    Flatterly plugin and sketchup 8 help please
    15 Posts 8 Posters 8.1k Views 8 Watching
      mckinnell
      Hello to all,
             Simple question, why after following the guidline for locating said plugin within plugin folder, both the flatterly file and seperate .rb, it will NOT work no matter what i do.
             After looking over the site this plugin is taken from for a FAQ or similar, and finding nothing at all, i turn to all out their who hopefully, can help me to get this sorted............regards and thanks.
                                 Tom......... :smile:
        I quote from the 'flattery' site http://www.pumpkinpirate.info/flattery/
        Installation
        To install Flattery, simply copy the file "flattery.rb" and the folder "flattery" into the SketchUp plugins folder.
        On Windows, this folder is usually C:\Program Files\Google\Google SketchUp 7\Plugins.
        On Macs the folder is usually /Library/Application Support/Google/Google SketchUp 7/SketchUp/plugins.
        Once the files are copied, start SketchUp.
        You should see the Flattery toolbar.
        To check where your version of Sketchup is actually installed open
        Menu > Window > Ruby Console
        and type/copy+paste this
        Sketchup.find_support_file("Plugins")
        Typically you substitute '8' for '7' for a newer version of Sketchup.
        'Flattery' is an Extension and needs switching on in
        Menu > Window > Preferences > Extensions > Flattery
        If the 'Flattery' toolbar is still not showing check
        Menu > View > Toolbars > Flattery
        is ticked...
          mckinnell
          TIG,
             Cheers and thanks for a swift reply; will take a look later on this evening and, hope, all will work out fine........Regards to you and yours...............
            tfdesign
            To be honest, I am finding this plug-in extremely difficult as well as baffling to use. It doesn't seem to behave in the way the instruction suggest- and they are not the best instructions either, especially as you can't even see the cursor on the animated gif's. ๐Ÿ˜ก
            My book "Let's SketchUp!" Download from here
              tfdesign
              Hmm- I think I've got it. Still baffling though! ๐Ÿ‘ฟ
                sketchyarchitect
                Hi I am having the same problem. the plugin appears ticked in the system preferences (window tab) but it is not on the toolbars option (view tab), I tried changing my sketchup folder name from 8 to 7 but was not allowed. how'd you get yours to work?
                kind regards,
                  mckinnell
                  ๐Ÿ˜„ Hi all, well, i finaly got it to work, just re installed my O/S,(win xp pro sp3), and it loaded in first time; must have been an overall system O/S problem, and i got a clean system by doing this as well ๐Ÿ˜† ..........
                                     Cheeers all.
                                        Tom...........
                    tvor
                    @mckinnell said:
                    ๐Ÿ™‚ Hi all, well, i finaly got it to work, just re installed my O/S,(win xp pro sp3), and it loaded in first time; must have been an overall system O/S problem, and i got a clean system by doing this as well ๐Ÿ˜† ..........
                                       Cheeers all.
                                          Tom...........
                    Oh surely not! I have Win7 and SU8 pro, hope you not suggesting to re-install OS every time some plugin will not show it's menu ๐Ÿ˜ฎ
                    I'm experiencing same issue as "sketchyarchitect" - plugin menu will not show โ—
                      Pavel, is your problem only that the Plugins menu doesn't show? If that is the case, go to Preferences>Extensions and tick the boxes you find there. Then click on OK.
                        sdismukes
                        Thank you so much! This was really helpfulโ€”I hadn't been able to figure out how to get this extension installed.
                        Installation
                        is ticked...
                          I see you are on MAC with v2015.
                          This thread is somewhat old.
                          I recommend you get the latest version of "Flattery" from the SCF PluginStore...
                          http://sketchucation.com/pluginstore?pln=Flattery
                          It has been updated to work with >= v2014.
                          Auto-Install it into your Plugins folder using SketchUp > Preferences > Extensions > Install... button
                          Check that its Extension is ticked in the Preferences, then check that its Toolbar is active etc...
                            Lizartin
                            Tried to add the Flattery extension in Sketchup and it isn't showing up...can't find it. Any suggestions?
                              Could you explain what you've done? Did you get it from the Sketchucation Plugin Store? Did you use the Plugin Store tool? If not, what did you do after you downloaded it?
                                Lizartin
                                I actually figured it out finally....only took me 2 days! Thanks!
                                  Explaining what you actually did to avoid ignominy might have helped other users who might be similarly challenged...
