    Droping hunderds of trees on surface
    12 Posts 7 Posters 998 Views 7 Watching
    • P Offline
      podlesnick
      How to drop hundreds of trees on a surface without copying them manually?
        Try Didier Bur's ComponentSpray tool 😄
        Or even my Matrix/Proximity + others Drop or SmartDrop ... or 'fur' ???
        • fuzzionF Offline
          fuzzion
          We have a fur/grass/leave making plugin. Whats stopping us from makaing a 3d tree maker plugin?
          A forest making tool set designed for SU would be radical 👍
          "Only the dead have seen the end of war" - Plato
          • K Offline
            KarinaGM
            With the fur plugin you can populate the surface by component and then replace the component for the one you need.
            **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
            -Benjamín Franklin.**
              Doesn't the later versions allow to select which component to place?
                The fur plugin can populate a certain area with any component you wish. Let it be grass (set it to denser) or trees (set less dense of course).
                • fuzzionF Offline
                  fuzzion
                  Thanks and Yeah I already know that. I once made a mountain covered by thousands of nipples (For artistic purposes)
                  But it would be cool if it created random heights of the tree, applied various different bark textures, make
                  different styles of trees, all at one go.(for productivity purposes) so that i can focus on design.
                  Something specifically designed for SU
                  Edit : WHat I currently do is to get 360 forest HDRI and render them in Vray for productivity reasons
                  due to lack of time.
                    Use Chris' random Rotate and Scale for that.
                    Make a tree is a bit more complicated. But if you find yourself a small set of tree variation you can just feed that to grass plugin.
                      @fuzzion said:
                      But it would be cool if it created random heights of the tree...
                      Both component spray and fur can randomly rotate, scale etc. If you take component spray for instance, you can select up to 8 species as components and with this added variation, there can already be some nice forest.
                      Note the poly count though.
                      As far as I know, iRender has a fractal tree generator built in. Al Hart even made a free product of it that renders trees and then you can save them as 2D face me components (for far distance trees this is better than full 3D)
                      http://www.renderplus.com/wk/RpTreeMaker_Free_w.htm
                      • Chris FullmerC Offline
                        Nothing. I started writing one one night. I got it to make the trunk and branches randomly, then got busy and never got passed that unfortunately. It has always been a dream of mine to write this toool.....someday I guess.
                        All my Plugins I've written
                          Today Chris - today! 😉
                          • fuzzionF Offline
                            fuzzion
                            Plus it will make a lot of people happy 😄 and i bet it will be a very very popular plugin. . . .
