    [Plugin] Mirror
    211 Posts 72 Posters 485.8k Views 72 Watching
      DIEGO-RODRIGUEZ
      this is the error.
      I use
      windows xp sp3, in Spanish. sketchup sketchup 8 in Spanish and 7 in Spanish
      in the two versions generated BugSplats.
      the image is made with sketchup 8.
      although sketchup 7, BugSplats generates but does not generate error reporting in the console ruby
        The rolled-down 'Outliner' WILL often cause a splat, that is why the new version tries to set it to 'roll-up' - however I notice you have it 'docked' that might be stopping the 'roll-up' - try having the 'Outliner' NOT docked with the others and see if that splats too... If it does the recommendation stands don't have the Outliner open/rolled-down while using tools that process groups - as it can 'splat'!
        I've no idea what the error message means - it must be another script that gets involved with components - quietly_force_sync_mats_cb just - is not in my Sketchup files [I 'grepped' them all]
          Jim
          Does it bugsplat if you use the 2nd parameter for start_operation?
            DIEGO-RODRIGUEZ
            Tig.
            the error in the ruby console, is generated by file called RubyWinFunc.so, using the Vray render engine.
            and
            Sketchup is closed only when the mirror and duplicate the components / groups.
            However if only mirror the components / groups (not duplicate) sketchup is not closed.
            By far the best solution is to have the closed ouliner
            and a question.
            when applied to a curved mirror. duplicated curve is exploited.
            can be solved?
              Diego
              I only rarely happens to me - usually a Curve is kept intact...
              If you know you have Curves and experience the problem then you could manually Group the Selection before Mirroring it.
              I don't know how to stop the rare 'raw' curve exploding glitch - the method used is basically "the selection is grouped, the group is copied, scaled -1 [to 'mirror' it] and then the original group might be deleted, then the group is exploded so the selection is back as it was but now 'mirrored'.
              A Curve shouldn't 'explode' as it's container group explodes but just sometimes it does!
              I was aware of the glitch but in a few tests just now I can't get it to reproduce - could you post a small SKP with a failing example ?
                DIEGO-RODRIGUEZ
                tig. is a very strange error.
                sometimes it generates and sometimes not.
                I have not found a pattern of regular behavior
                • B
                  bd99
                  thankkkkkkkkkkkkkk
                  • T
                    tfdesign
                    Tig, I use the Flip Along tool a lot of the time. I also watched a SketchUp tutorial with an official Google instructor saying that he didn't quite get it (flip along). I don't understand what there is that's not to get? How does your Mirror plugin differ or improve what's already available?
                    Tom
                    • GaieusG
                      With the flip along tool, you can flip along one of the main axes (or those of groups/components) only. This plugin lets you mirror in a bunch of different ways, too.
                        As Gai explained... the built in 'Flip' mirrors around the model's axes.
                        This is also similar to using Scale with '-1', where the 'mirroring' is limited to three directions too.
                        The Mirror tool allows you to mirror around a point, line or plane depending whether you pick 1, 2 or 3 points.
                        The most usual is around the plane from 3 points - that way you can Mirror about any plane, not just the axial planes and the mirrored version is related to the plane in the reverse manner to the original selection. To do it with Flip/Scale would involve one or more Rotate steps too.
                        The other benefit of Mirror is that [like CAD tools] on completion of the mirroring you can choose to keep or delete the original selection - useful when modeling in symmetrical parts etc as the 'copy' part is built-in for you...
                        • GaieusG
                          Although this is not hard with the native tools either;
                          1. Copy the "to-be-mirrored" entity
                          2. Do the mirroring (flip or scale)
                          3. Paste in place the original entity
                            But awkward with non-axial flips...
                            • T
                              tfdesign
                              I think it's got to be the sado-masochistic mathematician in me! (incidentally, my old man is a Cambridge-educated topologist! πŸ˜‰ ) I like that "now how can I do this without a plugin?". πŸ˜† Sounds good Tig. Thanks for the reply. I'll try and get round to having a go with this tool some time in the not too distant future. πŸ˜„
                              Meanwhile, I have a table to build! πŸ˜‰
                              Tom
                              • T
                                tfdesign
                                Yes. Do-able, but I can see that it would only be possible if one was good at remembering strings of numbers, repetitions and angles? 😲 πŸ˜‰
                                Plugins are best then? πŸ˜„
                                • jeff hammondJ
                                  you can do it without knowing any angles etc. but it's a pita.. this video makes it look easier than it really is because i didn't include the 5-10 minutes i spent figuring out the right moves (and have spent that same 5-10 minutes multiple times doing this in real drawings).. mirror.rb is a blessing πŸ‘ β˜€
                                  [flash=660,405:37jyqytp]http://www.youtube.com/v/Fsr9X4yir2Y?fs=1&hl=en_US&rel=0&color1=0x2b405b&color2=0x6b8ab6&border=1[/flash:37jyqytp]
                                    mac1
                                    Change in SU 7. Place axis then scale??
                                    • G
                                      GWD
                                      TIG,
                                      Thanks very much for the outline closer!!!!!! I can use this code in some of mine scripts.
                                      regards,
                                      Guy
                                      • OxerO
                                        Oxer
                                        Hello!
                                        Mirror is one of the plugins i use most, but with SU8, the plugin Mirror 3.3 don't work for me. I use SU 8 spanish on Mac OSX Snow Leopard, one message appears in Console window, with SU7 and Mirror 3.1 the plugin worked fine.
                                        This is the Error:
                                        Console Error Message
                                        I hope you that you help me,
                                        • L
                                          leminilab
                                          @diego-rodriguez said:
                                          this is the error.
                                          I use
                                          [attachment=1:3ncjb9nt]<!-- ia1 -->file without zoom.gif<!-- ia1 -->[/attachment:3ncjb9nt]
                                          [attachment=0:3ncjb9nt]<!-- ia0 -->mirror 01.jpg<!-- ia0 -->[/attachment:3ncjb9nt]
                                          Hi !
                                          A little off topic but how did you do that animated gif ? It's looking good !
                                          Nicolas
                                          • "Live every day as if it were your last and then some day you'll be right."
                                          • "ThomThom rules!!!"
                                            sents=[]
                                                	ss.each{|e|sents.push(e)}
                                                	  copy_group=Sketchup.active_model.active_entities.add_group(sents)
                                                  group_miner(copy_group.entities)###v3.1
                                                    new_group=copy_group.copy
                                                  group_miner(new_group.entities)###v3.1
                                            The last line is #266.
                                            It seems that there is nothing in the selection to copy... BUT if there is nothing then an earlier part of the code should trap it with an error, starting at line #109
                                                def activate
                                                    ###Sketchup.send_action("showRubyPanel;")
                                                    self.reset()
                                                    ss=Sketchup.active_model.selection
                                                    if ss.empty?
                                                        Sketchup;;set_status_text("Mirror; NO Selection !")###
                                                		UI.messagebox("Select Something BEFORE Using the Mirror Tool.")###v2.8
                                                        Sketchup.send_action("selectSelectionTool;")
                                                        return nil
                                            Have you messed up the code with the translation ?
                                            • 11
                                            • 2 / 11
