for easy modeling. Thanks for your kind answers.
                    pibuz
                    Any chance that we get support for 2014 version guys?
                    Thanks in advance!
                    WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                    • F Offline
                      fluid
                      We just released a new version of FluidImporter 2 that solves a lot of compatibility issues with SketchUp 2013/2014. You can download it here:
                      http://www.fluidray.com/downloads/#fluidimporter
                        mac1
                        By default XP does not make the Admin log on at its welcome screen available. Try at the welcome screen pressing cntrl+alt+delete twice; logon user; administrator; pwd the one you orginally set.
                        When you fomatted your disk what did you use FAT32 or NTFS
                          Mikaelo
                          The HDs in both machines (PC and laptop) are formated in NTFS. In laptop it works, in PC it does not.
                          I am the only user and I have not set pass while loging in. WinXP starts without selecting user or seting a pass to proceed.
                            mac1
                            Good NTFS is where the extensive permsiions are implemented;
                            Try the log on I suggested above . I used XP for some time and was surprised. Do internet search on windows xp administrator log in there are a number of how too,s. Note the xp login is different depending on the xp sku version you have, stating just xp is not the full story.
                            • jeff hammondJ Offline
                              i take it a mac version is not in the works nor will it ever be?
                              mac sketchup needs a fast OBJ importer and so far, you're the closest hope πŸ˜„
                              • F Offline
                                fluid
                                Actually, we are working on the Mac version as well, it will be released soon.
                                  😲 πŸ‘
                                  sweet!
                                    pibuz
                                    Thanks a lot fluid! Your plugin is wonderful!
                                    EDIT: I'm seriously intentioned to buy your plugin. What would be the price in euros (I'm italian)? Thank you
                                    • F Offline
                                      fluid
                                      We just released FluidImporter 2 for Mac OSX, together with a new website specific for the FluidImporter. Check it out here http://www.fluidimporter.com
                                        Phil Rader AIA
                                        SU2014 Import Dialog WIndow no OBJ formatSketchup.App>contents>Plugins>Fluidimporter.plugin
                                        Just purchased and installed in both SU2014 and SU2013 Mac and the import option for OBJ does not appear. IE: the plugin is not functioning as it is supposed to.
                                        http://www.philrader.com
                                          KrisM
                                          Has anyone had any success with this plugin?
                                          I downloaded the trial which tells me it's expired even though I have never used it and installed it on the same day as I downloaded it. Two emails to the developer have gone unanswered.
                                          I tried the free version on SketchUp 8 but it doesn't work. I can't tell if it's a problem with my file or the plugin.
                                          I would like to incorporate this plugin into my workflow but am somewhat frustrated. I would like to hear if this plugin actually works.
                                          KrisM
                                            dtrarch
                                            I really needed a good obj import and got the new $ version.
                                            Day one it refused to validate the purchase. πŸ‘Ž
                                            Day two it works perfectly and is really fast an imports accurately. πŸ‘ πŸ‘
                                            IMO good value and is better than the free one for hi-res people stuff.
                                            HMMMMmmmmmm?
                                            dtr
                                            • 7 / 9
