    Drawing a cap for an Aerosol can? [Curviloft / Extrude tools
    15 Posts 6 Posters 1.9k Views 6 Watching
    • utilerU Offline
      utiler
      Hey guys I'm drowning!!
      I've been asked to design a cap for an aerosol manufacturer. to date I've sketched it up and set up a typical can but do you think I can actually work out the best way to model it????
      The idea is to introduce a one piece cap that has a two way action, trigger and top button. The pivot point is located at the back of the cap to give maximum leverage to the trigger; the top button is an obvious downward motion.... It will also be molded from a one piece dye
      I've started by tracing the trigger with a F-spline bezier but it looks ridiculous.
      What should come first? the base of the cap and work up with Curviloft or TOGS edge tools?
      I'm stumped and running out of time. Please please please...
      DymarkCan-Nozzle-template.skp
      Just Curious...
      • fuzzionF Offline
        fuzzion
        I find technical drawing on SU challenging. For technical designs I first imagine what my final shape is and then craft the pieces individually. Like lego πŸ˜„
        Oh and you may want to get Smooth and subdivide plug
        Btw i have been trying this for the last two weeks and it looks promising
        http://www.tgi3d.com/index.php?Page=Amorph
        "Only the dead have seen the end of war" - Plato
          Ross Macintosh
          Andrew - maybe to model the cap you could scale it up and create a series of "contours" that you can subsequently skin. Stop thinking of it as a cap -- model it as a mountain! Actually, I'm suggesting you scale it up to avoid working with extremely short lines.
            First I suggest that you 'scale' your model x1000 [draw a line off to one side that is exactly 100mm long, use the Tapemeasure tool and pick its ends, then type 100m - accept when asked to scale everything].
            Change your Model Info > Units to 'meters' [with no unit suffix displayed, 0.0001 - no snap-length].
            Now carry on modeling... inputting units as if they were still 'mm'.
            This will now let you make very small faces - SUp hates faces <~0.1mm and will often fail...
            Now you should be able to use FollowMe, EEby... and CurviLoft tools with more success.
            Make the can, top, lid, button etc as separate groups [much as it'd be manufactured] - this ensures that the geometry doesn't stick together unexpectedly. You can always explode two parts and regroup then later - like the lid+grip that will need to become one part eventually.
            Much of it is simple 'FollowMe around a circle'. The odd parts like the 'grip' can be made using 2 or 3 lofted profiles - experiment - if it's grouped you can always move it to one side and try an alternative idea...
            When you are finished you need to scale everything back down and change unites to mm again - any small faces will survive - it's just making very small faces that SUp and OpenGL trip up on...
              Here's a quick example for the initial lid form without grip or buttonCapture.PNG
                Mr Carter,
                Attached is an attempt at your cap, which without a front profile i took some liberties. To create i made a circle and ctrl+push/pull'ed it numerous times. With this 'Ringed' cylinder i used the scale tool on each ring to position the rings to the side profile.
                Yes it rough but it is only for explanining that sometimes rubies aren't needed to rough out a model. With the overall cap designed afterwards you can go about the tweaking process.
                Do you have more pictures to go on?
                How's the tiling business? πŸ˜‰
                Tilers Cap.skp
                  With Rich's 'grip' you could use Fredo's RoundCorners to 3d-fillet the outer arrises...
                  • utilerU Offline
                    utiler
                    Thanks Ros, TIG and Rich, I actually used the product design 'out of the box' template from Google and it seemed to work OK but i see what you're saying about small faces.
                    Firstly, apologies for not providing an alternative view; had it in my mind but yet to sketch it. Here's what I've come up with to date.
                    I need to play a little more with the top of the nozzle as only the lower part of it will be symmetrical.
                    Haven't got my head around EEBy yet; so many to chose from its hard to know what's what. TIG, is there a help file?
                    Rich, Tiling business is good I expect. once a tiler, you'll always tile..... 😎
                    DymarkCan-Nozzle-4.skp
                    Just Curious...
                      Nice work Andrew.
                        Ross Macintosh
                        @dave r said:
                        Nice work Andrew.
                        Indeed! Andrew it might look even better if you eliminated the hard 90 degree edges on the trigger & the related ridge with a fillet.
                          Well, I was way off the mark on first attempt... πŸ˜’
                          But this is a great challenge and you definitely nailed it. I gave it another go today to see how EEbyR and Curviloft would handle some shapes. Here's the result(s)...
                          Andrew, do you use SDS?
                          • utilerU Offline
                            utiler
                            Thanks guys, getting used to Curviloft and EEBy....
                            @ Ross, fillet was my next step actually, I'll give it a go!
                            @ Rich, I'm keen to know how you set up your rails to get the nose of the cap to me more uniform; that's the look I'm after! Can you post the skippy so i can look at it? πŸ‘
                            @ Dave, thanks for the advice and comment!!
                            Edit - SDS; do have it but nope don't really use it much... have played a little though... I though this would be more a symmetrical build?
                            Thanks everyone. πŸ‘
                            Just Curious...
                            • utilerU Offline
                              utiler
                              Another thing; mapping an image onto curved surfaces... I recall seeing somewhere here a technique of positioning the image on 4 sides of a cylinder to map correctly.
                              the way I've done it here is fudged the location front and back, selected the image and edited the cap group and painted each arc segment..... efficient? πŸ˜•
                              Just Curious...
                                Why don't i read posts more carefully? πŸ˜’
                                Try running 1 iteration of SDS on the SprayCan while you are INSIDE the group and have the geometry triple clicked. It'll smooth that can out and you'll have a super smooth mesh. Afterwards you can use Thomthom's CleanUp script to reduces the faces but keep the details.
                                This 4 sided technique doesn't ring a bell? And your technique of Alt + is the correct workflow. Though Whaat's UV Tool can map cyclinders easily with a right click. But you well aware of this script. I did notice that when i checked your model that using that texture with Whaat's Tool screwed it up but i presumed it was a scaling issue?
                                As you can see i'm of no help.....again 😲
                                • utilerU Offline
                                  utiler
                                  OK ta. I'll try Whaat's UV tool next time ...
                                  LEGEND! πŸ‘
                                  Just Curious...
