    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 564.9k Views 108 Watching
    • C
      cadmunkey
      @rodman100 said:
      Thanks driven, I should have spotted that! (one radian = 180/π degrees). By the way Josh Madison has a great little free prog that everyone should have on their Desktop...
      Wow, I still have the version from years ago that was named MConvert 😛
      I keep it on a USB stick as I've always been afraid of losing it as I could never find it online anymore. Thanks for the link!
        ahdims
        great tool and works well, however, when i produce a take off table I select the entity ID and there is no identification (highlighting) of the item within the model.
        Do i need to have a particular switch turned on
          Sir
          @krisidious said:
          nice improvements... That wall tool looks nice. Can it possibly do curved walls? or transform lines into walls?
          I would also like to draw curved walls with this - could we select a arc then apply the wall type?
            diredjo
            @cadmunkey said:
            run into a problem, not sure if its 2105 specific as I no longer have 14 and before installed.
            When I have the rotation set to default (0) the member follows the line path fine (on the left in the picture).
            On the right, I wanted the RHS to be rotated about 90 degrees, so typed '90' in the rotation box but when I apply it I get something more like 35 degrees. I've tried with different inputs but the output never corresponds to the angle I have chosen. Any ideas?
            i had similar problem before, input required in radians not in degrees.
            90deg = 1.570796326795rad
            30deg = 0.610865238198
            it will works as expected,
              diredjo
              hi all,
              is anyone has plugin files of early version (V0.56).
              helps are much appreciates
                Dikshavarma
                I was facing the same issue thanks for the reply it has helped me a lot.
                • C
                  Conquer @tak2hata
                  @tak2hata T2H_BuildingStructureTools2.2.4 plugin does not work in Sketchup 2025!!!!
                    His tools are no longer supported.
                    Sadly he died some time ago...
                    1 Reply Last reply 😞
                      @Conquer
                      Building Structure Tools 2.2.5 is available with the error about File.exists resolved.
                        DOUGLAS0712 Newcomers
                        tem algum versao de tradução para o brasil ?
                        TIGT 1 Reply Last reply
                          TIG Moderator @DOUGLAS0712
                          @DOUGLAS0712
                          Suas ferramentas não são mais suportadas.
                          Infelizmente, ele faleceu há algum tempo...
                          • 13
                          • 14
                          • 15
                          • 16
                          • 17
                          • 17 / 17
