    [Plugin] Mirror
    211 Posts 72 Posters 410.6k Views 72 Watching
      As Gai explained... the built in 'Flip' mirrors around the model's axes.
      This is also similar to using Scale with '-1', where the 'mirroring' is limited to three directions too.
      The Mirror tool allows you to mirror around a point, line or plane depending whether you pick 1, 2 or 3 points.
      The most usual is around the plane from 3 points - that way you can Mirror about any plane, not just the axial planes and the mirrored version is related to the plane in the reverse manner to the original selection. To do it with Flip/Scale would involve one or more Rotate steps too.
      The other benefit of Mirror is that [like CAD tools] on completion of the mirroring you can choose to keep or delete the original selection - useful when modeling in symmetrical parts etc as the 'copy' part is built-in for you...
        Although this is not hard with the native tools either;
        1. Copy the "to-be-mirrored" entity
        2. Do the mirroring (flip or scale)
        3. Paste in place the original entity
          But awkward with non-axial flips...
            tfdesign
            I think it's got to be the sado-masochistic mathematician in me! (incidentally, my old man is a Cambridge-educated topologist! πŸ˜‰ ) I like that "now how can I do this without a plugin?". πŸ˜† Sounds good Tig. Thanks for the reply. I'll try and get round to having a go with this tool some time in the not too distant future. πŸ˜„
            Meanwhile, I have a table to build! πŸ˜‰
            Tom
            My book "Let's SketchUp!" Download from here
              tfdesign
              Yes. Do-able, but I can see that it would only be possible if one was good at remembering strings of numbers, repetitions and angles? 😲 πŸ˜‰
              Plugins are best then? πŸ˜„
              • jeff hammondJ Offline
                jeff hammond
                you can do it without knowing any angles etc. but it's a pita.. this video makes it look easier than it really is because i didn't include the 5-10 minutes i spent figuring out the right moves (and have spent that same 5-10 minutes multiple times doing this in real drawings).. mirror.rb is a blessing πŸ‘ β˜€
                [flash=660,405:37jyqytp]http://www.youtube.com/v/Fsr9X4yir2Y?fs=1&hl=en_US&rel=0&color1=0x2b405b&color2=0x6b8ab6&border=1[/flash:37jyqytp]
                dotdotdot
                  mac1
                  Change in SU 7. Place axis then scale??
                  • G Offline
                    GWD
                    TIG,
                    Thanks very much for the outline closer!!!!!! I can use this code in some of mine scripts.
                    regards,
                    Guy
                    • OxerO Offline
                      Oxer
                      Hello!
                      Mirror is one of the plugins i use most, but with SU8, the plugin Mirror 3.3 don't work for me. I use SU 8 spanish on Mac OSX Snow Leopard, one message appears in Console window, with SU7 and Mirror 3.1 the plugin worked fine.
                      This is the Error:
                      Console Error Message
                      I hope you that you help me,
                      Thanks!
                      http://www.oxervision.blogspot.com/
                        leminilab
                        @diego-rodriguez said:
                        this is the error.
                        I use
                        windows xp sp3, in Spanish. sketchup sketchup 8 in Spanish and 7 in Spanish
                        in the two versions generated BugSplats.
                        the image is made with sketchup 8.
                        although sketchup 7, BugSplats generates but does not generate error reporting in the console ruby
                        [attachment=1:3ncjb9nt]<!-- ia1 -->file without zoom.gif<!-- ia1 -->[/attachment:3ncjb9nt]
                        [attachment=0:3ncjb9nt]<!-- ia0 -->mirror 01.jpg<!-- ia0 -->[/attachment:3ncjb9nt]
                        Hi !
                        A little off topic but how did you do that animated gif ? It's looking good !
                        Nicolas
                        • "Live every day as if it were your last and then some day you'll be right."
                        • "ThomThom rules!!!"
                          sents=[]
                              	ss.each{|e|sents.push(e)}
                              	  copy_group=Sketchup.active_model.active_entities.add_group(sents)
                                group_miner(copy_group.entities)###v3.1
                                  new_group=copy_group.copy
                                group_miner(new_group.entities)###v3.1
                          The last line is #266.
                          It seems that there is nothing in the selection to copy... BUT if there is nothing then an earlier part of the code should trap it with an error, starting at line #109
                              def activate
                                  ###Sketchup.send_action("showRubyPanel;")
                                  self.reset()
                                  ss=Sketchup.active_model.selection
                                  if ss.empty?
                                      Sketchup;;set_status_text("Mirror; NO Selection !")###
                              		UI.messagebox("Select Something BEFORE Using the Mirror Tool.")###v2.8
                                      Sketchup.send_action("selectSelectionTool;")
                                      return nil
                          Have you messed up the code with the translation ?
                          • OxerO Offline
                            Oxer
                            @tig said:
                            sents=[]
                            It seems that there is nothing in the selection to copy... BUT if there is nothing then an earlier part of the code should trap it with an error, staring at line #109
                            >     def activate
                            >         self.reset()
                            >         if ss.empty?
                            >             return nil
                            >         end
                            I haven't done changes in the code only i have translated the UI.messagebox and the text of the popups windows, i have probe with the mirror 3.3 original version (english) and don't works too.
                            I don't know if there is a conflict with others plugins.
                              πŸ˜•
                              Can you try it with the 'Ruby Console' open and post all error messages...
                              This is a puzzle... πŸ˜•
                              • OxerO Offline
                                Oxer
                                I have found the error!
                                There is a conflict with SketchyPhisics 3.1, remember i work on Mac OSX.
                                Excuse me, it not was a problem in the plugin there were a conflict.
                                Thanks TIG‘‘
                                  It's no problem for me! Now it's no problem for you!
                                  Β‘No hay problema para mΓ­! Β‘Ahora no es problema para ti!
                                  • G Offline
                                    glro
                                    Thanks TIG‘‘
                                    i use windows XP SP3, and i noticed also a conflict between Mirror and Sketchyphysics3
                                    too bad, we'll have to choose between 2 excellent plugins...
                                    • cottyC Offline
                                      cotty
                                      Thanks TIG‘‘
                                      Is there a solution to solve this conflict?
                                      my SketchUp gallery
                                        Here's v3.4 with some more code tweaks that might stop bugs...
                                        http://forums.sketchucation.com/viewtopic.php?p=276512#p276512
                                        • kenK Offline
                                          ken
                                          I know this is an operator error. I have noticed if you press the delete key instead of the return, the plugin crashes. Is there a way to capture the delete key so it will not crash Sketchup.
                                          Yes, I know I should be more careful.
                                          Thank you for your plugin
                                          Ken
                                            DIEGO-RODRIGUEZ
                                            tig thanks for this new update.
                                            but unfortunately continues to generate bugplat when ouliner window this open, and make mirror for a group or component.
                                            use sketchup 8, windows xp sp3
                                            • 10
                                            • 11
                                            • 2 / 11
