    [Plugin] Mirror
    211 Posts 72 Posters 485.8k Views 72 Watching
      But awkward with non-axial flips...
      • T
        tfdesign
        I think it's got to be the sado-masochistic mathematician in me! (incidentally, my old man is a Cambridge-educated topologist! πŸ˜‰ ) I like that "now how can I do this without a plugin?". πŸ˜† Sounds good Tig. Thanks for the reply. I'll try and get round to having a go with this tool some time in the not too distant future. πŸ˜„
        Meanwhile, I have a table to build! πŸ˜‰
        Tom
        • T
          tfdesign
          Yes. Do-able, but I can see that it would only be possible if one was good at remembering strings of numbers, repetitions and angles? 😲 πŸ˜‰
          Plugins are best then? πŸ˜„
          • jeff hammondJ
            you can do it without knowing any angles etc. but it's a pita.. this video makes it look easier than it really is because i didn't include the 5-10 minutes i spent figuring out the right moves (and have spent that same 5-10 minutes multiple times doing this in real drawings).. mirror.rb is a blessing πŸ‘ β˜€
            [flash=660,405:37jyqytp]http://www.youtube.com/v/Fsr9X4yir2Y?fs=1&hl=en_US&rel=0&color1=0x2b405b&color2=0x6b8ab6&border=1[/flash:37jyqytp]
              mac1
              Change in SU 7. Place axis then scale??
              • G
                GWD
                TIG,
                Thanks very much for the outline closer!!!!!! I can use this code in some of mine scripts.
                regards,
                Guy
                • OxerO
                  Oxer
                  Hello!
                  Mirror is one of the plugins i use most, but with SU8, the plugin Mirror 3.3 don't work for me. I use SU 8 spanish on Mac OSX Snow Leopard, one message appears in Console window, with SU7 and Mirror 3.1 the plugin worked fine.
                  This is the Error:
                  Console Error Message
                  I hope you that you help me,
                  • L
                    leminilab
                    @diego-rodriguez said:
                    this is the error.
                    I use
                    windows xp sp3, in Spanish. sketchup sketchup 8 in Spanish and 7 in Spanish
                    in the two versions generated BugSplats.
                    the image is made with sketchup 8.
                    although sketchup 7, BugSplats generates but does not generate error reporting in the console ruby
                    [attachment=1:3ncjb9nt]<!-- ia1 -->file without zoom.gif<!-- ia1 -->[/attachment:3ncjb9nt]
                    [attachment=0:3ncjb9nt]<!-- ia0 -->mirror 01.jpg<!-- ia0 -->[/attachment:3ncjb9nt]
                    Hi !
                    A little off topic but how did you do that animated gif ? It's looking good !
                    Nicolas
                    • "Live every day as if it were your last and then some day you'll be right."
                    • "ThomThom rules!!!"
                      sents=[]
                          	ss.each{|e|sents.push(e)}
                          	  copy_group=Sketchup.active_model.active_entities.add_group(sents)
                            group_miner(copy_group.entities)###v3.1
                              new_group=copy_group.copy
                            group_miner(new_group.entities)###v3.1
                      The last line is #266.
                      It seems that there is nothing in the selection to copy... BUT if there is nothing then an earlier part of the code should trap it with an error, starting at line #109
                          def activate
                              ###Sketchup.send_action("showRubyPanel;")
                              self.reset()
                              ss=Sketchup.active_model.selection
                              if ss.empty?
                                  Sketchup;;set_status_text("Mirror; NO Selection !")###
                          		UI.messagebox("Select Something BEFORE Using the Mirror Tool.")###v2.8
                                  Sketchup.send_action("selectSelectionTool;")
                                  return nil
                      Have you messed up the code with the translation ?
                      • OxerO
                        Oxer
                        @tig said:
                        sents=[]
                        It seems that there is nothing in the selection to copy... BUT if there is nothing then an earlier part of the code should trap it with an error, staring at line #109
                        >     def activate
                        >         self.reset()
                        >         if ss.empty?
                        >             return nil
                        >         end
                        I haven't done changes in the code only i have translated the UI.messagebox and the text of the popups windows, i have probe with the mirror 3.3 original version (english) and don't works too.
                        I don't know if there is a conflict with others plugins.
                          πŸ˜•
                          Can you try it with the 'Ruby Console' open and post all error messages...
                          This is a puzzle... πŸ˜•
                          • OxerO
                            Oxer
                            I have found the error!
                            There is a conflict with SketchyPhisics 3.1, remember i work on Mac OSX.
                            Excuse me, it not was a problem in the plugin there were a conflict.
                            Thanks TIG‘‘
                              It's no problem for me! Now it's no problem for you!
                              Β‘No hay problema para mΓ­! Β‘Ahora no es problema para ti!
                              • G
                                glro
                                Thanks TIG‘‘
                                i use windows XP SP3, and i noticed also a conflict between Mirror and Sketchyphysics3
                                too bad, we'll have to choose between 2 excellent plugins...
                                • cottyC
                                  cotty
                                  Thanks TIG‘‘
                                  Is there a solution to solve this conflict?
                                  my SketchUp gallery
                                    Here's v3.4 with some more code tweaks that might stop bugs...
                                    http://forums.sketchucation.com/viewtopic.php?p=276512#p276512
                                    • kenK
                                      ken
                                      I know this is an operator error. I have noticed if you press the delete key instead of the return, the plugin crashes. Is there a way to capture the delete key so it will not crash Sketchup.
                                      Yes, I know I should be more careful.
                                      Thank you for your plugin
                                      Ken
                                        DIEGO-RODRIGUEZ
                                        tig thanks for this new update.
                                        but unfortunately continues to generate bugplat when ouliner window this open, and make mirror for a group or component.
                                        use sketchup 8, windows xp sp3
                                          It should roll up the Outliner in Windows ? πŸ˜•
                                            davidlouis
                                            I have replaced an archaic version of the Mirror tool with your new one and see that the right mouse context choice is now gone and only the icon in the toolbar is there. Could you please re-intoduce the necessary lines in the code to enable it to appear in the context menu....
                                            Sorry but i am a creature of habit and the use of the icon interrupts my usual workflow...
                                            Thanks in advance.
                                            Dave
                                            • 11
                                            • 2 / 11
