    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    335 Posts 107 Posters 468.5k Views 107 Watching
      rodman100
      I noticed this happens in SU2015 also.
        driven
        I don't have it installed, but what happens if you enter radians?
        1.57079633
        john
          cadmunkey
          1.57079633
          john
          Great, that works! What's going on then?
            driven
            the way ruby handles radians to degrees must have changed or you have another plugin that is changing the definition and it's effecting this one...
            I'll see if I can find any thing...
            john
              cadmunkey
              john
              Cheers, really appreciate your help.
                rodman100
                Thanks driven, I should have spotted that! (one radian = 180/Ο€ degrees). By the way Josh Madison has a great little free prog that everyone should have on their Desktop...
                https://joshmadison.com/convert-for-windows/
                  cadmunkey
                  Wow, I still have the version from years ago that was named MConvert πŸ˜›
                  I keep it on a USB stick as I've always been afraid of losing it as I could never find it online anymore. Thanks for the link!
                    ahdims
                    great tool and works well, however, when i produce a take off table I select the entity ID and there is no identification (highlighting) of the item within the model.
                    Do i need to have a particular switch turned on
                      Sir
                      @krisidious said:
                      nice improvements... That wall tool looks nice. Can it possibly do curved walls? or transform lines into walls?
                      I would also like to draw curved walls with this - could we select a arc then apply the wall type?
                        diredjo
                        @cadmunkey said:
                        run into a problem, not sure if its 2105 specific as I no longer have 14 and before installed.
                        When I have the rotation set to default (0) the member follows the line path fine (on the left in the picture).
                        On the right, I wanted the RHS to be rotated about 90 degrees, so typed '90' in the rotation box but when I apply it I get something more like 35 degrees. I've tried with different inputs but the output never corresponds to the angle I have chosen. Any ideas?
                        i had similar problem before, input required in radians not in degrees.
                        90deg = 1.570796326795rad
                        30deg = 0.610865238198
                        it will works as expected,
                          diredjo
                          hi all,
                          is anyone has plugin files of early version (V0.56).
                          helps are much appreciates
                            Dikshavarma
                            I was facing the same issue thanks for the reply it has helped me a lot.
                              Conquer @tak2hata
                              @tak2hata T2H_BuildingStructureTools2.2.4 plugin does not work in Sketchup 2025!!!!
                              • TIGT Online
                                His tools are no longer supported.
                                Sadly he died some time ago...
                                  @Conquer
                                  Building Structure Tools 2.2.5 is available with the error about File.exists resolved.
                                  • 13
                                  • 14
                                  • 15
                                  • 16
                                  • 17
                                  • 17 / 17
