    Tgi3D plugins -
    76 Posts 31 Posters 18.9k Views 31 Watching
    • KrisidiousK Offline
      Krisidious
      I get an error when I open that says "No such file to load -- tgi3d/imain" the file is there.
      there is an extension in the list and it is check marked... but there is no menu options or plugins in the list nor are there any toolbars.
      By: Kristoff Rand
      • charly2008C Offline
        charly2008
        Hi Kristoff,
        Do you have all the TGI-Folders and Files in your plugin folder? And did you activate the TGi3D toolbar?
        Charly
        • EarthMoverE Offline
          EarthMover
          Installer is not working for SU 7. I installed on 7 & 8 and got the same error on 7, but not on 8. Probably a file mix up on their part.
          Content Creator at Skapeup
          • unclebimU Offline
            unclebim
            @earthmover said:
            Installer is broken for SU 7. I installed on 7 & 8 and got the same error on 7, but not on 8.
            I got the same error on 8 but not on 7.
              Krisidious
              Hi Kristoff,
              Charly
              yes I have all of that... and the imain.rbs is in the folder.
              By: Kristoff Rand
                It installed on my PC v7 and v8 with no issues?
                  d12dozr
                  I also have it installed in SU7 and SU8 (PC) with no problems.
                  http://goo.gl/f7ooYh
                    Krisidious
                    are any of you using a external or extra harddrive for SU?
                    By: Kristoff Rand
                      d12dozr
                      Nope
                        Me neither.
                        • CadFatherC Offline
                          CadFather
                          there is a plugin conflict somewhere - remove all and leave only tgi3d - that way it will work and you can try it
                            JuanV.Soler
                            Diego Rodriguez,
                            it is so embarrassing to read you in this Plugin´s Creators forum...
                            Edit : %(#000080)[Sorry Diego for my last words, I thought you were taking advantage.
                            Lo siento. Salud]
                            • sadyoS Offline
                              sadyo
                              I have experienced exactly the same problem with you when trying to use "Tgi3D SU Amorph Training Edition v1.14"...
                              I think they fixed that problem now, because they just released a new versions of Tgi3D SU plug-ins (v1.15).
                              I already try that new version and error message "No such file to load -- tgi3d/imain" is Gone now...
                                Krisidious
                                thanks I'll try again...
                                By: Kristoff Rand
                                • unclebimU Offline
                                  unclebim
                                  Here is the message from the Tgi3D support about the error message "no such file to load -- tgi3d/imain":
                                  Thank you for contacting Tgi3D Support.
                                  We have just released a new versions of Tgi3D SU plug-ins on our website. Although we have not been able re-create the "exact problem with the same conditions" you encountered, we believe that the new version should address the issue.
                                  We would appreciate it if you could download the new version of Tgi3D SU Amorph Training Edition (v1.15t) and re-install it on your computer. After re-install, we would further appreciate your feedback on the result via the Support page on our website.
                                  Regards,
                                  Tgi3D Support Team
                                  I have run the new version and it has installed fine with SU 8 now.
                                    Krisidious
                                    yes the new installer fixed my issue... no errors on 7 or 8
                                    By: Kristoff Rand
                                    • 4 / 4
